It is currently Sat Nov 07, 2026 2:27 pm
 Post subject: cartoonizer (cartooner-color-reducer)
PostPosted: Fri Mar 08, 2013 7:08 pm  (#1)
Bonjour
Binaries 32bit-64bit for Gimp Windows - version 0.8.5
http://code.google.com/p/cartooner-colo ... troduction
cartoonizer-0.8.5-win-32bits-64bits.zip [229.03 KiB]
Downloaded 2084 times
 Post subject: Re: cartoonizer (cartooner-color-reducer)
PostPosted: Sat May 18, 2013 1:56 pm  (#2)
I wish I could code, so I could make all of the scripts for mac and iPad. It would be awesome to be able to use a touch screen to work on gimp.
PostPosted: Sat May 18, 2013 8:06 pm  (#3)
Thanks Sam, i missed this one. :)
PostPosted: Sun May 19, 2013 1:13 am  (#4)
excellent plug-in, very flexible, you can play a lot with all parameters and get surprising results, thanks SamJ by all windows-users!
PostPosted: Tue Aug 20, 2013 2:15 am  (#5)
Thank you!
PostPosted: Tue Aug 20, 2013 7:08 am  (#6)
:tyspin
Compilation Win 32 : viewtopic.php?f=7&t=8222&p=107534#p107534
