It is currently Sat Nov 14, 2026 11:08 pm
Post new topic Reply to topic  [ 57 posts ]  Go to page 1, 2, 3  Next
 Post subject: Gimp-2.8 for Windows
PostPosted: Fri May 04, 2012 9:52 am  (#1)
Woke up to see this today. :)
A compiled Gimp-2.8 for Windows.
 Post subject: Re: Gimp-2.8 for Windows
PostPosted: Fri May 04, 2012 10:28 am  (#2)
Is this the real deal now or another sorta/kinda?
PostPosted: Fri May 04, 2012 10:32 am  (#3)
Just noticed the source code for the official stable release got put up on gimp.org now just waiting on a windows installer being published for the stable version.
PostPosted: Fri May 04, 2012 10:54 am  (#4)
Yes that is what i am compiling now. :)
Gimp-2.8 for windows.
First test
PostPosted: Fri May 04, 2012 11:01 am  (#5)
Second test
Still having libintl-8.dll file problems though.
PostPosted: Fri May 04, 2012 11:07 am  (#6)
Test3 - Brush dynamics
I have a question.
When applying brush dynamics "Random Color" what pattern or palette does gimp use?
Clearly i have red and white as color picks, and my brush color is not those colors.
PostPosted: Fri May 04, 2012 11:12 am  (#7)
Test4 - single window mode and themes.
PostPosted: Fri May 04, 2012 11:16 am  (#8)
Test 5 - diagonal cropping.
PostPosted: Fri May 04, 2012 11:17 am  (#9)
I have to play with brush dynamics a bit more but it seems pretty stable, and its faster than the dev versions and isn't chunky.
PostPosted: Fri May 04, 2012 11:20 am  (#10)
I can not test any filters or python as i still have libintl-8.dll issues and none will initialize.
Sorry about that.
But i can test the basics. Anything else you guys want me to test?
All the color tools seem to work better.
PostPosted: Fri May 04, 2012 11:29 am  (#11)
It includes python ?
I see what you wrote about the dll but that is a different matter
PostPosted: Fri May 04, 2012 11:41 am  (#12)
I do not think it will run right out of the box.You will still have to select it in the installer.
I compiled on a windows machine with codegen already installed so the build included it for me. :)
I am sure the new official release of the setup will include a choice still.
PostPosted: Fri May 04, 2012 2:10 pm  (#13)
I am pretty sure the Random Color uses the selected Gradient. Do we have diagonal guides now? Or just cropping?
PostPosted: Fri May 04, 2012 4:22 pm  (#14)
Yes one of the test images i posted shows the diagonal cropping guides.
PostPosted: Fri May 04, 2012 6:32 pm  (#15)
Rod Will you be posting a windows gimp 2.8 soon, ps I have not given up on gimp# but i'n waiting for your 018 compile for windows to be posted.
PostPosted: Fri May 04, 2012 9:45 pm  (#16)
I can send you the compiled version Graechan in a link via PM.
All you will need to do is unzip to your gimp-2.0\lib\gimp\2.0\plug-ins folder and restart Gimp-2.6.12.
Keep in mind i have not tested it in Gimp-2.6.12 , nor Gimp-2.8 RC-1 as i do not want to mess up my current install.
I tested on Gimp-2.7 versions only, and it fails. A small hint... i believe it's missing a crucial dll file. Possibly mono.
I will include it in the zip if you like.
As far as Gimp-2.8 for Windows i only compiled it out of curiosity. With the dll problems i keep getting i wouldn't dare post an installer yet. Not until i fixed that at least.
Besides i believe the official installers will give you a choice to allow older plugins to work. Mine wouldn't.
You are much better off waiting for the release from the official Gimp team in my honest opinion. :)
Attached is one that you can unzip to RC1 /lib/gimp/2.0/plug-ins folder and it will work. I tested this one.
gimp-sharp4-Gimp-2.8-RC1.zip [1.52 MiB]
Downloaded 171 times
PostPosted: Sat May 05, 2012 12:54 am  (#17)
Hi Rod.
The libintl-8 problems are not from gimp itself, otherwise you wouldn't have it getting compiled.
I had some problems, too. Always moaning that there is no pointer to __printf__.
I got rid of that, by:
- making sure, that tehere is only one libintl-8.dll on my system.
- the path, where the only one resides, is in systems PATH (in my case my gimp/bin directory).
- deleting all (except especially for a plug-in) dll's from plug-in directories.
Hatti
PostPosted: Sat May 05, 2012 1:34 am  (#18)
Thanks Hatti i will try that. :)
PostPosted: Sat May 05, 2012 4:28 pm  (#19)
okay, I am just waiting for a 2.8 (64-bit) stable version for Windows that I don't have to worry about compiling, and that all the tools and scripts will work in.
Is there any such beast yet?
If so, could someone post a download link to it. If not, I will just sit and wait for a Linux Fedora version :pengy
PostPosted: Sat May 05, 2012 4:31 pm  (#20)
Sorry Molly all i can supply is 32 bit. (which is now available through gimp.org)
Partha would be the one to ask about 64 bit. :)
