It is currently Sat Nov 07, 2026 3:06 pm
 Post subject: Small Windows compilation environment for Gimp 2.8 64-bit
PostPosted: Wed Sep 04, 2013 6:02 am  (#1)
Bonjour,
I think this is the first time we propose a compilation environment for 64-bit Gimp Windows.
In this environment it is possible to compile:
- Plug-ins for Gimp.
- BABL, GEGL, GIMP.
- G'MIC
- Libraries.
- Etc.
This environment uses the latest libraries (jpeg 9, glib ...), a compiled version of Gimp 2.8.6 and you can download the sources from GIT.
I propose the 64-bit environment from this link :
http://www.aljacom.com/~gimp/divers.html
The volume uncompressed is about 2 GB.
You need to unpack "petit-msys-mingw-64bits-gimp28.7z" in the directory C:\
The instructions are in the text "Readme_petit-msys-mingw-64bits-gimp28.txt" file.
This file contains examples of compilation.
This environment runs on Windows 64-bit versions. A part of this environment can be used in Linux for cross-compiling with mingw-w64 (not tested).
Files "C:\petit-msys-mingw-64bits-gimp28\msys\etc\fstab" and "C:\petit-msys-mingw-64bits-gimp28\msys\etc\profile" containing all the parameters of the installation.
I will give some examples when new plug-ins will be created.
 Post subject: Re: Small Windows compilation environment for Gimp 2.8 64-bit
PostPosted: Wed Sep 04, 2013 7:07 am  (#2)
any chance for a compilation environment for 32-bit Gimp Windows?
PostPosted: Wed Sep 04, 2013 7:22 am  (#3)
One already available here.
http://gimpchat.com/viewtopic.php?f=7&t=8222
PostPosted: Wed Sep 04, 2013 8:07 am  (#4)
:tyspin Oh thanks Samj
This time i want really try to compile
It is supposed to be used in a Virtual Machine?
PostPosted: Wed Sep 04, 2013 8:08 am  (#5)
I use it on my PC no virtual machine required.
PostPosted: Wed Sep 04, 2013 8:19 am  (#6)
OK i have installed a VM but i didn't used yet
Going to try today
PostPosted: Wed Sep 04, 2013 9:05 am  (#7)
Thanks, I will try to understand it and start using...
PostPosted: Wed Sep 04, 2013 12:56 pm  (#8)
Rod, I downloaded, unzipped and read the instructions, but I'm also lost because it seems (from the examples provided) that one has to input a series of complex commands (somehow tricky for a windows user) and I did not find a kind of "copy and paste" method, which maybe for many of you is simple and obvious, so I couldn't try even to simply repeat the compilation of vignetting...
PostPosted: Wed Sep 04, 2013 8:48 pm  (#9)
unzipped and read the instructions, but I'm also lost because it seems (from the examples provided) that one has to input a series of complex commands (somehow tricky for a windows user) and I did not find a kind of "copy and paste" method...
i didn't try yet but as for copy and paste the solution may simply be add shift
I mean instead than CTRL_C ; CTRL_SHIFT_C , to copy from console and CTRL_SHIFT_V to paste there
And if i remember well you may also use copy or paste from the mouse RIGHT click menu
PostPosted: Thu Sep 05, 2013 1:01 am  (#10)
thanks Pc, but - unfortunately - neither did work
PostPosted: Thu Sep 05, 2013 1:27 am  (#11)
I didn't try yet ,it may not work on the Windows console but i was thinking was the mingw console to show up that should accept that
PostPosted: Thu Sep 05, 2013 1:29 am  (#12)
http://gvsigce.sourceforge.net/wiki/ind ... _with_MSYS
See section "Issuing commands"
PostPosted: Thu Sep 05, 2013 5:43 am  (#13)
samj wrote:
http://gvsigce.sourceforge.net/wiki/index.php/Getting_started_with_MSYS
many thanks, Samj, excellent info!
first of all I learned how to "paste" into the console
then, going also through your many explanations on the previous subject concerning 32-bits environment- and especially the one related to "how to compile cartoonizer" - I succeeded in compiling both cartoonizer and vignetting (applying the same technique of creating a specific folder and adapting the makefile)
you are an angel
images/smilies/041.gif
edit: it seems I'm unable to insert correctly the smiley, anyhow it's the one clapping and jumping....!
PostPosted: Thu Sep 05, 2013 7:20 am  (#14)
@Dinasset
:jumpclap
If you are using the 32-bit environment, you can continue your discussions on : viewtopic.php?f=7&t=8222
:tyspin
PostPosted: Thu Sep 05, 2013 7:21 am  (#15)
Bonjour,
gmic_1.5.7.0_beta
For those who want to compile G'MIC beta 64-bit Win, I have attached an archive containing a Makefile.
The instructions are in the Makefile.
Edit 20130910
gmic_1.5.7.0 :
Makefile : http://www.aljacom.com/~gmic/Makefile_G ... 64bits.zip
DLL for G'MIC - Gimp : http://www.aljacom.com/~gmic/gmic_gimp_64bit.zip
PostPosted: Sun Sep 08, 2013 10:54 am  (#16)
Bonjour,
Compiling GAP (from GIT).
Open the MSYS terminal by clicking C:\petit-msys-mingw-64bits-gimp28\start_MSYS.bat
In the MSYS terminal typing the following lines. Press the "Enter" key at the end of each line :
cd /env
git clone git://git.gnome.org/gimp-gap
cd /env/gimp-gap
./autogen.sh --prefix=/mingw --build=x86_64-w64-mingw32 --disable-libavformat --disable-libmpeg3 --disable-libxvidcore --disable-audio-support-sdl --disable-audio-support-wavplay
make
make install
exit
Binaries are in "C:\petit-msys-mingw-64bits-gimp28\base\c\lib\gimp\2.0\plug-ins"
Start Gimp by clicking on the file : "C:\petit-msys-mingw-64bits-gimp28\start_Gimp-2.8.6-64bit.bat"
"Video" menu is available.
