It is currently Fri Nov 20, 2026 9:47 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2, 3  Next
 Post subject: 8bf filters
PostPosted: Mon Mar 15, 2021 10:53 am  (#1)
GIMP Version: 2.8.14
Operating System: Windows
GIMP Experience: Experienced User
I have pspi. file installed again
That's why I'm also looking for 8bf filters ... does anyone know a free site?
 Post subject: Re: 8bf filters
PostPosted: Mon Mar 15, 2021 11:51 am  (#2)
https://www.thepluginsite.com/
There are lots of links, both to plug-ins for fee, and for free.
Just have a look (browse).
PostPosted: Mon Mar 15, 2021 12:13 pm  (#3)
I sent you a PM with the link of my dopbox. I have a few and they all work :yes
PostPosted: Mon Mar 15, 2021 2:03 pm  (#4)
We have links here to some 8bf filters:
viewtopic.php?f=9&t=18452
PostPosted: Tue Mar 16, 2021 4:00 am  (#5)
Thank you!
PostPosted: Tue Mar 16, 2021 9:33 pm  (#6)
I always edit the pspirc file to keep all my PhotoShop filters in the one easy-to-find location
Where to find your pspirc file 'It's below your plugins folder'
Open the file in a text editor and change the menu path of each filter from Filters/ to PhotoShop/
Your edited pspirc file looks a little like this
PostPosted: Wed Mar 17, 2021 5:04 pm  (#7)
Here's the Ulead filter. It's not free but here it is anyway: viewtopic.php?f=9&t=10029
Hopefully a coder can translate this to gimp so that it works on 32 but and 64 bit.
PostPosted: Wed Aug 23, 2023 4:51 am  (#8)
Graechan wrote:
I always edit the pspirc file to keep all my PhotoShop filters in the one easy to find location
Explain to me what you mean by pspirc file? How can I recreate your same menu? Thank you
PostPosted: Fri Aug 25, 2023 10:21 am  (#9)
Hi, I may seem silly to ask you this question. How do I link the help menu directly to photoshop plugins by deleting this weird "p"?
Thank you...
PostPosted: Fri Aug 25, 2023 11:59 am  (#10)
@Vitforlinux
A small number of 8bf plugins are available in Linux via UserFilter.
UserFilter 64 bit plugin for Linux:
viewtopic.php?f=8&t=18255&p=249991&hilit=UserFilter#p249975
Collection 2376 filters:
https://www.gimpscripts.net/2020/10/use ... 64bit.html
@Kamolis68+
There is little that can be done.
This is a side effect of editing the pspirc file.
However, when you replace "Filters" with 7 character text (I use "PSPI8bf") About Photoshop plug-ins will display correctly.
PostPosted: Sat Aug 26, 2023 2:44 am  (#11)
Hello thank you. Another thing it seems that in the Freebies Folder the Solidify C file doesn't work as it generates an error in the Gimp startup phase. Is there a fix? Thanks again
PostPosted: Sat Aug 26, 2023 2:50 am  (#12)
Here is the error...
PostPosted: Sat Aug 26, 2023 4:16 am  (#13)
Unfortunately - it's a case (quite common) that this won't work.
From message (Solidify A to F) requires transparency:
GIMP works with selection and transparency differently than Photoshop.
PostPosted: Sat Aug 26, 2023 6:34 am  (#14)
vitforlinux wrote:
Too bad .8bf files don't work on Linux, they would have been another toy to try.
There was a pspi plugin for linux but it was 32 bit. I last used it years ago with a PClinuxOS installation.
As well as userfilter, which uses converted .8bf PS plugins, another way is using Windows XnView which generally accepts the same old .8bf as pspi.
It is a real "cludge", using the shellout.py plugin and WINE to run that XnView ( a 32 bit version)
This using kubuntu 22.04 / Gimp 2.10.34 / Tasmanias Gimp launcher to add python support.
Then it might go like this https://i.imgur.com/H4IXjAp.mp4
PostPosted: Sat Aug 26, 2023 7:26 am  (#15)
Yes, you are right about transparency. However the error is specific to Solidify C so that its entry does not appear in the menu.
PostPosted: Sat Aug 26, 2023 1:49 pm  (#16)
Why are you so interested in a plugin that won't work?
These files need to be removed:
Solidify A-150 32bit.8bf
Solidify B-150 32bit.8bf
Solidify C-150 32bit.8bf
Solidify D-150 32bit.8bf
Solidify E-150 32bit.8bf
Solidify F-150 32bit.8bf
However, the menu entry can be fixed for the "no entrypoint" case.
If you open the pspirc file in Notepad++ and search for Solidify C-150 32bit.8bf, you will notice that one line of code is missing (compare, for example, with Solidify A-150 32bit.8bf).
By typing the right line, you can fix it - and that's how the famous Impressionist.8bf is fixed (there is a thread on this forum about it).
PostPosted: Sat Aug 26, 2023 2:17 pm  (#17)
Well if as you say they are not helpful I delete them all and the game is done. Forgive me but I thought they were correctable errors and that they were useful. Thanks for your valuable information. :)
PostPosted: Sat Aug 26, 2023 10:01 pm  (#18)
As others mentioned, sometimes you have to use a surrogate program like XNView to run 8bfs since it's more compatible with them than the GIMP. Also, Irfanview is even better and when I was toying with Ubuntu (via Virtualbox), Irfanview worked perfectly fine thanks to WINE. One of the best ways to do this is use shellout (python plugin as I recall). Use shellout quite often since I really like Inkscape bitmap filters (and wish they would port them to GIMP but no one has). Also, of course, use it to execute 8bfs within both XNView and Irfanview. :)
PostPosted: Mon Aug 28, 2023 10:58 am  (#19)
Hi, I state that the plugin (Xenofex) in question works. Is there a way to prevent these error messages on startup? Maybe in the Gimp settings? Thank you
PostPosted: Mon Aug 28, 2023 12:59 pm  (#20)
I have xenofex 1.1 /2.0 and it works fine...
follow this!
http://photofiltre.papy35.free.fr/02pre ... nofex2.htm
