It is currently Sat Nov 07, 2026 10:21 am
Post new topic Reply to topic  [ 58 posts ]  Go to page 1, 2, 3  Next
 Post subject: Gimp-2.8.8 released
PostPosted: Sun Nov 03, 2013 2:51 pm  (#1)
http://www.gimpusers.com/news/00489-gim ... -available
Only source for now.
Gerard.
Gimp-2.8.14
I use Linux only.
And Virtualbox with Win 7
 Post subject: Re: Gimp-2.8.8 released
PostPosted: Sun Nov 03, 2013 5:11 pm  (#2)
Looking good Gerard. Looks like they did some work with the cage tool, time will tell. thanks for sharing.
PostPosted: Sun Nov 03, 2013 5:31 pm  (#3)
You're welcome molly.
Gerard.
Gimp-2.8.14
I use Linux only.
PostPosted: Mon Nov 04, 2013 2:35 pm  (#4)
I use PClinuxOS, have done for a few years now. Same as Gentoo it is a 'rolling' release.
The maintainers there are on the ball today. A brand new Gimp 2.8.8
There is "oops I clicked on save instead of export".
The cage tool does seem a touch quicker or it might just be subjective.
So far everything working (had a little problem with a couple of plugins but all sorted)
PostPosted: Mon Nov 04, 2013 2:52 pm  (#5)
@rich2005,
Lucky you.
I could d/l the source and compile it myself but I'd rather wait until the Gentoo devs make it available.
Otherwise "portage" (Gentoo's package mangement) wouldn't be aware of it.
Gerard.
Gimp-2.8.14
I use Linux only.
PostPosted: Mon Nov 04, 2013 4:25 pm  (#6)
I have also wait till the make the Windows Version :) but this can only takes weeks. :)
Andrew
PostPosted: Mon Nov 04, 2013 5:27 pm  (#7)
Andrew
lolol
PostPosted: Tue Nov 05, 2013 6:32 am  (#8)
Gentoo now carries it too.
Late yesterday afternoon it was added to their repository.
Upgraded today.
Gerard.
Gimp-2.8.14
I use Linux only.
PostPosted: Tue Nov 05, 2013 6:41 am  (#9)
Not added to Fedora yet.
PostPosted: Tue Nov 05, 2013 7:13 am  (#10)
Hi all :gimp
For windows users:
WinGimp-2.8.8
For ubuntu users:
sudo add-apt-repository ppa:noobslab/ppa-gimp
sudo apt-get update
sudo apt-get install gimp
Bye
PostPosted: Tue Nov 05, 2013 9:55 am  (#11)
Installed GIMP 2.8.8 from ftp site. It launches fine, but during the launch, I get errors with libglib-2.0-0. Not sure the solution. Guess I will have to tolerate this until they fix it. :)
PostPosted: Tue Nov 05, 2013 11:26 am  (#12)
Hallo thank you I wounder only that Windows is found ftp://ftp.gimp.org/pub/gimp/v2.8/window ... -setup.exe and not form http://gimp-win.sourceforge.net/stable.html that address form I download as save Version. :)
Thank you Andrew
PostPosted: Tue Nov 05, 2013 11:59 am  (#13)
Thank you Andrew
The GIMP website explains why they are not using Sourceforge now: GIMP Windows Installers move from Sourceforge to ftp.gimp.org
PostPosted: Tue Nov 05, 2013 12:10 pm  (#14)
Hallo good to know I have now the German page I know say nothing about change.
thank you
Andrew
PostPosted: Tue Nov 05, 2013 1:48 pm  (#15)
As it's been a while i had not launched Gimp without plugins+scripts+brushes, i decided to count the loading time on my window version of 2.8.8.
I obtained roughly 37 seconds.
Then i launched my old portable version of 2.6.12 on which i had added the GPS brush pack and it loaded in 5 or 6 seconds.
Big difference.
After adding all my plugins/brush(much more than only GPS)/scripts, 2.8.8 loading time went up to 1 minute (at least i was expecting the increase there).
(it's not new to 2.8.8 , in 2.8.6 i noticed long loading time too, made worse by the rescanning of every single plugin everytime, something fortunately fixed and that was fixed in the 2.8.6 Partha version)
Has anyone noticed such big increase of loading time (5/6 seconds for 2.6.12 vs 37 seconds for default 2.8.8) since the 2.6.x era or is that just a win32 version of Gimp problem ?
PostPosted: Tue Nov 05, 2013 7:59 pm  (#16)
Below's what I posted at GIMPusers.
The problem turns out not with GIMP itself, but with the User Filter. Below are the errors. Maybe the User filter needs to be re-compiled. Sorry for not analyzing the errors earler (work weekend nights and last night was my Friday if you will and tired I was then and just installed the GIMP 2.8.8 before hitting the sack). Still not sure how the new version breaks the User Filter and I use this filter often enough that I hope there's a fix for it shortly. :)
http://imageshack.us/a/img109/9082/1l9o.png
http://imageshack.us/a/img203/2692/vkqe.png
http://imageshack.us/a/img713/8582/ow7t.png
PostPosted: Tue Nov 05, 2013 8:00 pm  (#17)
Just got the GIMP 2.8.8 update in Fedora.
Here are the changes from the official change log.
Overview of Changes from GIMP 2.8.6 to GIMP 2.8.8
Core:
- Make sure indexed images always have a colormap
- Fix language selection via preferences on Windows
- Don't crash on setting a large text size
GUI:
- Keep the same image active when switching between MWM and SWM
- Make sure all dockables are properly resizable (particularly shrinkable) (yay!!!)
- Add links to jump directly to Save/Export from the Export/Save file extension warning dialogs
Libgimp:
- Fix GimpPickButton on OSX
Plug-ins:
- Properly document plug-in-autocrop-layer's PDB interface
- Fix importing of indexed BMPs
General:
- Fix lots of places to use GIO to get proper file sizes and times on windows
- Add an AppData file for GIMP
- Backport lcms2 support from master, because lcms1 is not getting bug fixes any longer
- Lots of bug fixes
- Lots of translation updates
Looks great! :yes
Fedora 18 (and above) users can grab the new GIMP version from the updates-testing repository.
yum --enablerepo=updates-testing update gimp
PostPosted: Tue Nov 05, 2013 8:21 pm  (#18)
Just confirmed; removed path for User Filter (via GIMP interface for plugins) and all's well except, of course, the User Filter is no longer. Need to fix this. Maybe someone can recompile it or tell me how too; would be much appreciated. :)
PostPosted: Tue Nov 05, 2013 8:44 pm  (#19)
With all these errors, i'd rather wait for a fix.
PostPosted: Tue Nov 05, 2013 8:48 pm  (#20)
@Lylejk
If you already have a building environment to compile gimp and gmic it should be not too hard compile other gimp plugin
Bigger problem may be found what has to be corrected in the plugin code , why it works with the previous version but not anymore ,... and fix it
