It is currently Sat Nov 07, 2026 3:45 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2, 3  Next
 Post subject: Gimp 64 bits Windows Portable (Partha+SourceForge) for testing
PostPosted: Thu May 17, 2012 7:46 am  (#1)
Bonjour,
Here is a link to a "special" version of portable Gimp 64-bit (This is a 7zip archive) :
http://www.aljacom.com/~gimp/Gimp-2.8-6 ... rtha+SF.7z
85 730 756 bytes
___
EDIT
Version 2012 05 20
81,6 Mo (85 663 268 bytes)
___
This version is compiled by Partha (partha.com).
The 32-bit part is compiled by Jernej Simoncic (SourceForge).
Thank you for your work.
This version can run on a USB key.
The plugins compiled in 32bit or 64bit can run on this version.
You must start Gimp by clicking on a .bat file
This archive will be available a few days.
Some plugins are installed:
- Partha plugins.
- UFRaw
- GMIC 64-bit beta.
- CamoTruck (32bit).
 Post subject: Re: Gimp 64 bits Windows Portable (Partha+SourceForge) for testing
PostPosted: Thu May 17, 2012 8:13 am  (#2)
what the main differences with your previous 64bit portable version ?
downloading now ,maybe the answer is evident
PostPosted: Thu May 17, 2012 3:02 pm  (#3)
Bonjour,
The normal 64-bit version is compiled by Jernej Simoncic (SourceForge).
This version is compiled by Partha.
Here the difference.
PostPosted: Thu May 17, 2012 3:21 pm  (#4)
Speaking of the 64-bit version from Jernej, where can I find it. I looked on sourceforge and only find -dev and -debug of the 64bits. If I remember correctly it should auto detect and install that version correct?
PostPosted: Thu May 17, 2012 3:50 pm  (#5)
Bonjour,
@ZWard117
Version detects if the environment is 32bit or 64bit.
Link (SourceForge) :
http://sourceforge.net/projects/gimp-wi ... e/download
PostPosted: Thu May 17, 2012 4:54 pm  (#6)
Sam the new master has the UserFilter gimprc fix.So more than one entry can be listed.
Did Partha recompile 32 bit too? Or isn't that the same build?
Thanks!
PostPosted: Thu May 17, 2012 5:03 pm  (#7)
Thanks!
Rod,
I always compile both versions. :) If you have the recent version, I fixed the file size bug as well.
Thanks Samj.
Partha
PostPosted: Thu May 17, 2012 5:09 pm  (#8)
I have the one with the file size bug fixed. But userfilter still doesn't stay put in gimprc file.
I will try your latest 32 bit then. :)
Thanks Partha!
PostPosted: Thu May 17, 2012 5:29 pm  (#9)
@Partha
Thank you for your work on the compilation of Gimp.
@Rod
The utility "maringouin" modifies the file "gimprc" (language and/or PhotoComix options).
I can add an option if it seems useful.
Just tell me what to do.
PostPosted: Thu May 17, 2012 5:46 pm  (#10)
Here is the fix, but i no longer use your version Sam just Parthas is installed now.
I uninstalled all versions except Parthas Gimp-2.8 32 bit
Michael Natterer [GIMP developer] 2012-05-16 23:22:37 UTC
Fixed in master and 2-8:
commit 741daccf0238ccbc022b4e047698be0480e0a5be
Author: Michael Natterer <[email protected]>
Date: Thu May 17 01:14:22 2012 +0200
Revert "app (gimprc): Delete dead assignment"
This reverts commit d6d2a0bbd15f25d820631b4db6236f6a42b4b49c
and allows more than one unknown gimprc token again.
Fixes Bug 674096 - Strange behavior with gimprc
(cherry picked from commit 8851ec0b6e463c070f513f3f44f40323da25934f)
app/config/gimprc-unknown.c | 6 +++++-
1 file changed, 5 insertions(+), 1 deletion(-)
@ Partha - Nope that is your last version with the jpeg fix but Userfilter still doesn't keep its guf folder path in gimprc. :)
PostPosted: Thu May 17, 2012 5:49 pm  (#11)
Rod, I did not see the commit by Mitch. I will apply it and let you when I am done.
