It is currently Sat Nov 07, 2026 3:57 pm
 Post subject: Versions Gimp Windows 2.8.2 Portable 32-bit and 64-bit
PostPosted: Sat Aug 25, 2012 8:23 am  (#1)
Bonjour,
Here are the links that these versions can be downloaded :
Translation :
http://translate.google.ca/translate?sl ... ndows.html
Français :
http://samjcreations.blogspot.ca/2012/0 ... ndows.html
Extract in the root of a hard drive or a USB key
Start Gimp by clicking "Demarrer_Gimp.bat"
 Post subject: Re: Versions Gimp Windows 2.8.2 Portable 32-bit and 64-bit
PostPosted: Sat Aug 25, 2012 8:51 am  (#2)
Thank Samj
PostPosted: Sat Aug 25, 2012 12:51 pm  (#3)
i get a loading error for "sharpfeather.exe" for a missing dll, same for refocus it
I don't like much the 2 additional menus, Ghost and Python-Fu menus, just now i am trying to get rid of it editing the scripts registration path
Everything else seems working perfectly..humm maybe not the web browser it give up with a critical error
But about the web Browser maybe will be nice change default for preferences/help to web browser and then include your CHM help
It works pretty well and is much more updated then the alternative from Gimp for Windows, that is still the help for 2.6, also on Windows chm help are easier to navigate
Thank again samj
PostPosted: Sat Aug 25, 2012 3:25 pm  (#4)
Thanks Sam! :)
I have been running the portable versions through Wine quite successfully.
PostPosted: Sat Aug 25, 2012 4:26 pm  (#5)
Bonjour,
@PhotoComix
Web browser :
The Gimp "web browser" must be inhibited via the "Preferences" menu.
At home I have no critical error :roll:
DLL :
Some plug-ins compiled into ancient environments must be compiled again.
(You can send me the sources to see what I can do)
2 additional menus :
I use these menus for my tests. You can destroy the script-fu and .py files from directory ....\pref_1
64 bits :
I recommend using the 64-bit version which is substantially corrected (compared to the version on SourceForge).
PostPosted: Sat Aug 25, 2012 5:05 pm  (#6)
@PhotoComix
sharpfeather.exe
Deleted message, I found the sources to compile.
See the following messages.
PostPosted: Sat Aug 25, 2012 9:51 pm  (#7)
Refocus it
Binaries for Gimp 2.8.2 Windows 32 & 64 bits (This filter is very slow).
refocus-it-2.0.0-win-32bits-64bits.zip [315.56 KiB]
Downloaded 327 times
PostPosted: Sun Aug 26, 2012 8:05 am  (#8)
sharpfeather.exe & texturetiler.exe
textureops-0.3-win-32bits-64bits.zip [112.31 KiB]
Downloaded 242 times
PostPosted: Sun Aug 26, 2012 9:18 am  (#9)
thank Samj
yesterday i may have done some errors ,i restarted afresh till now everything is fine
PostPosted: Sun Aug 26, 2012 10:09 am  (#10)
Samj i tried again this time i didn't change anything i just try to load from demarrer_gimp.bat
I am quite perplex of the error message because that is a path for a folder where is my previous copy of your portable, and could not be a coincidence
anyway i got this same message also using french, spanish and english bat .
PostPosted: Sun Aug 26, 2012 11:20 am  (#11)
@Photocomix
If you want to extract in a directory containing spaces, you must use ".bat" files attached.
In principle you should extract the archive in the root of a hard drive or the root of a USB key.
Extract in a directory containing spaces may affect the operation of the whole.
You can change your .bat files (Photocomix..... .bat) by modifying the start of the command line start /D "%~dp0"
This allows you to associate an image file (xcf, xcf.gz, etc.) to a .bat file
I'll update my archives.
bat_files.zip [1.98 KiB]
Downloaded 201 times
PostPosted: Thu Oct 25, 2012 10:38 am  (#12)
Sorry for resurrecting this old post!
I'm looking for an updated version of the refocus-it (iterative refocus) plug-in.
I'm already using this GIMP version: GIMP-PC_Lab.2_8_2-64bits-R6!!
But I found the refocus-it have a problem, it only uses 1 core! The plugin is so old that it wasn't prepared to take the new approach of multicores, instead of higher CPU frequencies.
I've also found this: http://www.docstoc.com/docs/55762005/So ... eading-and
We need to refine this program! At first, make it use all cores! Optimize it.
Then, it would be really interesting if we could create an vector path, and it uses this vector path to refocus. Don't need to be that smart first.
Photoshop is based on this: http://www.cse.cuhk.edu.hk/~leojia/proj ... st_deblur/
PostPosted: Thu Oct 25, 2012 11:54 am  (#13)
Is the subject in this post perhaps what you are looking for?
http://www.gimpchat.com/viewtopic.php?p=70217#p70217
PostPosted: Thu Oct 25, 2012 12:05 pm  (#14)
I belive the version i installed is the most recent , but you are right the plugin is really slow i was even wandering if remove it for that very reason
About deblurring i was experimenting a new tool (see Oregonian link, the windows binary is on https://github.com/Y-Vladimir/SmartDeblur/downloads ) that as now is available as standalone
PostPosted: Sat Nov 03, 2012 4:26 pm  (#15)
@samj:
I have some questions regarding your versions:
1) As I'm running a 64 bits windows, I have downloaded the 64 and the 32 versions to see if there was any visible difference, as it feels no different to me, I'd like to know what were the pros and cons, stability, performance and such.
2) do I have to launch with demarrer_gimp.bat every time ?
3) if yes how should I use the features provided by maringouin ?
