It is currently Sat Nov 07, 2026 3:45 pm
 Post subject: Gimp 2.8.10 32-bit Win portable
PostPosted: Sun Dec 01, 2013 8:38 am  (#1)
Bonjour,
Download link:
http://www.aljacom.com/~gmic/gimp_2_8_1 ... ortable.7z
(136 094 923 bytes) - MD5 ff8011d86c41791df9af7adcc1ef05c7
This version should work from Vista.
Vista and +
- Start by clicking "\gimp_2_8_10-32bits-Portable\GIMP.exe"
Windows XP
- Python is not portable. I advise to unzip the archive to C:\ and start GIMP by clicking "XP_GIMP.bat".
- In case of a problem click "XP_Initialization.bat".
- 7 launchers .exe give errors.
Tested on Win 8.1 pro 32-bit , Win 8.1 pro 64-bit , XP pro 32-bit
Features of this version
Gimp 2.8.10:
- Compilation by Jernej Simoncic : ftp.gimp.org/pub/gimp/v2.8/windows
- Python 2.7.6 32-bit : www.python.org/download/releases/2.7.6/
- Libpng16-16.dll, libjpeg-9.dll, file-aa.exe, launchers, gmic, camotruck, compilations by samj
- pthreadGC2-w32.dll , libfftw3-3.dll and libstdc++-6.dll ( gimp_2_8_10-32bits-Portable\Preferences\plug-ins )
JPEG 2000
- Installation jp2.exe created by Divyanshu Vats and modified by adding a newer version of OpenJPEG 2011 (samj 20131201)
- Compilation of libturbojpeg-0.dll with libjpeg-62.dll for jasper tests
- Compilation of libjasper-1.dll with libjpeg-9
Manuals in CHM format are installed (English and French).
 Post subject: Re: Gimp 2.8.10 32-bit Win portable
PostPosted: Sun Dec 01, 2013 11:30 am  (#2)
Thank you samj!! I am downloading it now and will test it latter.
Any chance of a 64bit version?
Lyle, your off the hook now :)
PostPosted: Sun Dec 01, 2013 12:51 pm  (#3)
:tyspin Bilbo9955
Tests are underway for the 64-bit version. It may be ready tomorrow.
For now I am not satisfied with importing images in JPEG 2000 format.
Both plug-ins that I use (official and jp2) are not sufficiently "universal": They have a lot of problems... :(
PostPosted: Sun Dec 01, 2013 2:09 pm  (#4)
Don't use jp2, so that isn't a problem for me. Again, Thank You!!!
PostPosted: Sun Dec 01, 2013 6:52 pm  (#5)
Thanks Samj for the portable, are the CHM help files from help 8.1
PostPosted: Sun Dec 01, 2013 7:56 pm  (#6)
@Bilbo9955
Gimp 2.8.10 64-bit Windows Portable :
http://www.aljacom.com/~gmic/gimp_2_8_1 ... rtable.zip
(237 181 993 bytes) - MD5 03ddd68db20bf0c267d32e65cb4e955d
Edit 20131202 - Update
(237 773 684 bytes) - MD5 5428470befa539f9fa570f16ca4413a0
This version contains many plug-ins.
@Graechan
The manuals are installed in both versions (32 bit and 64 bit). Everything is pre-set.
PostPosted: Sun Dec 01, 2013 8:41 pm  (#7)
Both 32 ad 64bit potables are functioning fine
PostPosted: Mon Dec 02, 2013 8:07 am  (#8)
Thanks Samj!!
PostPosted: Mon Dec 02, 2013 11:33 am  (#9)
:tyspin
I made an update of the 64-bit version by adding separate+.
It is not necessary to download the entire archive, separate is available here :
viewtopic.php?f=7&t=6653&start=70#p118574
PostPosted: Mon Dec 02, 2013 1:31 pm  (#10)
Thanks, samj, for creating and sharing this portable version. :gimp
PostPosted: Mon Dec 02, 2013 3:50 pm  (#11)
Thanks samj!! works great.
