It is currently Mon Nov 09, 2026 12:38 am
 Post subject: "GIMP-2.8rc1-Windows-Friendly_64bit" ready for testing
PostPosted: Thu Apr 19, 2012 9:15 pm  (#1)
EDIT 22 April 2012
Some bugs fixed (a group of filters were not loading)
NEW LINK
http://sourceforge.net/projects/gimp-pa ... z/download
shortly the main difference from the standard version are
1)It may run alongside the stable version
2) Support for Python plugin work out of the box
3) the Help is preinstalled
4) start in single window mode (you may change this if you prefer multi-windows)
4) Run perfectly from the main HD but may be used also as portable
5) More commune file types supported out of the box:
a few examples: PDF , OpenRaster,WebP,and for animation AVI and .SWF (flash )
6) most useful (and often hard not only to install but also to find ) plugin and script installed
This is far to be the full list but is just to give a idea
UFraw
( open and pre-edit photo in raw formats )
LensFun
(to correct lens distortion)
GMIC
(the last stable version released yesterday)
MathMap
(second only to gmic as best multifilter plugin and the only that allow to assemble several filters to create new ones ... without known anything of code)
UserFilter aka Filter Factory Convertor ( a multifilters plugin that may use a very diffuse type of PS filters... more then 1.000 are included, but not preinstalled,)
GAP
( suite of tools for animation)
MUCH MORE
7) all what above may be easily unistalled or replaced with newer version (When will arrive new versions.. as now is all up to date) and all the addon are well separated from the Gimp core
HOW TO START IT THE FIRST TIME :
just unzip,everywhere you like EXCEPT that in "Program Files" and "Program Files(x86)"
and click on Gimp-2.8.0-RCI-1.exe
You may also RIGHT click, and chose from the menu that will pop out "send to desktop" to create a desktop shortcut
WHAT ELSE TO KNOW
All what added (plugin script , brush,pattern etc ) is kept clearly separated from the gimp core:
all addon are in the "_pref1" folder clearly visible at soon you open the zip
Inside that "_pref1" folder you will see folder with names as "plugin" "brush" "pattern" ...each of that folder contain a subfolder called "_preinstalled" ...
And if there it is something that you don't need then you may just remove from "_preinstalled" and if you want instead add something, you may place there and will be installed (obviously if compatible )
DOWNLOAD
 Post subject: Re: "GIMP-2.8rc1-Windows-Friendly_64bit" ready for testing
PostPosted: Thu Apr 19, 2012 9:16 pm  (#2)
PS
1)Credit
Too sleepy to be able to give the proper credit to the many that well deserve
But at least i must credit Samj because i build this on the top of her 2.8 portable and i included many plugin she compiled for 64bit
(i.e GAP) and Partha (that compiled many other plugin here included)
2) if any problem with this version report here don't disturb the developers;
if is something i may fix i will fix asap, if is a bug to report to the dev i will do
PostPosted: Thu Apr 19, 2012 10:24 pm  (#3)
Photocomix you left out the default gimp folders e.g. share/gimp/2.0/brushes, also palettes
PostPosted: Thu Apr 19, 2012 11:51 pm  (#4)
actually something is wrong with all preference folders
PostPosted: Fri Apr 20, 2012 6:24 am  (#5)
Just waking up i am going to check now, also if i have no very clear what you intend for something wrong
PostPosted: Fri Apr 20, 2012 7:01 am  (#6)
Humm..the first time tooks a awful amount of time to load but once loaded i can't see nothing wrong
About the preference paths i used Samj 28 portable as core, and its architecture is a bit unusual (as example instead then a .2.8 folder has a equivalent "pref_1" folder" and use a Samj utility called Marenguin to guarantee portability.
