It is currently Mon Nov 09, 2026 12:38 am
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
 Post subject: 2.8 RC1 for windows released
PostPosted: Sun Apr 08, 2012 7:25 am  (#1)
gimpusers
 Post subject: Re: 2.8 for windows released
PostPosted: Sun Apr 08, 2012 8:40 am  (#2)
that's the release candidate... not the "actual" 2.8
PostPosted: Sun Apr 08, 2012 8:46 am  (#3)
Is the release candidate like a beta?
 Post subject: Re: 2.8 RC1 for windows released
PostPosted: Sun Apr 08, 2012 9:29 am  (#4)
Yes.
I am running it (in Linux of course),runs quite well.
I hope python is included otherwise a lot of plugins won't work.
Gerard.
Gimp-2.8.14
I use Linux only.
And Virtualbox with Win 7
PostPosted: Sun Apr 08, 2012 11:07 am  (#5)
I would like to put it in Fedora 16 but I don't know how to put them in unless they are in the repository.
PostPosted: Sun Apr 08, 2012 4:18 pm  (#6)
@molly,
I wrote a howto to install it from git.
viewtopic.php?f=24&t=1261
If you now have 2.7.5 installed you might have all the dependencies already installed.
Don't use --prefix=/opt but use --prefix=/usr.
If you run into problems just holler.
Gerard.
Gimp-2.8.14
I use Linux only.
PostPosted: Sun Apr 08, 2012 4:25 pm  (#7)
Thank you Gerard.
I did install it in Windows and there are a lot of scripts I can't get to work so I don't know if that would be so in Linux or not. One of them was the Graechon one, picture frame, I do have both scripts installed, wrap-map and picture-frame and I get an error No selection defined. (I tried it with a selection and without one and still get the same message. There were some more that didn't work either
I will look at your instrucs and see what it entails.
PostPosted: Sun Apr 08, 2012 5:38 pm  (#8)
For all you Ubunties (Ubuntinites ? :) ), here is the PPA from Otto:
https://launchpad.net/~otto-kesselgulas ... /+packages
PostPosted: Sun Apr 08, 2012 5:44 pm  (#9)
what about the Fedoress's? lol
PostPosted: Sun Apr 08, 2012 5:49 pm  (#10)
Sounds like Empresses? :)
PostPosted: Sun Apr 08, 2012 5:53 pm  (#11)
Fedora 16 :teeth
PostPosted: Sun Apr 08, 2012 11:44 pm  (#12)
I'm kind of astonished at the size of the dev installer. :)
73MB? ... wow!
So i installed it and it uninstalled my gimp-2.6.12 even after i set up a different install location. :lol
Selecting customize allows for a few alterations in the program.
So after i run it i will try and add my other custom files that were in Gimp-2.6.12.
Mainly theme engines and gtkrc folders. :bigthup
Well it copies gimp-2.6 folders and its contents so be forewarned.
1) It uninstalled my Gimp-2.6.12 program, but left all the folders and the Gimp-2.0 directory
2) It copied MY ENTIRE USER/gimp-2.6 directory and renamed it gimp-2.8 but left the gimp-2.6 folders? WHY??
I can't use them anymore.
It loads rather quickly and the splash is nice though. :)
PostPosted: Mon Apr 09, 2012 12:04 am  (#13)
Python works ?
At least you have the option to install it if all the py libraries are in place ?
PostPosted: Mon Apr 09, 2012 1:47 am  (#14)
Yes it actually calls python (according to the pygimp.interp file), from within itself so its self contained.I am guessing that is why its so huge! :)
Older plugins work and i got PSPI working for all of my ADOBE plugins.
I also have themes working in it. :)
Impressionist worked also without having to add the line in the pspirc file
I can not however get Gimp Help manual to load within the program. :hoh
I have not tested my tablet yet.
PostPosted: Mon Apr 09, 2012 8:46 am  (#15)
Hey Guys,
Hi i just installed GIMP 2.8.0-RC1 (WIN) and its realy good,
but the new sliders are shitty :2thd. Is there any way to get the old ones back?
Specally the Brush-Size-Slider is badly configured -> i want the logarithmic scale back.
Need help!
...Thanks
Yugon
PostPosted: Mon Apr 09, 2012 10:02 am  (#16)
There's no way you can get that back without patching source code.
We briefly discussed log scale and, AFAIR, agreed that it's a good idea. It's just, as far as I can tell, noone actually sat down to implement that.
Is the lack of the log scale the only problem you have with the new widget?
PostPosted: Mon Apr 09, 2012 10:37 am  (#17)
Ok..Thanks!
IMHO is the new slider too big, but i can live with it...
But if you click on the bottom part of the slider,
you get the fine adjustment, I think its a little bit useless (I missclick very often). If i want a specific value, i type it in.
please make the possiblity to turn this of (or to get the old sliders back | i m a creature of habits).
I liked the big button in 2.6 and if i clicked somewhere else on the slider the value changed with decimal steps.
That was very usefull.
Thanks..Yugon
By the way i think there is something wrong with the slider of the fill tool (If you minimize the size of the toolbox window).
please excuse my english...I hope you understand me.
PostPosted: Mon Apr 09, 2012 2:27 pm  (#18)
I tried the 2.8 rc today, it's horribly buggy, it has all the same problems that 2.7.6 has, rendering it unusable for me.
PostPosted: Mon Apr 09, 2012 2:34 pm  (#19)
I'm starting to think they've just made 2.8 so much bigger and heavier that it just refuses to run well on my computer... even the startup screen takes like 3 times longer than on 2.6.
At this rate though, it looks like I'm stuck with 2.6 for now... :(
PostPosted: Mon Apr 09, 2012 5:18 pm  (#20)
It uninstalled my Gimp-2.6 so i just left it uninstalled.It works pretty fast on my XP software and its loaded with all my stuff from 2.6 so far no bugs here. :)
