It is currently Sat Nov 07, 2026 11:02 pm
 Post subject: Gimp-PC_Lab 2.8.3 new version is coming
PostPosted: Thu Jan 10, 2013 9:15 am  (#1)
I tried to integrate the plugins from Onkel Hatti version in my release , and seems with success
I would also like to integrate the Rggian selection tool as revised by Onkel Hatti, but i didn't figure out yet if is possible and if so how :gaah
Still testing till now everything seems working fine so i think to release soon the 64bit version and the 32bit shortly after
 Post subject: Re: Gimp-PC_Lab 2.8.3 new version is coming
PostPosted: Thu Jan 10, 2013 10:08 am  (#2)
The tool is not a plugin, but is part of the Gimp core. It can only be added during the Gimp build process.
PostPosted: Thu Jan 10, 2013 10:38 am  (#3)
Yes i know ;)
the point is see what part of the gimp core was modified to support the tool, its dependencies
Then what was modified in the code is reflected in the binary and i have the binary of both ... and luckily both version are sufficiently similar to support "transplants" (to successfully transplant all plugins i had only to fix a couple of "missing dll " errors )
i hope you follow my reasoning :
i prefer work at binary level when possible and MAYBE in this case is possible
I like much Onkel version but there are at least 2 features in the Samj build i was using ,
(1 the possibility to load the program choosing a "Basic" version that will load faster and smoother, or a "Full extra version "
2 the possibility to run a fully portable GMIC ,Samj version stores GMIC definition files internally )
that i want to preserve.
Also the Onkel Hatti "gimprun.exe" that allow to use his version alarm most of antivirus , that with default setting will delete , or block it , ..and then gimp will not work :gaah
...for some reason instead the Samj utility is much more tolerated by antivirus so i will prefer use it to avoid to respond to all users alarmed by antivirus alert or deluded because "It doesn't work" (In the ,alas very frequent cases of antivirus just silently deleting "suspect"files without asking confirm )
But i believe for doing it i would need the help of Samj and/or Onkel Hatti
Anyway i am quite satisfied with this new version i am testing
PostPosted: Thu Jan 10, 2013 11:19 am  (#4)
Your are probably awere of the, but here is a link to the build info. Maybe you can figure it out through the process.
https://github.com/rggjan/Gimp-Matting/ ... ld/windows
PostPosted: Mon Jan 14, 2013 5:51 am  (#5)
I updated gmic hopefully fixed a little issues with the help,
... i think should be ready to upload but a may delay a bit to make first a decent documentation
(somebody had offered to help to get the list changes, of all extra scripts plugins and addon , with the related links but i never heard of progress :roll: ...i fear i should do by myself :gaah )
If anybody here was using the last version please help :
Except gmic (already done ) did you noticed any included script /plugin that may be updated to a newer version ?
Or something new that you will like to be included
Not only plugin/script also preset for curve or gimpressionist, palette expecially palettes that may be used as swatches ( pantone , kuler , web safe ... )
in case add here the link !
PostPosted: Mon Jan 14, 2013 3:46 pm  (#6)
Hello Photocomix,
It's me who has offered my help to participate to the documentation, I have started to do it but by lack of time these few weeks, I had to put aside my participation to this project :oops: .
I hope it is not too late to help you ?
Concerning the necessary changes, I think the plugin "cartoonizer" needs to be updated in version 0.8
http://code.google.com/p/cartooner-colo ... loads/list
PostPosted: Mon Jan 14, 2013 5:19 pm  (#7)
Looking forward to having a look at the new version in simple terms is it 2.8.2 with the Rggian selection tool included or does it use the latest gimp 2.9 binaries
PostPosted: Mon Jan 14, 2013 5:32 pm  (#8)
Photocomix,
I don't know if it's important or not for you but when I have started to list the addons with the software notified by Odin, I have noticed that several plugins and scripts were duplicate. I haven't check the brushes, patterns ...etc.
There are all the duplicate addons that I have seen in 32 bit version & 64 bit version.