But as far from script and plugin seems all right, i see it load far too much brushes i have to slim down the number of preinstalled brush
Few minutes ago i starting to use for edit a series of images ,till now i don't meet problem..well i was expecting be much more fast then the 32bit version but even if here i had 8GB Ram doesn't seems perceptibly faster
PostPosted: Fri Apr 20, 2012 7:28 am  (#7)
Graechan one group of script was not properly loaded (because that undocumented limit in the number of preference paths for folder) that may caused problem with some of your script
Fixed now on my nlocal copy ,i'm going on checking to see if i found something else to correct before replace the file on sourceforge
I didn't try yet Ufraw and lens fun
PostPosted: Fri Apr 20, 2012 6:37 pm  (#8)
@Graechan
Yes it was something wrong with scripts & plugins preference paths, too much paths create a formatting error and then a group of plugins & script were not loaded.
Fixed now i am uploading now a fixed version
If you don't want download again, you may just move the content of a script Subfolder, in another and eliminate the empty subfolder and this is the point ,its preference path
Basically only 15 paths are supported, i added 1 more at the last minute and that was the culprit, and the solution is just eliminate 1 plugin preference path
For some reasons tonight the upload on Sourceforge is really slow,anyway a replaced file should be available shortly after this message
PostPosted: Fri Apr 20, 2012 7:22 pm  (#9)
It's the other folders I had no brushes patterns palettes e.t.c
PostPosted: Fri Apr 20, 2012 7:32 pm  (#10)
I just downloaded this version and gave it a try. I don't know why, but it won't open any .jpeg or .jpg files. The error console says they're unknown.
PostPosted: Fri Apr 20, 2012 8:16 pm  (#11)
I just redownloaded and tried the results were the same, I installed on my 'F' drive and as the image shows no brushes etc the error is when refreshing the brushes and the paths in preferances are incorrect.
PostPosted: Sun Apr 22, 2012 6:47 am  (#12)
A new version is out (see first message)
Lacertile
It seems as you started gimp from gimp.exe,(in the bin folder) you should use instead Gimp-2.8.0-RCI-1.exe visible at soon you open the main folder.
Anyway was a different problem now fixed i suggest to switch to this
but again you should start (this version of gimp ) clicking on "Gimp-2.8.0-RCI-1.exe" not on gimp.exe
(as in partha portable you should use gimprun.exe )
PostPosted: Sun Apr 22, 2012 6:51 pm  (#13)
The problems I showed above still have not been addressed? or replied to. Do you have an incorrect rc file
PostPosted: Sun Apr 22, 2012 7:58 pm  (#14)
I tough was solved ,you didn't reply to my previous message:
i asked if you was starting gimp clicking on "gimp.exe" that would have explained yours and lacertile problems
You may confirm that instead you are loading gimp clicking on Gimp-2.8.0-RCI-1.exe ,but the problem remain?
please let me know
PostPosted: Sun Apr 22, 2012 8:43 pm  (#15)
PostPosted: Sun Apr 22, 2012 9:33 pm  (#16)
Photocomix I was starting up using the correct method
PostPosted: Sun Apr 22, 2012 10:07 pm  (#17)
bad new :gaah
not sure what could be the cause i hope i can fix soon
the same utility that allow portability should also take care to "translate" the path when is moved in a different drive but obviously in your case doesn't work
PostPosted: Sun Apr 22, 2012 10:24 pm  (#18)
I unpacked your program in my 'F' drive, to be sure I did same in my 'C' drive, but still did not load corectly.If there is anything else I can try let me know
PostPosted: Sun Apr 22, 2012 11:56 pm  (#19)
please let me know
I unpacked the program to a secondary hard drive and started it by clicking on the link you specified, but it still will not open .jpeg files. It still says it's an unknown file type. It will open .xcf files fine, but won't recognize any file type outside of that.
PostPosted: Mon Apr 23, 2012 9:05 am  (#20)
Sorry something breaks portability
I temporary remove the file till i find a fix
I know better Partha build, with this i try to build on Samj portable build but she use a more complex system (i believe more powerful and flexible , but more mysterious to me,is called Mareguin ) to allow portability...evidently something screw up the mechanism...well i will see if i can fix or i will port back everything to the last 2.7
