It is currently Sun Nov 08, 2026 7:05 am
Post new topic Reply to topic  [ 50 posts ]  Go to page 1, 2, 3  Next
 Post subject: Gimp-2.7.5 for Windows 32 bit
PostPosted: Mon Dec 12, 2011 3:13 am  (#1)
I am almost finished compiling Gimp-2.7.5 which is probably going to be the last test beta for 2.7.
This is the latest GIT version, with the new GEGL-0.1.9, BABL-0.1.7, and new PANGOCAIRO.
I have heard this last test version is awesome, and also has tablet support fixed.
I will post a screenshot when the compile is finished and i launch it. :bigthup
 Post subject: Re: Gimp-2.7.5 for Windows 32 bit
PostPosted: Mon Dec 12, 2011 5:43 am  (#2)
way to go Rod! :coolthup
PostPosted: Mon Dec 12, 2011 7:30 am  (#3)
Thanks Partha! :)
This compile seems to be taking forever for some reason.GEGL also.
I am just about half way through the common plug-ins. I believe that is the last part.
Getting there :lol
PostPosted: Mon Dec 12, 2011 7:59 am  (#4)
waiting with you
PostPosted: Mon Dec 12, 2011 10:25 am  (#5)
Actually i finished compiling, created an installer, and installed the Gimp-2.7.5 program on my computer.
Everything works real nice except GEGL. Every time i try to use it ...boom Gimp crashes.
Python-fu works well, as well as Script-fu. I wonder if it's because of the new GEGL package?
Another thing that messed me up was that when it installed it used the UserFolder/.gimp-2.6 folder to draw from.
So when it first launched i got a bunch of errors because it was drawing plugins from gimp-2.6/plug-ins folder.
After i launched it, i closed it right away, and i just deleted everything inside the folders (sub folders of UserFilder/.gimp-2.7), and i was all set.
Except for GEGL that is. :)
So if you install this one be sure and create a .gimp-2.7 folder first to avoid those launch errors.
PostPosted: Mon Dec 12, 2011 11:38 am  (#6)
A portable version would solve the problem! Any chance?
PostPosted: Mon Dec 12, 2011 4:32 pm  (#7)
humm also partha build has problem with gegl, ..just a coincidence or something else ?
PostPosted: Mon Dec 12, 2011 4:37 pm  (#8)
I probably will not release one but Partha may. :)
This is the last beta before the 2.8 release or so i am told.So he may just pop out a Gimp-2.7.5 also.
Maybe after he compiles his i can figure out what went wrong with mine.
I updated Pix-Buf, Glib, Cairo, BABL, and GEGL so it should have compiled without a hitch. I could not find a newer version of ATK.
I did get some deprecation errors for some of the header files in ATK and GTK/Pix-Buf.
G_CONST_RETURN gchar seems to be deprecated?
Ah well maybe Partha can fix it. I won't release my version until the GEGL bug is fixed. :ninja
PC did Partha release a version of the last beta already?
PostPosted: Mon Dec 12, 2011 4:40 pm  (#9)
Incidentally this version is available for Linux already so if someone wants to grab it and test GEGL i would be ecstatic.
That would tell me if GEGL newest version is buggy.
Thanks.
PostPosted: Mon Dec 12, 2011 4:43 pm  (#10)
not yet but something was wrong with gegl in the last 32 bit
(maybe just some dll missed not sure)
i just saw your last post...it is long time i do not try to compile gimp on linux i may try tonight (but if i cannot finish tonight, tomorrow i will too busy to continue )
PostPosted: Mon Dec 12, 2011 5:30 pm  (#11)
Hi Rod,
I compiled gimp-2.7.5 couple of hours ago from git sources 64 bit.
Babl-1.7 gegl-1.9.
Tried Tools > Gegl operation works fine here.
I hope that's what you want to know.
Being a Gimp noob I never used it before.
Atk-2.20 gtk+-2.24.8 cairo-1.10.2.
Don't know what else might be important for you.
Compiling for Windows is definitely not my piece of cake.
Good luck,
Gerard.
Gimp-2.8.14
I use Linux only.
And Virtualbox with Win 7
PostPosted: Mon Dec 12, 2011 6:12 pm  (#12)
Thanks Gerard. All my libraries seem to be up to date.Maybe like PC said it may be a dll issue.
If it is the GEGL compile that failed i can just recompile and prefix it to re install into gimp-2.7.5 so no biggy there. I think i will wait and see if Partha has better luck and maybe some information to get my build env fixed.
Thanks again! :)
PostPosted: Mon Dec 12, 2011 7:13 pm  (#13)
humm we may see if also the sourceforge build has same problems with gegl...just to be sure that the culprit is not something wrong in the source code
PostPosted: Mon Dec 12, 2011 11:46 pm  (#14)
Maybe you can try it with older gegl 0.1.8?
PostPosted: Tue Dec 13, 2011 3:41 am  (#15)
Not sure if it will work with an older version of GEGL. It has to have GEGL-0.1.9 to compile correctly so...
PostPosted: Tue Dec 13, 2011 3:43 am  (#16)
I believe Gerard compiled it and said it works fine. :) :bigthup Thanks again Gerard.
PostPosted: Tue Dec 13, 2011 6:42 am  (#17)
don't know which version that you used
i download gegl #331 from https://gimptest.flamingtext.com:9090/view/gegl/job/gegl-distcheck-master/
and it works fine too.
Sorry for my poor English, I use Google Translate.
There may be something wrong, Please understand.
GIMP 2.10.38 rev1 portable+GAP+G'MIC+nufraw+Beautify+MathMap+...
PostPosted: Tue Dec 13, 2011 7:22 am  (#18)
When you compile a program in Linux it will leave a *.pc file in /usr/lib/pkgconfig.
This file contains version info needed for other programs depending on it.
If you're on Linux that's where you'll find installed version info.
Gerard.
Gimp-2.8.14
I use Linux only.
PostPosted: Tue Dec 13, 2011 7:23 am  (#19)
But according to the git commit log: http://git.gnome.org/browse/gimp/log/ there's been more changes since you grabbed your snapshot, so perhaps those changes will fix your problem?
Unless you all try compiling the same snapshot, then you're not comparing like-with-like.
Kevin
PostPosted: Tue Dec 13, 2011 7:39 am  (#20)
I don't think so.
Gegl hasn't changed since Nov 25.
And the last changes in Gimp are not about gegl.
I've compiled from git about once a week,never any problem.
Gerard.
Gimp-2.8.14
I use Linux only.
