It is currently Sat Nov 07, 2026 11:03 pm
 Post subject: Gimp plug-in for creating beautiful skies
PostPosted: Tue Mar 12, 2013 7:45 pm  (#1)
Bonjour,
Here's an old plug-in created by David A. Bartold that allows you to create beautiful skies and cloud animations.
:tyspin David A. Bartold
I updated this plugin.
The binaries are compiled for Linux and Windows, 32-bit and 64-bit.
Sky
Filters > Render > Clouds > Sky...
Filters > Render > Clouds > Sky Reset...
Filters > Animation > Clouds...
Foo
Filters > Misc > Media > Color Pencils...
Filters > Misc > Media > Texture...
Filters > Misc > Media > Thick Oil Paint
Edit 20130213
Add documentations
:tyspin anarkhya for the translation.
phymodmedia-0.5.2_Gimp-2.8_manual_EN-US.zip [620.7 KiB]
Downloaded 372 times
Documentation_fr_phymodmedia-0.5.2_Gimp-2.8.zip [824.34 KiB]
Downloaded 296 times
phymodmedia-0.5.2_32bits-64bits_Gimp-2.8_Linux_Windows.zip [859.97 KiB]
Downloaded 585 times
 Post subject: Re: Gimp plug-in for creating beautiful skies
PostPosted: Tue Mar 12, 2013 9:28 pm  (#2)
Wow very interesting plugin, ton's of options!
Thanks, samj :bigthup
PostPosted: Tue Mar 12, 2013 9:31 pm  (#3)
Sky
I downloaded the 32-bit Linux version. The only one that's available for me is Filters > Render > Sky
samj wrote:
Filters > Render > Clouds > Sky Reset... Not there
Filters > Animation > Clouds... Not there
Foo
Filters > Misc > Media > Color Pencils...This is grayed out
Filters > Misc > Media > Texture... This is grayed out
Filters > Misc > Media > Thick Oil Paint... This isn't there
It's fun to mess around with.
PostPosted: Tue Mar 12, 2013 9:50 pm  (#4)
I don't know why you don't have these,
Filters > Misc > Media > Color Pencils...(needs none transparency background)
Filters > Misc > Media > Texture...(needs none transparency background)
Filters > Misc > Media > Thick Oil Paint (needs a canvas and a few pixels)
PostPosted: Tue Mar 12, 2013 9:56 pm  (#5)
I downloaded the zip file one more time and re-installed it. Still no joy.
PostPosted: Tue Mar 12, 2013 10:05 pm  (#6)
Are you sure you have the 3 Misc | Media filters in scripts folder?
PostPosted: Tue Mar 12, 2013 10:17 pm  (#7)
Well duhhhhhhhhh, missed that entirely. Now most of it is working.
The colored pencils and textures are still grayed out in Misc > Media, everything else is available.
Thanks, Odin! :bigthup
PostPosted: Tue Mar 12, 2013 10:29 pm  (#8)
Thanks a heap samj; had this plugin when I was using 2.6 but didn't install it in 2.8; cool that you compiled it for 64-bit as well. Did tweak the clouds more to my liking (not still 100% but I didn't like the harsh result before). Not sure why the original program didn't have more tweaks for the clouds, but overall, I do like this plugin. :)
PostPosted: Tue Mar 12, 2013 10:42 pm  (#9)
Run the Sky... filter first and then the Reset Sky... and animate Sky.... menus should show.
PostPosted: Wed Mar 13, 2013 12:43 am  (#10)
Samj as your a very nice person would it be possible to get the documentation in English
PostPosted: Wed Mar 13, 2013 1:13 am  (#11)
for texture I did this and menu showed as available but when it came up and I selected OK nothing happened
PostPosted: Wed Mar 13, 2013 3:26 am  (#12)
As I get 404 from official site and registry remains silent with my keywords, Lyle, can you supply the one you had for 2.6 ?
PostPosted: Wed Mar 13, 2013 8:49 am  (#13)
Looks like one very useful plugin. Thank you for posting.
PostPosted: Wed Mar 13, 2013 9:03 am  (#14)
very cool filter...thank you samj
PostPosted: Wed Mar 13, 2013 9:12 am  (#15)
Here it is anarkhya; I'm can't be 100% sure but I believe samj's compile still should work in 2.6 though as well (she provides both 32-bit and 64-bit versions in the zip), but just in case, I've attached it here. :)
phymodmedia.7z [28.81 KiB]
Downloaded 149 times
PostPosted: Wed Mar 13, 2013 9:37 am  (#16)
Added Pan to Bow and Stars in the Sky scriptfu's to the mix for this waterworld. Yes, I made horizontal seamless as well. :)
PostPosted: Wed Mar 13, 2013 9:44 am  (#17)
Bonjour,
I added documentation in French at the beginning of this topic.
If someone wants to translate it into English, OO.o file format is included.
@anarkhya
I'm not sure of the proper functioning of older versions because I edit the source files in C language for animations.
PostPosted: Wed Mar 13, 2013 9:56 am  (#18)
Here it is
Got it, it started correctly, thanks !
PostPosted: Wed Mar 13, 2013 10:46 am  (#19)
If someone wants to translate it into English.
Done!
Downloaded 158 times
PostPosted: Wed Mar 13, 2013 10:50 am  (#20)
Bonjour,
:tyspin anarkhya :tyspin
I will place your archive at the beginning of the subject
Image abstraite utilisant Phymodmedia et G'MIC
cron
