It is currently Mon Aug 10, 2026 1:49 am
 Post subject: Gimp 3 Plug-in Installation - RESOLVED
PostPosted: Mon Mar 24, 2025 6:04 pm  (#1)
GIMP Version: 3.0.0-1
Operating System: Windows
GIMP Experience: Experienced User
Contrary to my initial decision to wait on GIMP 3, I have now downloaded it and will slowly configure it to work with all the plug-ins I have accumulated over many years.
But at the first step I have encountered problems as identified below. I would appreciate some counsel on my actions, which were as follows.
I checked the Preferences for the target plug-ins folders:
I copied a bunch of ofnuts plug-ins, dealing with layers, paths and his 'addoncollection' manager and pasted them into: Users\Tony\AppData\Roaming\GIMP\3.0\plug-ins
I open GIMP 3 and those plug-ins are nowhere to be seen.
EDIT - well I have now downloaded the ZIP archive for GMIC QT and put the folder into the same plug-in location as identified above. Open GIMP 3 and GMIC QT appears in the filters menu. It's all got me beat! :?
 Post subject: Re: Gimp 3 Plug-in Installation
PostPosted: Mon Mar 24, 2025 7:30 pm  (#2)
Typically you cannot use gimp 2 plugins in gimp 3.
To start, Ofnuts' Gimp 3.0 Tools are here:
https://sourceforge.net/projects/gimp3- ... s/general/
If you scroll down the page there are installation instructions.
It explains the directory structure to use.
PostPosted: Mon Mar 24, 2025 7:34 pm  (#3)
Thanks Teapot - suppose I should have known that. Old age again :hehe
 Post subject: Re: Gimp 3 Plug-in Installation - RESOLVED
PostPosted: Tue Mar 25, 2025 12:37 am  (#4)
Many scm that depend on python or filters that are now ported to GEGL are no longer functional. For instance my Embroider Stitcher scm plug-in no longer works with Noise>Spread. :(
My Chisled Steel effect scm plugin depended on LayerFx-210.py and no longer works.
Have to rewrite with some different filters i guess. :)
I am working on getting a few of mine working in Gimp-3.0 now.
I'm not sure how to use GEGL filters in my scripts though because nothing shows in the PDB.
(procedure browser)
PostPosted: Tue Mar 25, 2025 3:42 am  (#5)
Some examples for how to handle GEGL filters are here
https://gitlab.gnome.org/GNOME/gimp/-/m ... uests/2008
Maybe that helps a bit
PostPosted: Tue Mar 25, 2025 3:00 pm  (#6)
also:
https://www.reddit.com/r/GIMP/comments/ ... are_button
PostPosted: Wed Mar 26, 2025 12:09 am  (#7)
Thanks quietreader. ;)
PostPosted: Wed Mar 26, 2025 12:56 am  (#8)
So in scm it would be written something like this?
#!/usr/bin/env gimp-script-fu-interpreter-3.0
(define (script-fu-embroidery-stitcher image drawable contrast)
  (gimp-context-push)
  (gimp-image-undo-group-start image)
              (let* ((emlayer (car (gimp-layer-new-from-visible image image "Embroided layer"))))
                  ;copy the image to a new layer and name it
                (gimp-image-insert-layer image emlayer 0 0)
;Get the first layer of the first image
(gimp-get-images 0)
(image-get-layers 0)
;Create filter
(gimp-drawable-filter-new RUN-NONINTERACTIVE emlayer gegl-noise spread)
;Set properties
(filter-config-set-property ("horizontal"  7))
(filter-config-set-property ("vertical" 7))
;Apply filter
(layer-merge-filter (filter))
;rest of code here
Or perhaps it is time to learn python. :)
cron
