It is currently Sat Nov 07, 2026 3:45 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2, 3  Next
 Post subject: Portable Version Gimp 2.8.6 64-bit Win SourceForge
PostPosted: Sat Jun 29, 2013 7:50 am  (#1)
Bonjour,
I prepared a 64-bit Windows portable version with many plug-ins and scripts.
It is based on the version compiled by Jernej Simoncic, a big thank you to him.
To install you need to unpack in the root of a hard drive or USB key.
Do not unpack into a directory with accented characters or contain spaces.
Download :
http://www.aljacom.com/~gmic/gimp_2_8_6 ... rtable.zip
To start Gimp in the language of your computer click \gimp_2_8_6-64bits-Sourceforge-Portable\GIMP.exe
Directory Organization
Preferences directory : \gimp_2_8_6-64bits-Sourceforge-Portable\Preferences
Script-Fu directory : \gimp_2_8_6-64bits-Sourceforge-Portable\Preferences\scripts
Plug-ins 64bit directory : \gimp_2_8_6-64bits-Sourceforge-Portable\Preferences\plug-ins
Plug-ins 32bit directory : \gimp_2_8_6-64bits-Sourceforge-Portable\Preferences\old-plug-ins
G'MIC filters : \gimp_2_8_6-64bits-Sourceforge-Portable\GMIC_Filters
Mathmap directory : \gimp_2_8_6-64bits-Sourceforge-Portable\Preferences\mathmap
Userfilter directory : \gimp_2_8_6-64bits-Sourceforge-Portable\Preferences\userfilter
Gluas : \gimp_2_8_6-64bits-Sourceforge-Portable\Preferences\exemples_programmes_gluas-0.1.20
Beautify :
\gimp_2_8_6-64bits-Sourceforge-Portable\Preferences\rip-border
\gimp_2_8_6-64bits-Sourceforge-Portable\Preferences\texture-border
Version 20130910
Add :
Deskew : Layer > Transform > Deskew
WEBP with DLL : Open/Export webp images
Update :
colorblur.exe
gmic-1.5.7.0
Version 20130724
Update Selective-color-blur version 0.5.0
Add gimp-plugin-morphop-1.0 : Filters > Generic > Morphological operators
(168 231 208 bytes) / MD5 : 1edde1421cb65af2993c426cac45654f
Update 20130717
PeriodicPaint
(168 187 211 bytes) / MD5 661c0b7862a67bf131fa7ec45545a5d2
Update 20130716
Add Toy
(168 183 133 bytes) / MD5 af9d0f279b153e455a1b87bb251fcd63
Update 20130715
Add :
Iterative Save
Iterated Function System (IFS)
(168 157 575 octets) / MD5 ffe38a989bdf80f369bea266ebccc0e2
Update 20130714
Add :
Rainbow Tonemapping
Thin Line
Stroke Path with Taper
Specular Difference
(168 108 582 octets) / MD5 a0b0fbc6c52463985d7e93f583a2f079
Update 20130713
G'MIC version 1.5.7.0 beta
(167 873 537 bytes) / MD5 ca05e6b241ab4a26df0bbf7cbefbe46d
Update 20130712
(167 854 487 bytes) / MD5 82b166bc8c1dfbc755d58c25a63899ac
Update 20130710
159 Mo (166 914 275 octets) / MD5 4719243063b3f771a42de61efe9c9efa
Add plug-in 64-bit Separate+
Update 20130708
158 Mb (166 607 453 bytes) / MD5 008470d81b64f0197231bb81b7cd2954
update Bimp 1.4 - 64 bits
Update 20130704 :
158 Mb (166 596 839 octets) - MD5 5645d4ecc7a8ebfd0e4dd62d1efe8749
Update 20130703
158 Mb (165 841 207 bytes) - MD5 b70e72742c2886f2edf9f9388cca5cd8
G'MIC Gimp 64bit version 1.5.6.1
Add Speedline 64bit : Filters > Render > Speedline...
Update 20130702 :
158 Mb (165 780 909 bytes) MD5 d40acdf35f76b5d88a557cc49052960b
ADD
plug-in 32 bits
GIMP NORMALMAP PLUGIN : Filtres > Mappage > Normalmap
Panorama Tools : Filtres > Panorama Tools > Nom du filtre
plug-in 64 bits
NASA/ESA PDS/EDR images
Gimpmask : Filtres > Misc > GIMP Mask...
Luce for GIMP : Filters > Light and Shadow > Luce...
Tategaki : Filters > Text > Tategaki...
Edit 20130630
Update archive - 156 Mb (163 749 869 bytes) - MD5 : e46ffbb464428ac555ac41c279e6a964
Version 20130629 : 155 Mb (163 196 654 bytes) MD5 : 8862f4845c055a34ab7397e9defaa2c3
 Post subject: Re: Portable Version Gimp 2.8.6 64-bit Win SourceForge
PostPosted: Sat Jun 29, 2013 7:59 am  (#2)
:tyspin
exactly was i was hoping to reinstall gimp and start tweaking it on my new laptop :yes
i lose y previous attempt in a crash but now at least i may test also with Win 8..
PostPosted: Sat Jun 29, 2013 10:24 am  (#3)
:tyspin for testing PhotoComix.