PostPosted: Wed Dec 04, 2013 12:49 am  (#12)
Thanks Samj , i just installed now, yesterday my connection was too low and unstable
everything works fine and i like the help preinstalled
A question for that few standard plugins with the microscopic preview (gimpressionist, lighting effects,map object, fractal trace, small tiles...) ... do you think i may replace them with that from Onkel Hatty version?
I'm used to that hack giving bigger preview windows i found the preview of the normal version really too small to be of some utility
Also in general about the standard plugins , i like more Onkel Hatty version (for the others changes are no big but i found anyway the GUI more neat )
... and again the question is do you think i may just replace all standard plugins (with them of last onkel Hatty build )
PostPosted: Wed Dec 04, 2013 3:31 am  (#13)
@PhotoComix
It is not necessary to change the filters by Onkel Hatty.
I do not know if these filters comply with the GPL. Is Onkel Hatty provides sources?
To get good results, filters should be converted into GEGL.
PostPosted: Wed Dec 04, 2013 4:23 am  (#14)
I know is not necessary but i can't work with too little preview windows (as the standard for gimpressionist )
yes sure, it should be all here
http://sourceforge.net/projects/gimp-packagers/files/Onkel_Hatti/gimp-patches_Onkel_Hatti.zip/download
Yes , but nobody ,as far i known ported yet that group of filters to Gegl
Anyway the hack i am talking about it only modify the hardcoded size of the preview (for the few filters with a hardcoded and microscopic preview window ), and the position of the preview window in the filter UI (placing usually preview on top , sliders and control below )
Images explain better then words
please see here more examples
viewtopic.php?f=11&t=696&p=7155&hilit=bigger+preview#p7155
Those on the link were my own hacks, that of Hankel is more neat but based on similar concept : make the preview usable also to edit something bigger then post-stamp
Mind that even if i found very useful is a very simple hack that cannot break anything :
because doesn't change the filter code if not for the hardcoded value of preview window (when size is hardcoded)
PostPosted: Wed Dec 04, 2013 8:13 am  (#15)
@PhotoComix
I will compile with the changes to check the result.
In principle :
Original source file + Diff = Source file modified
The sources are one of the 2 parts of this equality.
PostPosted: Wed Dec 04, 2013 11:14 am  (#16)
samj wrote:
@PhotoComix
Yes, they do. They are small changes to the source. As a standard, the dialog boxes
provide a vertical box, I just changed it to horizontal.
Some previews are defined very small, I changed the define to bigger size.
Most of the previews can be enlarged by changing a value in gtkrc, but with a vertical dialog,
it is sometimes not usefull, the lower part of the dialog disappears on the screen.
I do not provide full source, but the complete patches of my changes are in the same directory,
where my unofficial version resides.
PostPosted: Wed Dec 04, 2013 12:43 pm  (#17)
Thank You for copyright versions of GIMP.
Yes, I think - the more sources - the better for the ordinary user.
However, selecting the best version - is not simple
Question to Samj and Onkell Hatti - you can make (own-author) version you are using (also with its own addon folder. Gimp-2.8)?
I've lost my resources because of a computer crash - download from one source (an expert like you) - it would be nice!
I think this is also a suggestion PhotoComix - from a single source is acknowledged to download the program and the best accessories.
PostPosted: Wed Dec 04, 2013 2:09 pm  (#18)
MareroQ
also Samj portable version has the equivalent of the user gimp addon folder, the only differences is that is called "preferences" instead then .gimp-2.8
About a best version i agree that is hard to chose ... as i wrote i would prefer a Samj version including Onkel Hatti tweaks (maybe even vice versa .. :mrgreen: )
PostPosted: Wed Dec 04, 2013 4:32 pm  (#19)
Bonjour,
I quickly looked at the changes created by Onkel Hatti. I'll try to apply the changes to the filters in the 2.8.10 version of gimp.org.
If the results are good, I will provide a new directory of "plug-ins" with maybe some DLL (we may not use the same environment).
I think doing that in the coming days.
PostPosted: Thu Dec 05, 2013 11:16 am  (#20)
:tyspin
