It is currently Sat Nov 07, 2026 11:03 pm
 Post subject: Twist 2.1 (binaries 32-64bit Linux Windows)
PostPosted: Tue Mar 19, 2013 4:50 pm  (#1)
Bonjour,
Here is a new version of the plug-in "Twist" (version 2.1).
With this version 2.1 the plug-in can be called by a script (Script-Fu - Python Script).
Compilations 32-64bit are made for Linux and Windows.
Filters > Distorts > Twist
Script-Fu is added :
Filters > Distorts > Butterfly...
If you have any problems with the script-fu using the plugin "Twist", delete the file "pluginrc" and start Gimp.
Edit 20130323 : +3 scripts-fu
Edit 20130327 : +1 script-fu
twist-2.1_32bits-64bits_gimp-2.8_Linux_Windows.zip [269.73 KiB]
Downloaded 329 times
 Post subject: Re: Twist 2.1 (binaries 32-64bit Linux Windows)
PostPosted: Tue Mar 19, 2013 5:47 pm  (#2)
Thanks for the update samj; just used a preset from Twist along with Rotate Copy n-layer script-fu for this one that I posted at link below. :)
http://forums.dpreview.com/forums/post/51118153
PostPosted: Tue Mar 19, 2013 6:04 pm  (#3)
@Lylejk
This is a very good idea to make "flowers" with "Twist". I love the result :)
PostPosted: Wed Mar 20, 2013 12:53 am  (#4)
Prefer butterfly wings though samj. ;)
PostPosted: Wed Mar 20, 2013 2:29 am  (#5)
excellent job, samj!
In my ignorance I didn't know how complex could be to create an interface to an .exe plug-in.
I thought it could be possible simply (?) to extrapolate the registration lines and let the plug-in read a simple text file (a kind of "pluginrc_menu" file) where to find the menu path.
Thanks for your script!
(note for the poor windows users: if somebody wants to keep his/her pluginrc file because of some personal set-up in there, he/she could just edit the file and remove the few lines related to the old version of the plug-in before launching gimp with the new version, in order to avoid problems...)
PostPosted: Wed Mar 20, 2013 7:19 am  (#6)
Bonjour,
To play with the plug-in "Twist", here is another script to create "butterflies" from an image.
Script-Fu butterfly_2.scm (with "Twist" plug-in version 2.1)
Filters > Distorts > Butterfly Version 2...
butterfly_2.zip [2.58 KiB]
Downloaded 245 times
PostPosted: Wed Mar 20, 2013 7:25 am  (#7)
@Lylejk
I'm trying to create a script inspired from your tutorial.
PostPosted: Wed Mar 20, 2013 7:55 am  (#8)
cool samg...thanks
PostPosted: Wed Mar 20, 2013 8:43 am  (#9)
samj wrote:
Bonjour,
Wow; definitely a keep samj. Had to do a lot of fiddling to keep the antennae from getting clipped and finally figured out how. I resized the canvas (not the fill) to a larger size and centered the fill. I then did layer to image size (forgot to add that the layer has alpha channel) before running the script-fu. Of coarse, since you separated the antennae from the wings already, I changed the colors of them to my tastes. :)
PostPosted: Wed Mar 20, 2013 9:10 am  (#10)
Just discovered that you really don't have to do the layer to image size step after you resize the canvas; the Script-fu handles the rest which is cool. I wanted broader wings for this one. :)
PostPosted: Wed Mar 20, 2013 12:09 pm  (#11)
Merci beaucoup !
Votre travail est très impressionnant.
PostPosted: Wed Mar 20, 2013 1:10 pm  (#12)
Bonjour,
Thank you all :tyspin
I add a new script on this page:
viewtopic.php?f=23&t=2519
