It is currently Sat Nov 07, 2026 12:01 pm
 Post subject: FYI
PostPosted: Mon Jun 28, 2010 9:56 am  (#1)
Just so everyone knows, I tried Gimp 2.6.9 last night and it messed up the menus in Gimp, My gimp themes doesn't work right and even after I removed it and went back to 2.6.8 it's still not right. All of the menu buttons are blank until I hover over them and the menus are.... I can't quite explain it, bigger, maybe, certainly the theme I had isn't in effect anymore. I can't say if this will happen to other people or not.
 Post subject: Re: FYI
PostPosted: Mon Jun 28, 2010 2:39 pm  (#2)
Thanks for the heads up. It's a beta, or unstable version, isn't it? I will stick to my 2.6.4 until the 2.8 is out as a stable version!!!
PostPosted: Mon Jun 28, 2010 2:57 pm  (#3)
That happens with every update. You have to uninstall the gimp themes and install them again. :)
PostPosted: Mon Jun 28, 2010 3:27 pm  (#4)
i think Jolie is right, but im okay with Gimp 2.6.8, and btw.. whats new in gimp 2.6.9 ??
PostPosted: Mon Jun 28, 2010 4:41 pm  (#5)
I think there's nothing new. Mostly bug fixes from what I understand.
PostPosted: Mon Jun 28, 2010 8:08 pm  (#6)
I saw some minor changes to the filters window, I think it can apply an effect to multiple layers but I didn't try it so so I can't be sure.
As was mentioned above, I think it was mainly fixes.
I've been using 2.6.8 pretty smoothly, although last week it got something wrong and simply would NOT start. I tried uninstalling it, removing every trace of it n the registry and completely copying all of the Gimp folders and registry keys to the affected computer and it still crashed. I finally had to do a completely clean reinstall of windows and everything else on my laptop. It took me half a day to get everything back the way I like it. What scares me is that I still don't know what caused it or how to fix it the next time. The only clue I have was that some fonts were showing on the font list that i had removed weeks and and when I added new ones it died. Having spent 35 years diagnosing and solving problems I get trippy when things happen that I can't figure out.
PostPosted: Mon Jun 28, 2010 9:33 pm  (#7)
I hate to admit it, but I wouldn't even know how to do any of that!
PostPosted: Tue Jun 29, 2010 9:34 am  (#8)
Well, knowing how to do it didn't help me out so it was worthless knowledge in this case.
PostPosted: Tue Jun 29, 2010 4:45 pm  (#9)
Amendment to my last post,
I had just reinstalled everything on my laptop last week due to that problem with gimp. This afternoon it did the same thing, same error, I don't remember the wording but it involved libcairo-2.dll not loading. I was really bumbed out and decided that I wouldn't reinstall everything on a computer every week for one program no matter how good it was. But then I backtracked what I was doing and in both cases I had been deleting some fonts. So on a wild guess I copied everything in my font folder on my other computer and pasted it into my laptop fonts folder then reinstalled Gimp. It worked perfectly, I didn't even lose any of my configuration in gimp. The Point is that if anybody has this problem with libcairo-2.dll a potential fix rather than a complete reformat and reinstall it is to either keep a backup of your fonts folder now while it works then copy it back when needed or copy the fonts folder from a computer that works with Gimp on it. This might save a days work for someone.
PostPosted: Tue Jun 29, 2010 4:55 pm  (#10)
Thanks, I didn't know that. I did it and 2.6.9 works fine, my windows even stay put better which is one of their bug fixes:
[align=center]Overview of Changes from GIMP 2.6.8 to GIMP 2.6.9
* Bugs fixed:
612618 - Font selection remains visible
622234 - gimp.desktop: image/x-psd in MimeTypes twice
622196 - Unportable test(1) construct in configure script
620604 - Description of "histogram" procedure is slightly inaccurate
541586 - Tool options not saved/loaded correctly?
614153 - Importing PDF files with long titles
600112 - blur-gauss-selective.exe crashes
599233 - Dialog of "Save as BMP" ignores changes which are not made
with a mous
565001 - Text-Tool crashes when edit a 2.4.2 version XCF file
610478 - Layer preview suddenly stops getting updated
609026 - leaks shared memory
609056 - Exporting to Alias PIX format fails
608188 - a few strings in Save as... > Raw image data dialog are always
in English
604820 - GEGL Operation "path" crashes GIMP
603711 - Crashes when using path tool
607242 - GIMP 2.7.0 fails to build against libpng 1.4.0
606372 - Saving to .ppm fails on indexed colorspace
605237 - the "Antialiasing..." message in the progress bar does not show
translated
604508 - gimp-layer-new-from-visible should work from updated projection
* Updated and new translations:
Asturian (ast)
Basque (eu)
Burmese (my)
Catalan (ca)
Chinese (Hong Kong) (zh_HK)
Chinese (Taiwan) (zh_HK)
German (de)
Italian (it)
Latvian (lv)
Low German (nds)
Romanian (ro)
Simplified Chinese (zh_CN)
Slovenian (sl)
Ukrainian (uk)
Valencian (ca@valencia)
[/align]
PostPosted: Tue Jun 29, 2010 7:36 pm  (#11)
yes, most of the bug fixes will be implemented in 2.8 i'm pretty sure.
there was also another critical bug that would crash 2.6.9 when you used any scroll bar in a tool selection.
Gradient,brush,even text type
You could mouse wheel and choose or directly select, but if you clicked an up or down arrow on the scroll bar it would crash the program.
this bug has since been resolved, but not yet implemented in 2.6.9
2.6.9 is supposed to be a stable version, but one of the bug fixes for open menus i believe caused lots of problems with the selection boxes.
i am currently using 2.6.8, 2.6.9, and 2.7 all installed on my Windows XP platform with very little problems so far.
i still have the bug with the selection boxes in 2.6.9 but you can work around that by using the mouse wheel to select.
the email i received from bug-zilla stated to look for an updated version after the new bundle is reviewed.
here is the email i received...
https://bugzilla.gnome.org/show_bug.cgi?id=623008
GIMP | Tools | 2.6.9
Michael Schumacher <schumaml> changed:
What |Removed |Added
Status|UNCONFIRMED |RESOLVED
Resolution| |DUPLICATE
--- Comment #1 from Michael Schumacher <[email protected]> 2010-06-28 07:15:46 UTC ---
Thanks for taking the time to report this bug.
This particular bug has already been reported into our bug tracking system, but
we are happy to tell you that the problem has already been fixed. It should be
solved in the next software version. You may want to check for a software
upgrade.
*** This bug has been marked as a duplicate of bug 622608 ***
------- You are receiving this mail because: -------
You reported the bug.
PostPosted: Wed Jun 30, 2010 8:24 am  (#12)
After reading your post I checked and 2.6.9 crashed just as you said it would so i removed it and went back to 2.6.8. All seems to be well now. i have to switch it on my laptop now and opefully this whole matter should be resolved
PostPosted: Thu Jul 01, 2010 1:44 am  (#13)
you can sign up for bugzilla and gimp emails, and youll get emails when new bugs are fixed and new bundles are out, including dl links for those bundles.
much easier than checking the gimp.org site and looking for the dl links.
hope all is well with your Gimp install now. =)
PostPosted: Thu Jul 01, 2010 6:41 am  (#14)
I have gone back to Gimp 2.6.8 after 3 days of 2.6.9 (windows XP )
My problem is that the TEXT tool (Capital A in Toolbox) appears to have a problem on my computer. When I click on a font and try to use the slider to select other fonts , the slider interface dissappears. And I am stuck with one font. The same does not happen if I use the Freetext plugin in Filters where I can select different fonts. I have tried playing with the font library in preferences . Previously if I deleted all fonts Gimp took the windows Font library.
Going back to 2.6.8 the problem is gone. I then retried 2.6.9 and the problem reappeared . I am back on 2.6.8 and there is no problem.
Note that this may be due to other causes and I have not looked at upgrading GTK yet, I also think that the Gimprc file stays the same in upgrades but again I have not looked at this. Unfortunately I do not enough about GTK or how to debug windows except for basic stuff to take this much further.
If any of you are running Gimp 2.6.9 for windows XP could you see if the text tool works correctly so that I may determine whether there is a Gimp problem or whether I have a Windows / compatibility/ Gimp problem on my machine only.
I think this may be another display of the scroll problem mentioned before
Thanks Wbool63
PostPosted: Thu Jul 01, 2010 7:37 am  (#15)
Yes thats the problem I had with the text tool too. I'll signup for bugzilla, thanks for the tip.
PostPosted: Thu Jul 01, 2010 8:02 am  (#16)
my text tool works well :/ and im windows xp
PostPosted: Fri Jul 02, 2010 2:16 pm  (#17)
the text tool worked fine for me also, just the combo boxes i had problems with.
i now only use 2.6.8 and 2.7.1 =)
both run great on Windows XP
PostPosted: Sat Jul 03, 2010 10:25 am  (#18)
2.6.9 seems to have a nasty bug when scrolling...scroll may crash gimp
Only 1 bug vs many other fixed but maybe sufficently nasty to suggest to stick with 2.6.8