Thanks!
Partha
PostPosted: Thu May 17, 2012 5:57 pm  (#12)
Thanks!
Partha
Cool!
Thanks Partha. :)
PostPosted: Thu May 17, 2012 6:07 pm  (#13)
If I don't use userfilter, does it work all right?
Tony
mechatherium.deviantart.com
What did you expect? Shakespeare?
PostPosted: Thu May 17, 2012 6:10 pm  (#14)
PSPI (except for some PS filters broken since 2.6.8 unfortunately) still works fine Mechatherium. My favorite PS plugins that still work in GIMP are Impresionist, GML Matting, Paint Engine and Eye Candy 3. Pretty much, the rest of the PS plugins that I use I run via Shellout Python plugin. :)
PostPosted: Thu May 17, 2012 6:45 pm  (#15)
samj wrote:
Bonjour,
Ah ok i was wandering if was the case to update my version (btw i just uploaded now the file) to this
PostPosted: Thu May 17, 2012 6:50 pm  (#16)
I have gotten many to work.
Some using Vista/Win 7 may even be able to get more to work by disabling UAC
(Recommended you re enable it after shutting down Gimp)
New Plugin: Noise Shampoo (denoising)
Minor Updates: Flat Median 1.3 (dry & AA & Ram), Julia World 1.1 (smooth colors)
Compatibility Updates: For Vista/Win 7 users with UAC enabled , you don't get anymore file access errors with Blots 2.1 , Gradient Smithy 1.1 , and Julia World 1.1.
These are since the updates the ONLY Mehdi plugins that will work in Gimp-2.8 with PSPI. :)
Whatever was updated in the src fixes the issue. So my guess is UAC or "User Account Control".
I have contacted Mehdi and asked for a UserFilter version of the filters. I am guessing because this is the src i will be denied... :lol
PostPosted: Thu May 17, 2012 6:56 pm  (#17)
You can still use both in Gimp-2.8. You just need to open the GUF directory for UserFilter filters each time you use the filter.
PSPI for Adobe 8bf filters works regardless.
Looks like Partha may have a fix for us soon though. :)
Thanks again Partha, and you are still my hero. :bigthup
PostPosted: Fri May 18, 2012 4:40 am  (#18)
LOL. Thanks Rod. :)
I applied the patch and rebuilt Gimp. 32-bit works fine as tested by Rod. I will push the rebuilds on my server soon. I will let you know once I do that.
Any feedback on the 64-bit appreciate.
Edit: 32-bit and 64-bit updated now.
PostPosted: Fri May 18, 2012 5:43 am  (#19)
Yes it works excellent. :)
After installing this newest version be sure and add a new folder to your UserNameFolder\.gimp-2.8 folder and name it "userfilter"
Then copy, or move all the filters in the GUF folder to the new userfilter folder you just created.
Fire up Gimp-2.8 and open any image. Now go to Filters>Generic>Filter Factory and you should have 2 new paths when you open filter directories tab in the dialog.
one to the UserFolder\.gimp-2.8\userfilter folder
and one to the gimp-2.8\share\gimp\2.0\userfilter folder
Just like Edit\Pref will do. :)
After that now all you need to do is place extra filters in the userfilter folders and UserFilter will find them.
Thanks Partha. :bigthup
For those interested i did recompile UserFilter.exe and all the other 2guf exe files with the newest libraries.
I use it right now so i know it works for windows 32 bit.
If you want it PM me.
Updates - newest libraries used for compile, and the new menu item name is Filters>Generic>UserFilter
PostPosted: Fri May 18, 2012 11:47 am  (#20)
Could I get a copy of most of these? (really want GML Matting as is no longer available....)
