It is currently Sun Nov 08, 2026 12:59 am
 Post subject: file mpo - Binaries Win 32-64 bits
PostPosted: Sun Jun 30, 2013 6:23 am  (#1)
Bonjour,
By Christian Steinruecken
This plug-in loads the MPO(Multiple Picture Object) file with its respective layers. MPO file is the raw 3D file format for many 3D cameras.
http://registry.gimp.org/node/28259
https://github.com/ksashikumar/file-mpo
Samples in the archive :
https://github.com/ksashikumar/file-mpo ... master.zip
file-mpo_32bits-64bits-Win.zip [44.62 KiB]
Downloaded 239 times
 Post subject: Re: file mpo - Binaries Win 32-64 bits
PostPosted: Sun Jun 30, 2013 6:27 am  (#2)
Sam how did you override the gimp_image_insert_layer call?
I couldn't get it to compile for me because of that undefined call.
EDIT: Oh maybe i need to update my GIMP lib dependencies? :)
PostPosted: Sun Jun 30, 2013 7:14 am  (#3)
@Rod
I did not do anything special to compile this plug-in, there was no compilation errors (I compiled in environments with gimp 2.8.0).
PostPosted: Sun Jun 30, 2013 7:41 am  (#4)
samj wrote:
@Rod
Yes i will have to re compile babl, gegl, and gimp-2.8 for windows. :) :bigthup
Thanks Sam.