Duplicate in PC LAB 64
Jhead.exe
C:\Users\ADMIN\Documents\GIMP-PC_Lab.2_8_2-64bits-R6\GIMP-PC_Lab.2_8_2-64bits\lib\Jhead
Cartoonizer.exe
C:\Users\ADMIN\Documents\GIMP-PC_Lab.2_8_2-64bits-R6\GIMP-PC_Lab.2_8_2-64bits\PhotoComix\plug-ins\_Preinstalled\others
Save layers with names.py
C:\Users\ADMIN\Documents\GIMP-PC_Lab.2_8_2-64bits-R6\GIMP-PC_Lab.2_8_2-64bits\PhotoComix\plug-ins\_Preinstalled\python
Advancedtonemapping.scm
C:\Users\ADMIN\Documents\GIMP-PC_Lab.2_8_2-64bits-R6\GIMP-PC_Lab.2_8_2-64bits\PhotoComix\scripts\_Preinstalled\color-contrast
Sg-quantize.scm
Sg-layer-fit-in-selection.scm
C:\Users\ADMIN\Documents\GIMP-PC_Lab.2_8_2-64bits-R6\GIMP-PC_Lab.2_8_2-64bits\PhotoComix\scripts\_Preinstalled\layer
Border_and_copyright_by_blackTau_gimp_28.scm
C:\Users\ADMIN\Documents\GIMP-PC_Lab.2_8_2-64bits-R6\GIMP-PC_Lab.2_8_2-64bits\PhotoComix\scripts\_Preinstalled\logo
Chalk_it_up_28.scm
Fp-script-fu-move-layer-anime.scm
Frosty-logo.scm
Glossystroke3D.py
Sg-mirror-dup.scm
C:\Users\ADMIN\Documents\GIMP-PC_Lab.2_8_2-64bits-R6\GIMP-PC_Lab.2_8_2-64bits\PhotoComix\scripts\_Preinstalled\map-distort
Luminescence+ 2.6_01.scm
C:\Users\ADMIN\Documents\GIMP-PC_Lab.2_8_2-64bits-R6\GIMP-PC_Lab.2_8_2-64bits\PhotoComix\scripts\_Preinstalled\photo
Elsamuko-color-tint.scm
Elsamuko-grain.scm
Elsamuko-lomo.scm
Elsamuko-national-geographic.scm
Elsamuko-technicolor-3-color.scm
Fp-script-fu-grungy-photo.scm
Jp-polaroid.scm
Border_and_copyright_by_BlackTau_gimp_28.scm
C:\Users\ADMIN\Documents\GIMP-PC_Lab.2_8_2-64bits-R6\GIMP-PC_Lab.2_8_2-64bits\PhotoComix\scripts\_Preinstalled\utils
Patchsynth.scm
Resynth_along_path.scm
Sg-copy-mask-from-above.scm
Sg-scale-to-selection.scm
Resynthesizer.exe
C:\Users\ADMIN\Documents\GIMP-PC_Lab.2_8_2-64bits-R6\GIMP-PC_Lab.2_8_2-64bits\lib\gimp\2.0\plug-ins
Resynthesizer-gui.exe
Duplicate in PC LAB 32
Jhead.exe
C:\Users\ADMIN\Documents\GIMP-PC_Lab-2_8_2-32bits-rc3\GIMP-PC_Lab-2_8_2-32bits-rc3\lib\Jhead
Palette-sort.py
C:\Users\ADMIN\Documents\GIMP-PC_Lab-2_8_2-32bits-rc3\GIMP-PC_Lab-2_8_2-32bits-rc3\PhotoComix\plug-ins\_Preinstalled\python
Palette-to-gradient.py
Plugin-map-style.py
Plugin-render-texture.py
Resynthesizer.exe
C:\Users\ADMIN\Documents\GIMP-PC_Lab-2_8_2-32bits-rc3\GIMP-PC_Lab-2_8_2-32bits-rc3\PhotoComix\plug-ins\_Preinstalled\utils
Exif-browser.exe
Intelligum.exe
C:\Users\ADMIN\Documents\GIMP-PC_Lab-2_8_2-32bits-rc3\GIMP-PC_Lab-2_8_2-32bits-rc3\PhotoComix\scripts\_Preinstalled\layer
Border_and_copyright_BlackTau_Gimp_28.scm
C:\Users\ADMIN\Documents\GIMP-PC_Lab-2_8_2-32bits-rc3\GIMP-PC_Lab-2_8_2-32bits-rc3\PhotoComix\scripts\_Preinstalled\logo
Cshw-strblinking.scm
Frosty-logo.scm
Glossystroke3D.py
