It is currently Sat Nov 07, 2026 2:26 pm
 Post subject: New Gimp Win 32 - 20131101
PostPosted: Thu Nov 07, 2013 6:37 pm  (#1)
Bonjour,
I think there are problems with some versions of Gimp Windows 32-bit.
I offer a "blend" of the latest version of Gimp 2.8 32-bit Windows. This version may work better ...
Download link:
http://www.aljacom.com/~gmic/gimp-stabl ... ortable.7z
(74 055 366 bytes) / MD5 3be6fdf22a88f7e25c600dc8bd3360d4
This version should work from Vista.
Vista and +
- Start by clicking "\gimp-stable-i686-2013-11-07-Portable\GIMP.exe"
Windows XP
- Python is not portable. I advise to unzip the archive to C:\ and start GIMP by clicking "XP_GIMP.bat".
- In case of a problem click "XP_Initialization.bat".
- 5 launchers .exe give errors.
Tested on Win 8.1 pro 32-bit , Win 8.1 pro 64-bit , XP pro 32-bit
 Post subject: Re: New Gimp Win 32 - 20131101
PostPosted: Sun Nov 10, 2013 4:18 pm  (#2)
Hello Samj,
Thank a lot for your gift, I have downloaded your Gimp version 2.8.9.
I just encountered an issue during the first launch with some error messages regarding several plug-ins.
To correct it, I have duplicated the file libintl-8.dll in the folder gimp-stable-i686-2013-11-07-Portable\lib\gimp\2.0\plug-ins.
Maybe it's normal, I wanted to share it with you.
PostPosted: Sun Nov 10, 2013 5:01 pm  (#3)
Bonjour,
@Steeno
Thank you for testing and information :tyspin
PostPosted: Mon Nov 11, 2013 2:08 am  (#4)
I have also asked Partha to recompile GIMP-2.8.8 32 bit installer version for Windows.
Sam does your portable version fix the Refresh Scripts and Python pygimp.env bugs present in GIMP-2.8.8?
PostPosted: Mon Nov 11, 2013 5:23 am  (#5)
Bonjour,
@Rod
Everything works. You can also install this version on your hard drive without any problems.
On compilations of Gimp for Windows :
It's very sad but now nobody is able to correctly compile Gimp for Windows.
For proper operation it is necessary to assemble several versions.
PostPosted: Mon Nov 11, 2013 10:53 am  (#6)
Thank you Sam.
