It is currently Tue Aug 11, 2026 5:47 pm
 Post subject: How to rotate canvas in gimp ?
PostPosted: Thu Mar 23, 2017 12:18 am  (#1)
GIMP Version: 2.8.16
Operating System: Linux
GIMP Experience: Basic Level
Ive been using krita for a very long time now to draw in , but im using gimp more and more, it was tedious and hard to learn at first but i got used to it in a few months and now i can do the basic things i wanna do in it now , except i can't rotate canvas ,i realize i need to be able to rotate the canvas in gimp whilst inking/sketching like how i can rotate paper when i draw in real life , or with every other art program i use, is their such a canvas rotation feature in gimp ?
 Post subject: Re: How to rotate canvas in gimp ?
PostPosted: Thu Mar 23, 2017 12:33 am  (#2)
Gingle, I have not seen anything to rotate the canvas but some of the more experienced will probably be along to address that. However, in the meantime, you can rotate the layer to whatever degree you want, either by transform under layers, or using the rotate tool in the toolbox.
PostPosted: Thu Mar 23, 2017 12:36 am  (#3)
Rotate the image.
Then use "fit canvas to layers"
Like this.
5624-close-up-portrait-of-a-beautiful-brunette-pv_rotated.png [ 1.9 MiB | Viewed 19546 times ]
note: the "white" you see around is really "transparent"
PostPosted: Thu Mar 23, 2017 2:35 am  (#4)
Not yet in 2.8. IIRC there could be one in 2.10 (the testing version is 2.9.x).
PostPosted: Thu Mar 23, 2017 4:54 am  (#5)
Your memory has not failed
@Gingle
It is worth trying out Gimp 2.9.5 It is quite usable these days and some nice features. I can not pretend to using the 'artistic' tools but they are there.
Shift-middle-mouse button to rotate the canvas.
Symmetry painting
Mypaint brushes.
Depends on your linux how easy it is to install. Ubuntu and derivatives, there is a ppa. There are also 'portable' versions 'appimages' that might work depending on distro.
This is my own appimage in Kubuntu 16.04. Allows me to use a regular Gimp 2.8.20 as well.
PostPosted: Thu Mar 23, 2017 5:40 am  (#6)
Just for myself, to understand:
- what is the benefit to rotate a canvas instead of rotating the image?
I ask because I can't figure it out (my fault).
PostPosted: Thu Mar 23, 2017 6:04 am  (#7)
The natural movement of your fingers holding a pencil has a 45% slant, so vertical and horizontals are hard to do. By turning the paper/canvas by 45% one of these directions become the natural ones.
Now, do we turn the canvas and the graphics tablet (turning the tablet alone could be a solution), or just the canvas?
PostPosted: Thu Mar 23, 2017 6:34 am  (#8)
Thanks Ofnuts, but I still don't understand (not what you say, which is the clear reason for turning, but the advantage of a "canvas" rotation).
Is it not the same if I draw on a rotated image?
PostPosted: Thu Mar 23, 2017 7:31 am  (#9)
Here it is just a User Interface operation (like a zoom) and the real data is not changed (when you zoom, the actual image data is not scaled). if you rotate the actual image data (twice) you will eventually get some visible blur.
PostPosted: Thu Mar 23, 2017 7:39 am  (#10)
OK, now it's clear, many thanks Ofnuts.
PostPosted: Sat Mar 25, 2017 11:12 am  (#11)
only the canvas turns, same goes in real life
PostPosted: Sat Mar 25, 2017 11:38 am  (#12)
@Gingle
Symmetry painting
Mypaint brushes.
i tried the other method in one of the first posts but thats actual transforming and takes15 seconds just to rotate and sometimes it crashes gimp and thats not what i wanted, This method is the best way though this doesnt work for me in 2.8 , but it does work in the 2.9 appimage, the only problem is that it looks really bad and out of place like a blocky windows 98 look with bad contrast , it doesn't take on theming like 2.8
and my os is gecko linux gnome. also Is there a way to reply to someone without having to quote them? It takes up so much space on the forum when you have to keep quoting people in order to reply to a specific person, i dont see a simple reply button like on other forums
PostPosted: Sun Mar 26, 2017 4:26 pm  (#13)
There is a "Quick Reply" button at the bottom of the page, that lets you add a post without answering anyone in particular. But if you quote a specific post(*) you can always edit the quote and pare it down to the part you are replying to.
(*) ) Nothing worse than a "Thanks it works!" reply that doesn't quote any of the 5 possible solutions expounded above it.
PostPosted: Fri Jul 18, 2025 6:30 pm  (#14)
Rotating / tilting the canvas worked, but weirdly, all tools also rotated.
(Gimp 3.0.4)
I need to select several rectangular objects, that are on an angle on the picture. Therefor, I expect the selection tools, guide lines, ... to keep working horizontal.
Also, I expected horizontal / vertical guides, to help me find the correct tilt angle, according to the skewed objects.
How does it work as expected?
PostPosted: Sat Jul 19, 2025 9:53 am  (#15)
(Gimp 3.0.4)
Yes, because the rotation is just a display nicety for the user (mostly for people hand-drawing using a stylus), the core code of Gimp doesn't see it. Other solution: create a rectangle selection and scale/rotate/move it with the Unified Transform (in "Transform: Selection", mode), or create a polygon selection using the FreeHand tool.
