It is currently Sun Nov 08, 2026 7:05 am
Post new topic Reply to topic  [ 50 posts ]  Go to page 1, 2, 3  Next
 Post subject: Gimp 2.7.4 Update and G'MIC 1.5.0.6
PostPosted: Sun Nov 13, 2011 11:52 pm  (#1)
Just uploaded a new version of Gimp 2.7.4 - latest (as of today, November 13th, 2011) maintenance release and the latest G'MIC 1.5.0.6. I know, David is already on the road to 1.5.0.7, but hard to keep up with him. :)
Let me know if this does not work for you or it breaks etc.
Thanks,
Partha
 Post subject: Re: Gimp 2.7.4 Update and G'MIC 1.5.0.6
PostPosted: Mon Nov 14, 2011 1:48 am  (#2)
Thanks Partha! :) (love the new splash btw) ... could you throw them all together in a zip for us as you create them?
I would love to keep the collection.
Works excellent in Windows XP 32 bit.
Screen shot
Thanks again for all your hard work, and your help.
PostPosted: Mon Nov 14, 2011 3:03 am  (#3)
great ...downloading now
PostPosted: Mon Nov 14, 2011 4:40 am  (#4)
@partha
For the portable did you used the modified gimprun.exe that i tested ?
PostPosted: Mon Nov 14, 2011 5:25 am  (#5)
PhotoComix wrote:
@partha
I had an issue with it on XP and so did not update the portable yet. But since you have Win 7, you should be OK.
PostPosted: Mon Nov 14, 2011 6:23 am  (#6)
ok with what ?
sure the old portable version for me works well with the modified gimrun.exe ...i will wait for the new
(and yes from a selfish point of view i would not mind if would be "7 only" version)
PostPosted: Mon Nov 14, 2011 6:40 am  (#7)
PhotoComix wrote:
ok with what ?
No problems. :)
For you I will make it available in a location that is not necessarily accessible in general. Don't want any XP users, sending me email about it being broken. :)
You will have to wait till evening US eastern.
PostPosted: Mon Nov 14, 2011 12:12 pm  (#8)
Hi, my first post on this forum although I have been using Gimp for some years and more recently following Partha's 2.7 updates.
I downloaded the new 2.7.4 (32 bit regular) yesterday. It seems to install just fine but I get the error message "GNU imagage manimpulation program has encountered a problem and needs to close" when I try to open it. I have uninstalled and reinstalled without success.
I am using XP SP3 and have not had this problem with previous 2.7.x updates.. One quirk is that I install to my D: partition and not to the default C:... which I keep for system files only
I have tried to attach the error file for information but "the extension txt is not allowed"? Would it be helpful to paste the full contents... or am I missing something?
Mark
PostPosted: Mon Nov 14, 2011 12:42 pm  (#9)
Can i install over the 2.7.4 i'm running now..don't want to lose any scripts or plugins
win7 64
PostPosted: Mon Nov 14, 2011 12:45 pm  (#10)
Hi MarkUK, and welcome to Gimp Chat.
I believe your problem may stem from the user environment PATH variable.
Is the PATH located there to the D Gimp-2.7 install?
A path to Gimps bin folder has to be present for Gimp to find its dependencies.
win7 64
I did with Windows XP without a hitch.(IF YOUR OLDER VERSION IS A PARTHA VERSION)
Otherwise uninstall through the CP.Then reinstall Parthas version to avoid conflicts.
Just make sure your added resources are in the USERFOLDER/.gimp-2.7 folders only.
Then you won't lose anything.
PostPosted: Mon Nov 14, 2011 1:01 pm  (#11)
thanks Rod
i made a backup of plugins, scripts, patterns and gradients just in case
off to download the newest 2.7.4 32bit is what i've been running
thanks Partha
PostPosted: Mon Nov 14, 2011 1:08 pm  (#12)
Hi and many thanks
I have checked my PATH and D:\Gimp-2.7.4\bin; is the first entry... which is correct. Do I need anything else here or should I revert to the previous version of 2.7.4 which did work and wait for 2.8?
Mark
PostPosted: Mon Nov 14, 2011 5:22 pm  (#13)
Working great so far..probably a dumb question..but can i install RGGJAN fork over top of it or do i keep it separate
PostPosted: Mon Nov 14, 2011 6:02 pm  (#14)
win7 64
Yes, you should be fine if you do that. However, I would not recommend installing your scripts and plugins in the system directory. You probably should use your local .gimp-2.7 directory.
PostPosted: Mon Nov 14, 2011 6:06 pm  (#15)
Mark
Hi Mark,
Perhaps you can leave me a message on my website and copy and paste the text file? Here you can zip the file and attach it to your message.
Thanks,
Partha
PostPosted: Mon Nov 14, 2011 6:08 pm  (#16)
That's pretty neat! :)
Thanks,
Partha
PostPosted: Mon Nov 14, 2011 6:18 pm  (#17)
great thanks
this is where i've always put them
PostPosted: Mon Nov 14, 2011 6:37 pm  (#18)
alc59 wrote:
great thanks
Don't forget Rod's warning. As long as you are installing over my build, you should be fine. Thanks Rod.
PostPosted: Mon Nov 14, 2011 6:48 pm  (#19)
thanks
big storm coming right over me, have to power down before it does it for me
tornado warning :hoh
PostPosted: Mon Nov 14, 2011 7:38 pm  (#20)
I have installed 2-7-4 64 bit but cannot find 64bit GAP or mathmap files.
GMIC 1-5-0-6 win64 works great
