It is currently Sat Nov 07, 2026 6:21 am
 Post subject: Photoshop Pattern Loader Plugin version 1.2
PostPosted: Sat Mar 16, 2013 7:53 am  (#1)
Bonjour,
This filter loads patterns of Adobe Photoshop(tm) PAT format.
By Eric Lamarque
Binaries 32bit-64bit Linux & Windows
This GIMP plug-in is designed to load Adobe Photoshop(tm) pattern set (.pat).
The complete set is loaded as a new RGB image, one pattern per layer.
Only grayscale, indexed and RGB pattern are currently handled.
Adobe and Adobe Photoshop are trademarks of Adobe Systems Incorporated that may be registered in certain jurisdictions.
ps-pat-load_1-20081104_32bits-64bits_Gimp-2.8_Linux_Windows.zip [86.26 KiB]
Downloaded 13036 times
 Post subject: Re: Photoshop Pattern Loader Plugin version 1.2
PostPosted: Mon May 06, 2013 4:01 pm  (#2)
Which version of Gimp is this compatible with? I use 2,6 :0
Ta
PostPosted: Mon May 06, 2013 4:11 pm  (#3)
Ta
Looks like Gimp-2.8 Deb. :)
PostPosted: Sat Jul 18, 2026 4:19 pm  (#4)
Still works in Gimp-2.10.38.
Just make sure you only use Photoshop-CS2 .pat files or you get an error.
Open Gimp
Download your .pat file
Now just drag it into Gimp. Images will open in separate layers for you to save each layer as a Gimp .pat file.
