It is currently Sat Nov 07, 2026 12:04 pm
 Post subject: Gimp 2.8.6 Partha Build Released
PostPosted: Tue Jul 09, 2013 8:16 pm  (#1)
I have released Gimp 2.8.6 for Windows and Mac.
As, usual, plugins useful to photographers are include:
Ufraw from cvs (the very latest) fixes the issues on 64-bit Windows.
G'MIC 1.5.6.1
Akana's Save & Clean
Resynthesizer - version 1.0
Refocus-it
LAB Sharpen
David's Batch Processor
Alessandro Francesconi's BIMP
Exif-Browser
Wavelet-Denoise
Wavelet-Sharpen
Wavelet-Decompose
Fix Chromatic Aberration
Satequalizer - Saturation Equalizer
Advance unsharp mask
Separate+ - Color Management in Gimp
Advanced Tone Mapping - Faux HDR
Recover shadows and highlights
ShellOut
Liquid Scaling - Liquid Rescale
You can get it here www.partha.com
 Post subject: Re: Gimp 2.8.6 Partha Build Released
PostPosted: Tue Jul 09, 2013 8:37 pm  (#2)
No problems so far in windows 8 here Partha! besides the no default G'MIC but thats easily fixed
I'm back I think
PostPosted: Tue Jul 09, 2013 10:17 pm  (#3)
Tested your portable version win32 bit in Windows Vista 32 bit.
I got some errors Partha.
Most have to do with the libstdc++-6.dll file.
Gimp-2.8.6 does start and run fine after i close that no-disc error twice.
PostPosted: Tue Jul 09, 2013 10:58 pm  (#4)
The McGimp version works fine, so far no issues. Can't wait to play with the new G'MIC goodies.
PostPosted: Wed Jul 10, 2013 1:13 am  (#5)
Awesome....thanks sweetheart :)
PostPosted: Wed Jul 10, 2013 5:39 am  (#6)
Hey Willy! Good to see you again. :)
My upload must have gotten screwed up. Can you try again please?
Thanks!
Partha
PostPosted: Wed Jul 10, 2013 5:40 am  (#7)
I don't know what happened Rod. I have to investigate. :(
Sorry about that.
PostPosted: Wed Jul 10, 2013 8:43 am  (#8)
Sorry about that.
No biggy. :)
I await for the Gimp-2.8.6 build patiently. :bigthup
PostPosted: Wed Jul 10, 2013 9:07 am  (#9)
All works now Partha, before I didn't have your dark theme and maybe I was missing other features aswell. Works great on 64 bit Win8 :D
I'm back I think
PostPosted: Wed Jul 10, 2013 4:56 pm  (#10)
Sorry about that.
No biggy. :)
Thanks for your support Rod!
Somehow, my uploads totally screwed up. I am sorry about this. Would you be kind enough to download again and let me know if it works?
Thanks!
Partha
PostPosted: Thu Jul 11, 2013 3:26 pm  (#11)
Thanks!
Partha
Sure will! :)
Thank you sir.
Still getting that dll error ..... libstdc++6.dll file and libidn11.dll
PostPosted: Thu Jul 11, 2013 5:38 pm  (#12)
samj wrote:
Merci Partha :tyspin
For fun I did a mix of 32-bit and 64-bit versions.
The 32-bit plug-ins running on the 64-bit portable version.
This release includes a large number of plug-ins ...
This version requires a 64-bit Windows environment.
To install you need to unpack in the root of a hard drive or USB key.
Do not unpack into a directory with accented characters or contain spaces.
Download :
http://www.aljacom.com/~gmic/gimp-2.8.6 ... rtable.zip
(198 501 171 bytes)
To start Gimp in the language of your computer click \gimp-2.8.6_Partha_64-32bits_Portable\GIMP.exe
That's very cool Sylvie!!
Merci,
Partha
PostPosted: Thu Jul 11, 2013 5:41 pm  (#13)
Thanks!
