It is currently Sat Nov 07, 2026 11:03 pm
 Post subject: McGimp 2.8.2
PostPosted: Sun Sep 16, 2012 8:28 pm  (#1)
McGimp 2.8.2 is released. :) It's available at www.partha.com.
New to this version:
1. UFRAW to edit Camera Raw pictures.
2. "Save for Web (RIOT)"
I have removed simple-bilateral as it segfaulted on launch. If anyone knows why, please let me know.
Thanks to the beta testers!! Could not have done it without you. :tyspin
Thanks,
Partha
 Post subject: Re: McGimp 2.8.2
PostPosted: Mon Sep 17, 2012 1:14 am  (#2)
Thanks to you partha for putting in the effort. I know I am gonna love this!!!
PostPosted: Mon Sep 17, 2012 2:18 am  (#3)
Cool beans...thanks Partha :)
PostPosted: Mon Sep 17, 2012 4:29 am  (#4)
Excellent! Thank you very much!
This way to have the updated G'MIC version included in GIMP is very useful. For me, moreover, one of the greatest things about McGimp is that Mac users can take advantage of the Refocus-it plug in for the first time (yours is the first Mac release ever of this useful plugin, as far as I know).
Just an idea: I believe that another very useful addition could be the "Maximize local contrast" script, here:
http://registry.gimp.org/node/17151
I use it quite a lot (the first version on that page; the other new version does not work on my Mac).
Thank you!
http://www.GKweb.it/
http://www.flickr.com/photos/gkweb/
PostPosted: Mon Sep 17, 2012 5:41 am  (#5)
Thanks! :) I am trying to provide a set of plugins that will be useful to photographers right "out-of-the-box" so you need not go hunting for them.
Thank you!
On the other hand, I am glad you went hunting since you found a nice script. I will try them out and let you know how they both work.
PostPosted: Mon Sep 17, 2012 7:28 am  (#6)
This is great! All these mac users!
PostPosted: Mon Sep 17, 2012 5:27 pm  (#7)
I love the mcgimps, and now that I changed to the default workspace, it's even better! I love finding out little nuggets of wisdom here in Gimp Chat, just by reading what others ask and answer.
PostPosted: Mon Sep 17, 2012 5:39 pm  (#8)
I am glad you like it. :)
Let me know if you have any issues.
PostPosted: Mon Sep 17, 2012 8:16 pm  (#9)
heh, heh, will do. Did you change up where the filter windows go? I don't remember which ones went behind and which went in front, but it seems like more go in front now. Could be just because those are the ones I am using.
PostPosted: Tue Sep 18, 2012 4:39 am  (#10)
Yes, I did. I used a patch from Karine. However, it's a work-in-progress. Some plugins might show in front but send the main Gimp window all the way in the back. This still requires some work. :)
PostPosted: Fri Sep 21, 2012 4:22 pm  (#11)
Forest,
I tried out the "maximize local contrast" and you are right that the new version does not work. The older one functions just fine by copying it to your local scripts folder ~/Library/GIMP/2.8/scripts.
One thing I should point out that maximize local contrast is similar to tone mapping and if you try the "advanced Tone Mapping" script already included (Filters -> Enhance -> Advanced Tone Mapping) with the defaults which I tweaked, you should be pleasantly surprised. :)
Partha
PostPosted: Fri Sep 21, 2012 6:31 pm  (#12)
Thank you, Partha! I'll try!
PostPosted: Sat Sep 22, 2012 10:21 pm  (#13)
I have just noticed a new action that I don't think happened in earlier versions. When I have another window open, such as gimp chat, and have gimp open on top of it, when I use a filter, then gimp will go behind the internet window. If I minimize the internet window, no problem but if i want it to stay open under gimp than I have to click on the gimp icon to bring gimp back the top. Not really a problem, just seems like this is something new.
PostPosted: Sat Sep 22, 2012 10:57 pm  (#14)
It's an artifact of trying to solve the whole problem with some scripts/plugins opening behind the main window. So, you will notice that sometimes this happens. It's pretty tricky to solve this problem.
PostPosted: Mon Sep 24, 2012 1:23 pm  (#15)
It's not much of a problem, just sort of surprised me. And as long as Gimp works otherwise, I can easily deal with it! Thanks for the explanation.
PostPosted: Mon Sep 24, 2012 11:23 pm  (#16)
Ran across another interesting happening. I was outlining some text. I do alpha to selection, then edit>stroke selection. At first I thought it was broken because it would NOT stroke when I clicked on the stroke button, but I discovered it's just a quirk...you cannot click on the stroke button right away, you first have to click somewhere in the dialog window and then you can click on the stroke button and it works fine.
PostPosted: Sat Nov 17, 2012 4:21 pm  (#17)
Hi Partha,
Gets better and better......thanks for your work on this.
Seems every time more windows open in front than before.
The only thing i use the old version for is a Normal Map plugin.
Are there any that are compatible for this version? I saw that the recent 2.8. Normal Map is now working in Windows.
Regards
Sam
PostPosted: Sun Nov 18, 2012 6:59 pm  (#18)
I've found that just about all of the stuff we had before works by putting them into the usual folders but using a slightly different path to the previous versions.
PostPosted: Sun Nov 18, 2012 11:53 pm  (#19)
Thanks Akky,
Will give it a go, just thought i would ask before i broke something!
PostPosted: Mon Nov 19, 2012 12:57 am  (#20)
you have G'Mic built in now and it has over 400 filters in it and always being updated to include more...
