It is currently Sat Nov 07, 2026 11:04 pm
 Post subject: Shades of grey
PostPosted: Mon Nov 19, 2012 5:18 pm  (#1)
Bonjour,
Binaries (win) + source
shadesofgrey-win-32bits-64bits.zip [42.06 KiB]
Downloaded 189 times
 Post subject: Re: Shades of grey
PostPosted: Mon Nov 19, 2012 6:25 pm  (#2)
Just tried it; not sure where it would be of benifit samj. Could you elaborate where a good use for this plugin would be for? :)
PostPosted: Mon Nov 19, 2012 7:03 pm  (#3)
@lylejk
You can try on an RGB image to understand the effect of the filter (does not work on a RGBA image) :roll:
PostPosted: Mon Nov 19, 2012 7:20 pm  (#4)
It just appears to darken and shift the hue of the image I tried; also I notice some posterization with the result. Currently have no vision as to what I could use it for but I always find purposes for plugins soon enough. Found a cool way to make David R's Felt Pen preset work quite well if you run another GIMP Testing preset first (Naggabot's Vector Field Rotation Demo). Below's a result if you run Naggabot's preset first followed by Felt Pen preset. :)
PostPosted: Mon Nov 19, 2012 7:30 pm  (#5)
Hey Lyle, does your Dad get to see this collection of him.
PostPosted: Mon Nov 19, 2012 7:57 pm  (#6)
I print them out from time to time. Thanks for asking Molly. :)
PostPosted: Mon Nov 19, 2012 8:01 pm  (#7)
One possibility for this filter: Get an image in pseudo gray
Source : http://www.mahvin.com/2011/11/easy-bord ... -gimp.html
PostPosted: Tue Nov 20, 2012 6:27 am  (#8)
Hi Samj
I also don't know how to use it.
Could you please explain?
Hatti
PostPosted: Tue Nov 20, 2012 8:43 am  (#9)
Bonjour,
Example :
test.xcf.bz2 [2.17 MiB]
Downloaded 198 times
PostPosted: Tue Nov 20, 2012 9:22 am  (#10)
Bonjour samj,
I think what Onkel Hatti means is:
Nous avons besoin d'une explication décrivant ce que ce plug-in est utilisé pour.
(Google translation of "We need an explanation describing what this plug-in is used for.")
Merci
Kevin