Shapegrid1_1.py
C:\Users\ADMIN\Documents\GIMP-PC_Lab-2_8_2-32bits-rc3\GIMP-PC_Lab-2_8_2-32bits-rc3\PhotoComix\scripts\_Preinstalled\render
C:\Users\ADMIN\Documents\GIMP-PC_Lab-2_8_2-32bits-rc3\GIMP-PC_Lab-2_8_2-32bits-rc3\PhotoComix\scripts\_Preinstalled\utils
ShellOut.py
PostPosted: Tue Jan 15, 2013 9:57 am  (#9)
Ohh :::thank for the help Steeno ! :yes
I will check the duplicate entry
@ Graechan
I did include all the plugins with revised gui from Onkel Hatti version , i would like to include also the selector tool but , as i explained in my first message i will need some help from Hatti or from Samj to do it
I found 2.9 very interesting but not sufficiently stable yet and i am not sure how will handle older plugin script
...also 16bit edit needs much more powerful computer then 8bit , even more in this beta phase were optimization is not done yet (except some from partha )
basically i fear may be delusive on not modern and powerful PC (as example in all 32bit OS)
i didn't test much 2.9 , but i saw that my 8GB ram are barely sufficient to edit very ,very slowly raw files
PostPosted: Tue Jan 15, 2013 5:36 pm  (#10)
Hello Photocomix,
I have compared the PC LAB 32 bit with the PC LAB 64 bit, and I have found several plugins / scripts missing in one but not in the other.
Maybe it is normal if some addons don't exist in 64 bit but I'm telling that is it preferable that you be aware. So I have compiled a list of missing plugins / scripts for each version based on the contents of 32 bit version and vice versa for the 64.
I hope this can help you ...
Plugins / Scripts missing in PC Lab 32 :
3dscript.scm
adaptive-edge.exe
aumask.exe
autosave_a.py
cartoonizer.exe
ColorDepth2Parallel.scm
colour-match.exe
colour2grey-local-0.1.exe
Comix Text Bubble.scm
dcamnoise2-0.64.exe
degrain.exe
dents_de_scie_2_8.scm
djvu.exe
ecomment.exe
elsamuko-national-geographic-batch.scm
elsamuko-temperature.exe
ev_iccii_photoeffects_246.scm
file-ora.py
filltrans.scm
focusblur.exe
fp-script-fu-grungy-photo.scm
freetype.exe
gimp-lqr-plugin.exe
gimp-plugin-toy.exe
gimp_plugin-refocus-it.exe
gluas.exe
guillotine_into_layers.exe
icc_colorspace.exe
Image_Subtraction.exe
intoolace.exe
lame.exe
lextract.exe
mathmap.exe
phymodmedia.exe
plug_in_lqr_iter.exe
poster.exe
saturate.exe
save layers with names.py
sg-align-down.scm
sg-anti-crop.scm
sg-photocomics.scm
simple-bilateral.exe
split.exe
streak.exe
uc-avi.exe
unsharp2-0.12.exe
wavelet-decompose.exe
wavelet-denoise.exe
wavelet-sharpen.exe
whirl-pinch.exe
wsurface.exe
yuv.exe
Plugins / Scripts missing in PC Lab 64 :
aquabutt-2.1.py
arclayer-0.3.py
autocrop-ac-layers.py
autocrop-linked-layers-0.1.py
