It is currently Sat Nov 07, 2026 2:26 pm
 Post subject: Beautify Plugin needs a Home[solved thanks to Rod]
PostPosted: Tue Aug 27, 2013 9:11 pm  (#1)
The previous links to the 'beautify plugin' are dead, please contact if you are still hosting this plugin (maybe Samj or Rod) :tyspin
 Post subject: Re: Beautify Plugin needs a Home
PostPosted: Tue Aug 27, 2013 10:58 pm  (#2)
Yeah i have been meaning to upload these to MediaFire very soon Graechan. My hosting provider has gotten very kooky these days. :)
Sam may still have links to the 64 bit version also. I will get on this right away.
Thanks for reminding me. :bigthup
EDIT: I uploaded the new files here.
I will fix the original links also to reflect this.
The file needs to be unzipped and there are two folders inside.
They are named -
Place contents in the plugins folder
Place contents in the gimp-2.8 folder
border.zip is a separate file
https://backup.filesanywhere.com/fs/v.a ... 5f707bb49a
Couldn't be simpler than that. :)
LINK - https://backup.filesanywhere.com/fs/v.a ... 6676ac73a3
PostPosted: Wed Aug 28, 2013 2:15 am  (#3)
Thanks Rod I knew you would have solution
PostPosted: Wed Aug 28, 2013 6:58 am  (#4)
You are very welcome. Sorry for the inconvenience this may have caused anyone out there. :)
 Post subject: Re: Beautify Plugin needs a Home[solved thanks to Rod]
PostPosted: Wed Aug 28, 2013 2:14 pm  (#5)
you may upload also on "free Gimp packagers" at Sourceforge , just create first a "plugin" subolder to place it.
I may do, but Rod too should be able to access there .
PS
@Graecan would you like a space to present all your scripts ( and of course to download ) ?
Can't be easily arranged , i just have to create a "scripts" section
PostPosted: Wed Aug 28, 2013 7:56 pm  (#6)
PS
Thanks PC. I always seem to forget about the Free Gimp Packagers website. I will get everything together and start uploading there soon. :)
I only get 1 gig of room on this current server so i may as well switch it. :bigthup
PostPosted: Thu Aug 29, 2013 5:22 am  (#7)
Bonjour,
The plug-in "Beautify" is in the big archives "Sources_Plugins.7z" and "gimp_x_x_x-64bits-Sourceforge-Portable.zip".
These archives contain the sources and binaries compiled for Gimp Windows (often 64 bits).
These archives evolves over time according to my compilations.
Download links :
sources
http://www.aljacom.com/~gmic/Sources_Plugins.7z
binaries (in \Preferences\plug-ins and \Preferences\old-plug-ins )
http://www.aljacom.com/~gmic/gimp_2_8_6 ... rtable.zip
PostPosted: Thu Aug 29, 2013 7:22 am  (#8)
Hi,
I have downloaded the files in Rod's original message and hopefully followed his instructions correctly however when using this filter not all the textures seem to be available eg. when using the Rip Border option there is one tab called "Top" but the others textures in the folders like "art", "border" etc are not available for use. See attached screen dump.
Hopefully someone can tell me where I have gone wrong.
Regards,
Bob
PostPosted: Thu Aug 29, 2013 8:50 am  (#9)
Hi wirra. :)
Have you checked to make sure the three folders with textures are in the USERNAME/.gimp-2.8 folder?
If they are check to be sure they are not duplicated from the unzip.
For example, /.gimp-2.8/rip-border/rip-border/
Are all three like that? Tabs missing.
Please check inside the rip-border folder for all the sub folders.
Did you unzip the compressed zip and place the CONTENTS of each folder where they are supposed to go?
Please explain to me how you installed everything.
Please add a screenshot of your .gimp-2.8 folder contents.
PostPosted: Thu Aug 29, 2013 1:55 pm  (#10)
samj wrote:
Bonjour,
Download links :
sources
THANK YOU SAMJ - this is an invaluable source - deserves a new thread!
