It is currently Tue Nov 10, 2026 3:41 pm
 Post subject: The official dev version of Gimp-2.7.4 for Windows 32 bit
PostPosted: Sun Dec 18, 2011 9:22 am  (#1)
has been released -
http://www.gimpusers.com/downloads/46-g ... -4-windows
I installed it and in my opinion it is very, very slow.
Has anyone else experienced this?
 Post subject: Re: The last official dev version of Gimp-2.7.4 for Windows 32 bit
PostPosted: Sun Dec 18, 2011 6:02 pm  (#2)
Rod have just downloaded, It won't replace my 2.6.11 will it, if not I will Install and take a look.
PostPosted: Sun Dec 18, 2011 6:44 pm  (#3)
It will not , but it will use your gimp-2.6 as a draw to copy all the files to
USERFOLDER>gimp-2.7>resources directory
So you will want to start it, shut it down, then delete all those extras in the resources it copies.
Then run it again and setup your prefs for docks and all that stuff.
When you install click customize to get python and allow old plugins.
I got many errors because of the plugins in gimp-2.6 folder it copies so if you get some don't worry that is why.Just let it start then shut down gimp and delete all those extra resources then restart it.It will be fine then.
I really like the new installer. :)
PostPosted: Sun Dec 18, 2011 9:32 pm  (#4)
Rod have you tried to install mathmap and gmic into this version yet
PostPosted: Sun Dec 18, 2011 11:55 pm  (#5)
Installed mathmap as per photocomix's instuction for 2.7 -Works OK
installed gmic files in folder to plugins and pointed path to it as in MM -No Good
The following error came up in console, I deleted the duplicated dll's still no good but no error message
there's a second bin folder inside 32? I have no idea of the purpose of 32 folder
other than gmic problem I like it.
PostPosted: Mon Dec 19, 2011 5:26 am  (#6)
Did it run slow for you?
PostPosted: Mon Dec 19, 2011 7:33 am  (#7)
I've downloaded it and will try it later, but just so I know what to look out for "Run slow" doing what?
Kevin
PostPosted: Mon Dec 19, 2011 8:30 am  (#8)
Graechan what error you have for gmic ?
PostPosted: Mon Dec 19, 2011 10:51 am  (#9)
hello everyone :ffy
I noticed the same thing Rod, it works very slowly, so I went back to the last portable version of Partha.
PostPosted: Mon Dec 19, 2011 12:30 pm  (#10)
Maybe this is the impression that it is slower when is started (maybe by GEGL *. dll ?) - But it seems (after the first test) that everything is working properly - and certainly the GMIC, Mathmap, User Filters, GEGL, pdf and some *. 8bf (but an old problem).
The only problem is remembering the old plugin file location: GUF (User Filters); 8BF (Pspi) and Free Type (fonts) - does not help edit the gimprc (typed paths are partially erased at the next start).
According to me - really worth a try!
ps. there are also some plugins Gimp SHARP (you can add:
http://www.gimpchat.com/viewtopic.php?f=11&t=405&start=0)
PostPosted: Mon Dec 19, 2011 5:21 pm  (#11)
could not get gmic to show in Filters, has anyone else installed gmic on this version, below is my error
PostPosted: Mon Dec 19, 2011 8:42 pm  (#12)
Never gave up, new day,fresh mind, Much better results,GMIC now OK (I removed plug-in file from 2.6 before re-installing 2.7)
now I'll install GAP after a coffee.
PostPosted: Tue Dec 20, 2011 4:40 am  (#13)
Yeah that is what i was saying remove everything gimp copied from 2.6 folder because it will error 2.7 a lot.
Then add the plugins you need one at a time and see how that goes.
I haven't added anything to this version yet.I probably won't.
PostPosted: Tue Mar 06, 2012 3:33 am  (#14)
If the very recently changed task list is to be believed, then the title of this thread is wrong! 2.7.5 is getting an official release before 2.8 arrives.
 Post subject: Re: The dev version of Gimp-2.7.4 for Windows 32 bit
PostPosted: Tue Mar 06, 2012 3:57 am  (#15)
May? Probably more like July. :)
 Post subject: Re: The official dev version of Gimp-2.7.4 for Windows 32 bit
PostPosted: Tue Mar 06, 2012 8:59 am  (#16)
Is this safe to go? :D
PostPosted: Tue Mar 06, 2012 7:09 pm  (#17)
I was planning to release a maintenance update. But I think I will wait till 2.7.5 is released to do so.
PostPosted: Tue Mar 06, 2012 8:28 pm  (#18)
Partha - I think i may try and compile this next version myself.
Rob - I changed the topic to reflect it isn't the last version before Gimp-2.8.
Deb - Deb i think you should wait for the next test release from Partha. And remember these are only test beta versions (all uneven number releases are). Gimp-2.8 will be the next stable release fit for production work.
My personal beliefs...
I think the only reason there is a Gimp-2.7.5 official development release is because it will probably contain everything Gimp-2.8 will include. Which is pretty much what Gimp-2.7.4 has already.
It will just be released as a beta version (uneven number).
They will test it until May or later and release Gimp-2.8 with the same content.
They know Gimp users are getting antsy. :)
PostPosted: Tue Mar 06, 2012 9:27 pm  (#19)
I thought 2.8 was suppost to be released in February; now it's March. See that Partha is about to compile a new version of the 2.7x series so what gives? I've stayed (admit purposely) out of the look since January but now I'm curious. :)
PostPosted: Wed Mar 07, 2012 1:51 am  (#20)
Really it is my belief that Parthas last release IS the next official dev release Gimp-2.7.5.
It seems to me he has been one step ahead of each test release since he started compiling. :)
When he released Gimp-2.7.5 the devs released Gimp-2.7.4 :lol
I give up on wondering anymore. It ( Gimp-2.8), will be released when it gets released i guess.