b&p_glossy_btn_01.py
b&p_glossy_btn_02.py
b&p_simple_btn_01.py
b&p_spiro_1.2.py
b&p_vector_path_1.py
b&p_word_art_1.2.py
batch-descreen.py
batch-gimp-lqr.scm
bimp.exe
bloom.py
boundary-shrinker.exe
calendar-en.py
cdcasefier.py
CDlabel.py
Change-Themes.py
create-layer-mask-from.py
cross_process.py
DBorder.py
dbp.exe
elsamuko-escape-lines.scm
engrave.py
exif-browser.exe
export_as_svg-0.1.py
export_layers_pdf-0.2.py
Export_layer_names.py
ez-perspective.py
file-webp.exe
fil_current_pub_eng.scm
fp-hidden-watermark.scm
fractalizer.py
fuzzdots-0.0.py
gap_colormask.exe
gap_fire_pattern.exe
gap_movepath.exe
gap_vid_common_encoder.exe
gap_vid_enc_avi.exe
gap_vid_enc_ffmpeg.exe
gap_vid_enc_rawframes.exe
gap_vid_enc_singleframes.exe
gap_water_pattern.exe
gap_wr_color_balance.exe
gat_tools.py
gimp-drt.exe
gimp-plugin-interpolate.exe
gimpgpui2.exe
GIMPJPEGXRPlugin.exe
gimp_polka_dot.py
gimp_texture_generator_1_1.py
gimp_typewriter.py
glow1_0.py
GMIC-export_PNGs_with_L_Names.py
golden-spiral-0.0.py
GoldenRatio2.scm
hide.exe
idPhoto.scm
intelligum.exe
interleave-layers-0.3.py
kaleidosix.py
l2height-0.7.exe
lasm-gm-channel-extract.scm
libertyernie.py
luminance.py
magiceye.exe
molten-material_0.py
morph.exe
neon-path-0.1.py
new_distributed_guides.py
noise-generator.exe
ofNutz_Distress.py
paste-in-selection.py
path-arrow-heads-0.0.py
path-csv-0.0.py
path-dump-0.1.py
path-mirror-0.0.py
path-shift-0.1.py
path-spread-0.2.py
path-waves-0.2.py
PathRotator2.scm
PathSplit.scm
Path_selection_sum.scm
photo_mosaic.py
pixel-dot-grid.scm
plugin-gimpscripter.py
plugin-trace.py
Polygon.scm
PolyGonize_Path.scm
profile-map-0.0.py
ps-pat-load_1.exe
python_glossy_stroke_3d.py
rendertexture1_3.py
resize-match-dpi_0.scm
reverse-strokes-0.1.py
ribbon-path-0.1.py
Riot.exe
rotator.py
roys-max-local-contrast.scm
shapegrid.py
shapegrid1_1.py
sharpfeather.exe
smooth-path.exe
Spiral.scm
strdflash.scm
strflash.scm
tileably-shrink.exe
ufraw-batch.exe
unclose-path-0.1.py
VerticalText.py
voronoi-path.exe
voronoi.exe
waterpaint.py
win-bash.exe
PostPosted: Tue Jan 15, 2013 8:11 pm  (#11)
Thank a lot seems i have to do a lot of work to check all well
Weird that many GAP plugin seems missed , it is true that the 32bit version of gap was newer and it did include more effect and plugin , but i didn't expect be so many
i will check well the rest i fear that will took me some days
PostPosted: Fri Jan 18, 2013 9:57 am  (#12)
I think that the 64bit version is ready , i will try to upload this evening
Still time for last minute fix and changes so if you have any suggestions make it now
PostPosted: Fri Jan 18, 2013 5:48 pm  (#13)
Provide the source code.