Sources_Plugins 2013-08-29
Date         Time           Bytes    File name
2013-03-11 16:10:29  -     69 283  adaptive-edge-32bits-64bits-gimp-2.8-win.7z
2013-06-15 18:03:15  -     84 070  aumask-0.9.2-Gimp-2.8_Win-32bits-64bits.zip
2013-03-11 17:45:41  -     98 456  bascii-32bits-64bits-gimp-2.8-win.7z
2013-02-13 20:36:36  - 45 280 610  Beautify.7z
2011-07-27 15:09:24  -  2 274 424  bilateral.tar_1-64bits.zip
2012-12-06 01:29:42  -     79 676  cartoonizer-0.8.0.tgz
2013-07-24 01:59:30  -     93 677  colorblur-0.5.0-32bits-64bits_gimp2.8.zip
2013-03-11 23:03:50  -     54 136  colour2grey-local-0.2-32bits-64bits-gimp-2.8-win.7z
2013-03-11 20:43:36  -     40 026  Colour_Match-32bits-64bits-gimp-2.8-win.7z
2013-02-12 22:06:28  -     10 782  Custom-Convolution-master.7z
2011-07-27 15:50:25  -  2 620 311  dbpSrc-1-1-9-64bits.zip
2013-07-04 10:50:16  -  3 230 083  djvu_plugin-32bits-64bits-Win.zip
2012-11-21 03:07:54  -      7 131  elsamuko-eaw-sharpen.tar.gz
2013-02-12 22:52:52  -      2 790  elsamuko-heatmap.7z
2013-02-13 23:13:11  -      2 712  elsamuko-hsv-analysis.7z
2013-06-30 01:33:00  -     50 550  elsamuko-saturation-Update1-32bits-64bits-Win.zip
2011-07-21 23:03:00  -    238 650  exif-browser-64bits.zip
2013-06-30 13:13:14  - 10 208 804  file-mpo_32bits-64bits-Win.7z
2013-03-16 15:39:24  -     54 665  fix-ca-3.0.2_32bits-64bits_Gimp-2.8-Win.7z
2013-02-13 22:43:58  -     14 535  fourier-0.4.2.7z
2013-07-06 14:41:44  - 20 306 442  gimp-2.8.6.tar.bz2
2013-03-09 22:28:48  -    783 903  gimp-dds-2.2.1-gimp-2.8-win-32bits-64bits.7z
2013-03-16 17:52:40  -    275 659  gimp-freetype-0.6_32bits-64bits_gimp-2.8-Win.7z
2013-02-12 16:28:01  -    271 081  gimp-image-reg-0.5.5.tar.gz
2013-07-01 14:19:04  -  1 750 404  gimp-normalmap-1.2.3-32-64bits-win.zip
2013-07-08 13:22:12  -  1 438 781  gimp-plugin-bimp-master-1.4-64bits_Win_Gimp-2.8.zip
2013-07-24 14:22:17  -    105 895  gimp-plugin-morphop-1.0-64bits-Win-Gimp-2.8.zip
2011-12-14 07:46:39  -    466 065  gimp-plugin-toy-1.0.4-32bits-64bits.zip
2013-03-10 16:09:38  -    890 586  gimp-plugin-userfilter-0.9.7-64bits.7z
2013-02-12 22:45:12  -      6 439  GIMP-raw-file-load-master.7z
2013-03-14 04:02:37  -    266 675  gimp-save-for-web-0.29.3b_32bits-64bits_gimp-2.8-win.7z
2013-07-01 13:47:33  -    128 104  gimpmask-32bits-64bits-Win.zip
2013-03-17 13:49:38  -    443 806  gluas-0.1.20-32bits-64bits.7z
2013-02-13 22:32:07  -     28 096  guillotine-into-layers-0.1.2.tar.gz
2011-12-14 07:36:29  -     35 036  IFS-64bits.zip
2011-12-14 07:36:31  -     15 758  IFS-i686.zip
2013-03-08 17:00:14  -    226 733  intelligum_32bits_64bits_Linux_Windows_gimp-2.8.7z
2011-12-14 08:00:33  -     44 921  iterative_save-64bits.zip
2013-03-16 23:25:40  -     54 415  kaleidoscope-0.10-2_32bits-64bits_gimp-2.8_Win.7z
2013-02-13 22:23:31  -     17 059  l2height.7z
2013-07-02 12:25:26  -    767 834  luce-2.0.0-32bits-64bits-Win.zip
2009-07-10 03:25:18  -    760 685  magie-0.3.tar.gz
2013-07-04 12:02:09  -     58 828  maze5-0.7-64bits-Win.zip
2013-03-17 16:48:23  -    403 822  noise-generator-0.2.5_poisson-noise-0.1b_32bits-64bits_gimp-2.8_Win.7z
2013-01-26 22:51:02  -  1 361 156  pcre-8.32.tar.bz2
2013-07-01 13:13:25  -    285 418  pds-2.4.116-32bits-64bits-Win.zip
2013-07-17 15:09:49  -  2 699 222  periodicpaint-0.2.032bits-64bits-Linux-Win_Gimp-2.8.7z
2013-03-13 02:34:38  -    752 063  phymodmedia-0.5.2_32bits-64bits_Gimp-2.8_Linux_Windows.7z
2013-03-15 20:44:24  -     80 296  plasma2-2.11_32bits-64bits_Gimp-2.8_Win.7z
2012-09-11 14:19:10  -    131 688  plugin_curveloader_v1.0.tar.gz
2013-03-16 14:47:18  -     68 061  ps-pat-load_1-20081104_32bits-64bits_Gimp-2.8_Linux_Windows.7z
2009-07-10 03:26:35  -    249 425  refocus-it-2.0.0.tar.gz
2013-03-09 21:41:58  -    259 691  resynthesizer_0.16c_bootchk_Gimp-2.8-Win-32bits-64bits.7z
