It is currently Sun Nov 08, 2026 7:46 am
 Post subject: Gimp-2.6.12
PostPosted: Fri Feb 03, 2012 6:44 pm  (#1)
A build src is available.
http://www.gimpusers.com/news/00399-gim ... le-release
There is one last bug fix release in the stable GIMP 2.6 series before the highly anticipated GIMP 2.8.
Lots of reported problems have been fixed:
Changes from 2.6.11 to 2.6.12:
These bugs were fixed:
627328 – GIMP 2.6.10 segfaults when CTRL-left click on a layer mask
631885 – GIMP fails to import a path from SVG
631728 – Crash or Gtk-CRITICAL on File→Open
641259 – [abrt] gimp-2:2.6.11-1.fc14: py-slice.py:172:slice:TypeError: integer argument expected, got float
640219 – gimp(1) manpage fixes
640612 – Sample Colorize does not function non-interactively
646947 – file-pdf-load: Don’t use deprecated API
639203 – file-psp: fix for bogus input data
639203 – Fixes for some buffer overflow problems
652280 – Guard against crash due to quitting while DND is processed
660305 – fails to build with -Werror=format-security
623045 – script-fu: make server IPv6 aware
and many more!
Also there have been several translation updates.
I am compiling now for Windows. :)
Just finishing up with GEGL compile.It will probably be another 2 hours or so before it is totally compiled.
 Post subject: Re: Gimp-2.6.12
PostPosted: Fri Feb 03, 2012 6:46 pm  (#2)
Hope you will share Rod; not sure if the developers are going to release 2.6.12 (Windows version) since it's already been a few days and still no compile. :)
PostPosted: Fri Feb 03, 2012 6:55 pm  (#3)
Yes i noticed that and this is why i decided to go ahead and compile it.If it works ok on my system i will share a download link with you folks. :)
PostPosted: Sat Feb 04, 2012 1:36 am  (#4)
BABL and GEGL compiled nicely, however while compiling Gimp-2.6.12 i ran into a slight problem with
script-fu-server.c file.
I have asked Partha for some much needed help. :)
PostPosted: Sat Feb 04, 2012 8:03 pm  (#5)
How does this differ from the 2.7.5 version some may be using already?
PostPosted: Sat Feb 04, 2012 8:11 pm  (#6)
If you already have 2.7.5, then don't install 2.6x. You are using the GIMP Beta (all odd numbers such as 2.7x is beta; even numbers such as 2.6x is stable release). 2.7.5 has more features then 2.6x. 2.8x will just be a stable release and hopefully include all the features that 2.7x has; it should be released in a few weeks (so cross your fingers). :)
PostPosted: Sat Feb 04, 2012 8:14 pm  (#7)
2.6 (even number releases), are stable releases.
2.7 (uneven number), releases are test or dev releases.You can also tell if a version is a test release or unstable release by loading Help>About and if its a test release Wilbur will be wearing a hard hat. ;)
I am actually really very surprised that the developers have not compiled this stable version for Windows themselves.
This is an error i have never encountered compiling Gimp-2.6.11 or Gimp-2.7.4. Perhaps this is why.
PostPosted: Sat Feb 04, 2012 11:05 pm  (#8)
I dont think its available for Mac at this point.
PostPosted: Sun Feb 05, 2012 3:45 am  (#9)
No it is only available as source code at this time. :)
PostPosted: Sun Feb 05, 2012 10:19 am  (#10)
There seems to be a 2.6.13 in the pipeline.
Branch Commit message Author Age
gimp-2-6 build: Bump version in repo to 2.6.13 Mukund Sivaraman 5 days
Take a look here http://git.gnome.org/browse/gimp/
Gerard.
Gimp-2.8.14
I use Linux only.
And Virtualbox with Win 7
PostPosted: Sun Feb 05, 2012 10:30 am  (#11)
lol; guess 2.6.12 opened up a can of worms. Guess I'll wait then. :)
PostPosted: Sun Feb 05, 2012 2:27 pm  (#12)
Just sent you an email Rod. Take a look and let me know. :)
Thanks,
Partha
PostPosted: Sun Feb 05, 2012 4:31 pm  (#13)
Yup. that was the ticket.
Compiling now.Partha you rock.
I bet the newest GIT build (Gimp-2.6.13) is with the server file fixed. :lol
As soon as its compiled i will test it on my machine, make sure it's clean and create an installer for it.
Thanks again Partha.
PostPosted: Sun Feb 05, 2012 4:59 pm  (#14)
ok the mac version is out now
PostPosted: Sun Feb 05, 2012 5:05 pm  (#15)
Cool Akky, maybe you can give us a shout out how it works? :)
That is if you decide to update.I really do not think there will be much difference.Other than it being even more stable.I believe these issues had to be ironed out before a stable release of Gimp-2.8.
I really am not sure why they may release a Gimp-2.6.13. :lol
PostPosted: Sun Feb 05, 2012 6:07 pm  (#16)
They released 2.6.12 Windows installer at Sourceforge. Just finished installing it (not sure 13 will be needed). Main motivation is that they said they fixed some stability issues. We shall see. lol
Running it now and Impressionist (PSPI) still works. :)
PostPosted: Sun Feb 05, 2012 6:56 pm  (#17)
Oh i see how they are now! :) :lol
I just got it compiled too.
Ahh well.I will place a link to the version i compiled on my blog site Monday.
PostPosted: Sun Feb 05, 2012 7:27 pm  (#18)
You had your chance; you blew it Rod. lol
Not sure why they even bothered if 2.6.13 is going to be released in the next few days. Maybe you can beat them to the punch then. ;)
PostPosted: Sun Feb 05, 2012 7:50 pm  (#19)
Nah i have the new Gimp-2.6.12 compiled now so i will just wait for the new Gimp-2.8 to be released. :)
However i newer Gimp-2.6.12 is pretty stable i will keep a link to it as an older version that works, and actually has paint with gradient available. :lol ... (plus PSPI still works)
Just in case someone needs to re install it and can not find it anywhere else.
PostPosted: Sun Feb 05, 2012 8:31 pm  (#20)
Just playing with it now and it seems to be working fine...went in over the top of previous version ok .
