It is currently Sun Nov 08, 2026 7:38 am
 Post subject: Gimp Gap for 2.7.5 64-bit
PostPosted: Wed Dec 28, 2011 9:23 am  (#1)
Hi All,
Looking for volunteers to test Gimp GAP 64-bit. Note that this is my first build and some modules crash, but seems to work. I need experts who can verify this while I figure out why some of the modules are crashing. Also note that the original GAP has not been updated in 3 years.
Let me know if you are interested.
Thanks,
Partha
 Post subject: Re: Gimp Gap for 2.7.5 64-bit
PostPosted: Wed Dec 28, 2011 10:33 am  (#2)
Hy the original GAP was updated !!
it was even a recent build of GAP 2.7 that i was testing on your portable 32 bit just now
(here the GC new viewtopic.php?f=9&t=2365 )
I may well try your build too but first better check that you traced the right link for most recent version ,that seems hidden very well...well maybe hidden in the most obvious place "master"" there i see more recent changes even if most are about translations
should be somewhere here http://git.gnome.org/browse/gimp-gap/
Anyway JamesH did it find a GAP_2,7 there time ago so the code should be there, even if i can't see any visible 2.7 branch
but maybe is hidden in master
PS About JamesH gap require a additional dll from gimp 2.6, intl.dll to works
everything seems working fine ..well not sure for the Master Videoencoder but just because it always confuse me
PostPosted: Wed Dec 28, 2011 3:32 pm  (#3)
Thanks for the update PC. I found the git version and will give it a go.
PostPosted: Wed Dec 28, 2011 5:19 pm  (#4)
Yes i thought that version of GAP (2.7) had a layer-effect-apply error?
Partha if you compile for 32 bit i will test that for you. :)
PostPosted: Wed Dec 28, 2011 5:40 pm  (#5)
Me too, except that i found problematic test the Master Videoencoder but is important check it well