Partha
Sure will! :)
Thank you sir.
Hey Rod,
Thanks for testing again! :)
But, now we are in weird territory. I uploaded new versions and have received reports that it's all working fine.
Can you email me the exact errors? I assume this is the 32-bit portable version?
Thanks,
Partha
PostPosted: Fri Jul 12, 2013 8:07 pm  (#14)
I had Partha 2.8.1 installed and uninstalled it through windows program files , installed new 2.8.6 (both were 64bit) .
Install worked fine and seemed to run good .
I was working on a old Xcf image and started working on it , all was good till I wanted to save . tried save, save as , export etc and got a error saying the path of image didn't have permission .
I rebooted and think that is ok but have another issue with file association , by accident I linked xcf to another program .
So i try the Open-with option . browse to gimp dir, pick gimp2.8.exe but it does not link it . It doesn't add gimp to list .
I don't see file association options in gimp .
Anyone know whats wrong , never had this problem before .
Edit: I think I fixed it .
I was trying to add the gimp-2.8.exe and I guess for some reason it doesn't like it but linking the gimp.exe worked and seems to run with it ok . not sure what the difference between them .
PostPosted: Fri Jul 12, 2013 8:45 pm  (#15)
Thanks!
Partha
Sure will! :)
Thank you sir.
Hey Rod,
Thanks,
Partha
Yes i am using the 32bit portable build. :)
I will email the screenshots for you. Basically they are the same as above though. Just the 2 dll files now though.
3 errors and then it starts fine.
No G'MIC, or Davids Batch Processor.
PostPosted: Fri Jul 12, 2013 9:22 pm  (#16)
Hi Ed,
There is no difference between gimp.exe and gimp-2.8.exe. gime.exe is there because on a Linux system (or Unix/Mac in general), you can softlink a file to another. Since there is no such thing as softlink on windows, gimp.exe is created as a copy of gimp-2.8.exe. So, you should not have any difficulty linking to gimp-2.8.exe or gimp.exe.
My guess is that in the past you associated gimp-2.8.exe (from 2.8.1) with your graphics/image files and those associations are still in your registry. So, remove all the old associations from the registry and you will be able to link to gimp-2.8.exe again.
Let me know if this does not work for you.
Thanks,
Partha
PostPosted: Fri Jul 12, 2013 10:00 pm  (#17)
Hi Ed,
Thanks,
Partha
Hi Partha .
I think I found all issues and will post .
The first one with file permission to saved was fixed by setting the gimp-2.8.exe to administration under properties , that fixed that .
Now with file associations , I ran Ccleaner and found old enteries to app open command with 2.8.1 .
so I uninstalled 2.8.6 and cleared all gimp entries to be sure .
then reinstalled and that cleared up problem of adding the gimp-2.8.exe to file association .
So all fixed now I think .
PostPosted: Fri Jul 12, 2013 10:25 pm  (#18)
Great! Good to hear. Let me know if you have any other issues.
Thanks,
Partha.
PostPosted: Fri Jul 12, 2013 10:41 pm  (#19)
2-ton,
Hope you have not had any issues with McGimp. Please let me know if it's all working OK for you.
Thanks,
Partha
PostPosted: Sat Jul 13, 2013 8:14 am  (#20)
Thanks,
Partha.
haven't put it through its paces (I use gimp now for photo work mainly masks, layers ,sharpening etc ).
will try few thing . I just tried to load few filters and GMIC and all seems to work .
One thing maybe you know . I use Rawtherapee as my Raw convertor as I like all options . I using version 4.0.11.8 .
They have option to open with gimp the image and seems like I get runtime error when I set path to gimp folder . I used to have this working with 2.6 but that was on XP and older Rawtherapee version . I think problem on there side but if you do use it does it work for you ?
Edit: since I see Ulraw in your gimp installer I guess you use that, so no biggy .