2013-06-15 17:48:09  -     87 133  satequalizer-0.9.1-32bits-64bits-gimp-2.8-win.zip
2013-03-16 01:31:52  -     80 471  selfsom-1.1_32bits-64bits_Gimp-2.8_Win.7z
2011-07-09 01:23:51  -    771 536  separate+-0.5.9-alpha1-64bits.zip
2013-02-12 22:31:38  -      5 440  shadesofgrey-master.7z
2013-03-21 13:29:48  -    733 177  shapeit-v0.6-060619_32bits-64bits_Gimp-2.8-Win.7z
2013-03-17 00:42:34  -    190 302  smooth-path_32bits-64bits_gimp-2.8_Linux_Windows.7z
2011-12-14 08:04:07  -     34 336  specular_difference_plugin_4-32bits-64bits.zip
2013-07-02 15:03:27  -    712 345  speedline-0.1.1.samj-32bits-64bits-Win.zip
2013-02-12 21:51:52  -      4 567  streak.7z
2011-12-14 08:04:09  -    299 863  stroke-path-with-taper-1.0-64bits.zip
2013-07-02 11:08:52  -  1 169 998  tategaki-0.7.5-64bits-Win.zip
2012-08-26 15:00:05  -    115 002  textureops-0.3-win-32bits-64bits.zip
2013-07-14 13:18:11  -    271 733  thin_line-2.0-32bits-64bits.zip
2013-03-16 01:02:25  -    336 759  tileably-shrink-1.3_32bits-64bits_gimp-2.8_Win.7z
2011-12-14 08:05:11  -  1 450 449  tonemapping-0.2-32bits-64bits.zip
2013-03-16 02:03:03  -     75 571  turing-pattern-1.3_32bits-64bits_gimp-2.8_Win.7z
2013-03-27 12:23:07  -    203 906  twist-2.1_32bits-64bits_gimp-2.8_Linux_Windows.7z
2013-07-12 13:28:18  -  1 548 963  ufraw-0.19_64_Partha.zip
2013-03-16 22:23:47  -    105 950  upsize_0-32bits-64bits_gimp-2.8_Win.7z
2013-03-15 23:07:15  -    117 990  voronoi-2.2_32bits-64bits_gimp-2.8_win.7z
2013-03-17 14:49:16  -    153 994  wavelet-decompose-0.1.2_32bits-64bits_Gimp-2.8_Win.7z
2013-03-17 16:00:48  -    202 707  wavelet-denoise-0.3.1_32bits-64bits_gimp-2.8_Win.7z
2013-03-17 15:16:45  -    141 000  wavelet-sharpen-0.1.2_32bits-64bits_gimp-2.8_Win.7z
2013-03-15 02:10:38  -     69 270  waves-of-chaos-1.2_32bits-64bits_gimp-2.8-win.7z
2013-03-15 23:38:17  -     74 608  wsurface-2.1_32bits-64bits_Gimp-2.8_Win.7z
    Summary           108 906 488 = 78 Files
PostPosted: Thu Aug 29, 2013 4:37 pm  (#11)
Hi Rod,
Thanks very much for your reply. Having slept on the problem I have solved part of the problem. I have my user files and the majority of my Gimp plugins, scripts etc on my F drive. I have now moved the Beautify plugin files to my C drive user area (see attached). The texture folders now appear for the Rip Border and Texture Border options. The custom folder however does not appear for the Simple Border option (see attached). Would you know any reason for this? Also, is there a reason why the plugins don't work on my F drive when most other plugins do?
Once again thanks for your help.
Bob
PostPosted: Thu Aug 29, 2013 9:36 pm  (#12)
I do not believe that the custom folder works for simple-border. It wasn't added as of yet. :)
The reason they (the texture folders) do not work in F drive is because Gimp is looking for the GIMP 2 directory (.gimp-2.8) in the C:/USER folder.
The PATH environment variable is set for C not F. :)
You could try adding the value for the PATH variable like this at the end of the rest of the string.
F:/PATH TO YOUR /user/.gimp-2.8 folder.
That may work but i am not promising anything.
Alternatively you could add the path to Edit>Preferences>Folders>Patterns This will cause all the images to be added as patterns and you would open one as an image and edit it from there. They would not however be available from Beautify interface widgets.
Have you tried installing Beautify into an F drive gimp install (USER/.gimp-2.8/plugins folder)?
Then just run it once close it and place the texture folders in the .gimp-2.8 folder that should now be available/created. For the life of me i can not remember if Gimp will install that USER sub directory in F drive though.So you may be out of luck there.