I personally use Windows 8 64-bit for a long time and there is no particular problem with Gimp.
PostPosted: Sat Jun 29, 2013 1:47 pm  (#4)
A little weirdness
open gimp, open 1 image, close the image without edit ...
...and also gimp close
PostPosted: Sat Jun 29, 2013 2:17 pm  (#5)
PhotoComix wrote:
A little weirdness
that's a new behavior of 2.8.6. You need to Ctrl-W now to close last image
PostPosted: Sun Jun 30, 2013 7:18 am  (#6)
Bonjour,
Update 20130702 : 158 Mb (165 780 909 bytes) MD5 d40acdf35f76b5d88a557cc49052960b
ADD
plug-in 32 bits
plug-in 64 bits
20130630 : Update archive
Modification file : Parametres_Gimp_Lang.ini
Add file : Filtres_Gimp_2.8_Win.pdf
New version : Bimp v1.3 / 64 bits
Add : Elsamuko Saturation / 64 bits
Plug-in : Colors > Components > Calc Saturation
Script-Fu : Colors > Naturalize
Add : file-mpo / 64 bits
MPO Multiple Picture Object is one of the stereo 3D image formats used in some of the 3D cameras.
PostPosted: Wed Jul 03, 2013 1:27 pm  (#7)
Till now everything fine
PostPosted: Wed Jul 03, 2013 5:50 pm  (#8)
:tyspin PhotoComix
The archive has been updated today, features are at the beginning of this thread.
PostPosted: Wed Jul 03, 2013 6:09 pm  (#9)
oh nice ,thank for the update :yes
PostPosted: Thu Jul 04, 2013 4:18 pm  (#10)
@Samj
gimp_2_8_6-64bits-Sourceforge-Portable\Preferences\ filters
what should contain that folder ? is maybe for UserFilter ? or for what ?
PostPosted: Thu Jul 04, 2013 5:56 pm  (#11)
@PhotoComix
That's right, but I do not have very interesting filters to put in :(
PostPosted: Thu Jul 04, 2013 6:17 pm  (#12)
i have a lot but select the most interesting would be a hell of a job
i have the whole collection
are more then 1.000 and often are a bit primitive :
As example there is 1 that make a nice yellow glow, and 1 a red glow,1 a green glove ,and so on and on
cool glow but alas none allow to change position of center of the glow,
... now we will expect 1 single filter that also makes a nice glow but with option to change colour and position and will cover all of them and more.
just a example ..
anyway i may upload my collection ...it is already online from long but i may found easier upload again then trace the link
now i know where place in gimp my userfilter filters without have to modifythe path ! thank Samj :tyspin
PostPosted: Sun Jul 07, 2013 4:59 pm  (#13)
@ Samj
not sure if you are interested, only a few to sort out are cool, but here my collection of Filter Factory Filter, converted in guf for UserFilter (thank to another friend from France , Francois Collard )
Are not 1000, but 1452
https://drive.google.com/folderview?id= ... Hc&usp=sha
PostPosted: Sun Jul 07, 2013 6:35 pm  (#14)
@Samj
sorry for the triple post :oops: !
But i just noticed that ,
1 )at least in the 64 bit version ...\Preferences \Tool presets is empty while i have a lot of files in a previous version
It is correct ?
i attach the files i have
tool-options.zip [11.95 KiB]
Downloaded 171 times
2) i had also a "gegl.exe" in bin that i don't see in your portable
just curious, i like much your portable
PostPosted: Sun Jul 07, 2013 7:17 pm  (#15)
:tyspin PhotoComix
I downloaded archives and I will test tomorrow (20130708) . I will give the results of these tests.
Edit : Can you provide an archive containing the corresponding filters (from this link) :
Do you use gegl.exe ?
PostPosted: Sun Jul 07, 2013 8:05 pm  (#16)
The original FF filters ? Sure , i had to search in my back up DVDs, i may upload tomorrow
It is not needed for the "gegl operations" ?
I don't use often except c2g and the "gegl" Kaleidoscope
PostPosted: Sun Jul 07, 2013 8:12 pm  (#17)
https://drive.google.com/folderview?id= ... JmbHc&usp=
Do you want the compiled version (.8bf) or the FF codes ?
PostPosted: Sun Jul 07, 2013 10:24 pm  (#18)
:yes Found all the codes of the original Filter Factory filters
allfilters.7z [226.58 KiB]
Downloaded 209 times
PostPosted: Mon Jul 08, 2013 5:52 am  (#19)
Again a triple post, sorry :oops:
But i noticed a few problems that i think better reports
1) apparently the quickmask button (on the lower left of imagine window ) disappeared
It was another way to call the quickmask, if i remember well from Tools/selection tools but also there no trace of quickmask
2) about Gegl :
with or without gegl.exe, it seems that gegl could not find any of his operations
the gegl operations are all in ...lib/gegl-0.2, maybe the folder is not properly linked ?
PostPosted: Mon Jul 08, 2013 5:57 am  (#20)
@PhotoComix
Today I'll update the archive after compiling the new version of Bimp.
I will make an announcement about Bimp.
Presets, Filters :
I will add the links in the "lisez-moi.txt" file in the archive.
People can download filters and "presets" and use them according to their taste.
Edit :
I have no problem with the quick mask is always in the same location :roll:
