It is currently Sun Nov 08, 2026 7:39 am
 Post subject: Gimp 2.8 release scheduled on 2012 January 24
PostPosted: Fri Nov 04, 2011 7:56 pm  (#1)
Former Member
Source - deviantART
The news already has its time, but continues to impact on those who have not seen. Most of us are already aware about GIMP 2.7.3(unstable) and its single window interface. This is one of those significant improvements in the field of open-source graphic softwares.
The single window option exist and you can test it in the GIMP 2.7.1. You can download it at any time and give a test, but be warned that it will remove your current version of GIMP and replace it by this 2.7.1, so if you want to test, be sure to back up your plugins and whatever settings.
In my experience the Gimp 2.7.3 release is a bit buggy currently, as after activating the option, once you closed GIMP, and relaunched it , GIMP was forgetting that it was in single window mode and went back to floating panels, leading you to reset it correctly each time. And for now, the docks are stuck with the single window, meaning you can't move them in a position that would satisfy you better into this single window.
Tasks left on GIMP 2.8
Write release notes
Announce string freeze
Decide on a splash image
Bug 631934 - Interaction between Old text parameters and new region specific text attributes
Bug 51112 - Support layer masks on layer groups
Single-window mode related bugfixing buffer
If you consider testing Gimp 2.7.3(unstable)
GIMP 2.7.3 can be downloaded as source at the official GIMP website.
To install on Ubuntu add ’ppa:matthaeus123/mrw-gimp-svn’ to your Software Sources. Following this either update and upgrade your existing GIMP installation, or update and install GIMP via the Ubuntu Software Center.
 Post subject: Re: Gimp 2.8 release sheduled on 2012 January 24
PostPosted: Fri Nov 04, 2011 8:48 pm  (#2)
Mike you can download Gimp-2.7.4 here (Windows)
www.partha.com
along with some other goodies.Such as the new fork with the new GML matting tool. :)
Parthas compiles work very nice.
PostPosted: Sat Nov 12, 2011 10:19 pm  (#3)
Former Member
I've been using partha's compiled version, cause it doesn't crash on me. Plus all the extra goodies it comes with. I just thought I'd notify thoughs that aren't using it.
PostPosted: Sun Nov 13, 2011 2:58 pm  (#4)
Former Member
I can't wait for all the updates it comes with.
PostPosted: Mon Nov 14, 2011 3:20 pm  (#5)
steveczajka wrote:
That's cool that you will be able to apply a mask to an entire layer group!
Definitely the feature that makes it for me!
Along with the improved brush dynamics.
-Rob A>
PostPosted: Mon Nov 14, 2011 3:56 pm  (#6)
-Rob A>
You do know that layer masks for layer groups has been put back to 2.10 ?: viewtopic.php?f=7&t=2542&start=10#p37883
PostPosted: Tue Nov 15, 2011 11:13 am  (#7)
-Rob A>
You do know that layer masks for layer groups has been put back to 2.10 ?: http://gimpchat.com/viewtopic.php?f=7&t ... =10#p37883
I had heard that, but thought from Mike's (more recent) posting that it was back in...
Sigh :(
-Rob A>
PostPosted: Tue Nov 15, 2011 11:53 am  (#8)
With the date being moved farther ahead maybe that's what the developers are trying to do.That would be nice. :)
