It is currently Sat Nov 07, 2026 2:26 pm
 Post subject: Try to improve Gimp 2.8 Windows : file-aa.exe
PostPosted: Thu Nov 28, 2013 4:11 pm  (#1)
Bonjour,
This plugin allows you to export a small image formats .txt , .ansi
This plug-in is one of the sources of Gimp but is not often compiled.
Here are 2 versions for Gimp 2.8 Windows (32-bit and 64-bit).
Use:
Create a small image and export format .txt or .ansi
This image must be contrasted.
For html, change the extension after export : .txt to .html
This plugin is compatible with bascii.exe : Select .txt extension and select the plug-in to use.
Test :
http://www.aljacom.com/~gmic/clown.html
Download :
http://www.aljacom.com/~gmic/file-aa-AS ... -64bit.zip
(186 236 bytes)
 Post subject: Re: Try to improve Gimp 2.8 Windows : file-aa.exe
PostPosted: Fri Nov 29, 2013 5:32 pm  (#2)
:tyspin samj
PostPosted: Fri Nov 29, 2013 6:48 pm  (#3)
Bonjour,
Thank you Ollybit :)
I hope this plugin can evolve : colors, fonts, etc.
PostPosted: Sat Nov 30, 2013 7:46 am  (#4)
Thank you Sam. I hope they keep updating this plugin as well. :)
