It is currently Sat Nov 07, 2026 2:23 pm
 Post subject: Speedline Plug-in
PostPosted: Tue Jul 02, 2013 8:13 am  (#1)
Bonjour,
By OHTSUKA Yoshio
Filters > Render > Speedline...
Site:
http://reddog.s35.xrea.com/wiki/GIMP%E3 ... 81%8B.html
Archive : speedline-0.1.1.samj-32bits-64bits-Win.zip
I changed the sources for the plug-in because it called functions Cairo that do not exist. The plug-in is recompiled for Windows.
speedline-0.1.1.samj-32bits-64bits-Win.zip [695.65 KiB]
Downloaded 465 times
 Post subject: Re: Speedline Plug-in
PostPosted: Tue Jul 02, 2013 10:16 am  (#2)
Thanks Sam. :)
PostPosted: Tue Jul 02, 2013 10:35 am  (#3)
nice, thanks samj!
PostPosted: Tue Jul 02, 2013 10:41 am  (#4)
Is there a way to get the Python plugin in English?
PostPosted: Tue Jul 02, 2013 2:54 pm  (#5)
Oregonian, Filters->Render->Line Nova... does almost the same effect. So, if this isn't working for you, you have a workaround...
PostPosted: Tue Jul 02, 2013 3:01 pm  (#6)
Thanks, kimppi, the line nova does a nice job. I just was wondering which one was the Python plugin on that website.
PostPosted: Tue Jul 02, 2013 7:00 pm  (#7)
@Oregonian
What is this plug-in Python? Do you have a link? :tyspin
(Plugins by this author are written in C).