PostPosted: Fri Jan 18, 2013 6:33 pm  (#14)
Sure,
till now was no any change in the source code (i would not consider 2 different default in the gimprc file a change , if we do was 1 change : a slighly modified gimprc file ) all other changes were at binary level consisting in additional addon in the (correspondent of the ) user folder
From now on i should include the change done by Onkel Hatti to the plugins gui, and 2 additional libraries 1 to allow export as swf and another for support more audio files (for animation soundtrack )
For the rest i carefully avoided any change to the original source code
From no
PostPosted: Wed Jan 30, 2013 10:07 am  (#15)
steeno wrote:
Photocomix,
Jhead.exe
Cartoonizer.exe
Sg-quantize.scm
Chalk_it_up_28.scm
Frosty-logo.scm
Glossystroke3D.py
Sg-mirror-dup.scm
Elsamuko-grain.scm
Elsamuko-lomo.scm
Jp-polaroid.scm
Patchsynth.scm
Resynthesizer.exe
Jhead.exe
Palette-sort.py
Plugin-map-style.py
Resynthesizer.exe
Exif-browser.exe
Intelligum.exe
Frosty-logo.scm
Glossystroke3D.py
Shapegrid1_1.py
ShellOut.py
I am checking again this list but i can't find the duplicates
I mean i see in most cases only 1 entry, where are the clones/duplicates ?
PostPosted: Thu Jan 31, 2013 5:24 pm  (#16)
Hi Photocomix,
I'm sorry to respond you with delay but I am currently busy with the renovation of the roof of my house renovation.
I can give you an example with the plugin cartoonizer.exe that I see twice in the folder
GIMP-PC_Lab.2_8_2-64bits-R6\GIMP-PC_Lab.2_8_2-64bits\PhotoComix\plug-ins\_Preinstalled\color-contrast
and also in the folder
It's the same result with the script Advancedtonemapping.scm that I see in the folder
GIMP-PC_Lab.2_8_2-64bits-R6\GIMP-PC_Lab.2_8_2-64bits\PhotoComix\scripts\_Preinstalled\artistic
I have found all duplicates after creating the file list contained in PC LAB, with the software adviced by Odin.
PostPosted: Thu Jan 31, 2013 6:38 pm  (#17)
Ah ok this helps a lot, now clean up is much easier
i may already give the list of changes
1) general clean up ( i.e removed duplicates add on )
2) All the gimp bundled in plugins are from Onkel Hatti version so all have a more polished gui, and all the group that had a microscopic preview (gimpressionist, lighting effect, map objects , fractal trace ,etc ) instead will offer a quite large preview
3) All additional resources (script ,plugin,pattern gradient... ) revised and updated
4) Detailed list of changes from the standard version , with credit and referral links
5) Some cool new addon
6) a introductory video
Not sure about
7) include Rggjan selection tool (as in Onkel Hatti build )
I would like but i may need some help from Samj and or Onkel Hatti to succeed, honestly i didn't try yet
8)
Installer
I would like provide not only a zipped version but also a win installer
I could not promise anything yet, but first experiments were quite promising (thanks also to Partha that helped with a script )
The point of the installer is no much to install ; in any case install is simple as extract the folder from the zip.
The point of a installer is that may offer options to create shortcut for start the program from a desktop icon and from All Program
and more in general to easier the first contact , assist in the initial set up
No promises on this yet but good chances
PostPosted: Fri Feb 01, 2013 5:30 am  (#18)
Thank you very much for this project.
This is the kind of initiative that can help beginners and convince to go on Gimp.
I uploaded the file that I used to list duplicates, it contains all the files from the PC LAB 64, I can not find where I put the PC LAB 32.
http://dl.free.fr/getfile.pl?file=/iMPNriQL
PostPosted: Fri Feb 01, 2013 8:45 am  (#19)
Thank a lot :jumpclap :hi5
In this moment i am working on the 64bit so i will need even more the other way round, a list of what is ONLY the 32 bit and not in the 64 bit
but thinking better maybe i just have to look some messages behind , i believe you already did
PostPosted: Fri Feb 01, 2013 10:22 am  (#20)
Yes I did, and you are lucky, I have found the 32 bit file in a business folder that I have just opened.
http://dl.free.fr/getfile.pl?file=/F0HH6yjN
