It is currently Sun Aug 09, 2026 7:48 am
 Post subject: plugin "Change menu & icons.py"
PostPosted: Tue May 06, 2025 1:45 pm  (#1)
GIMP Version: 3.0.clang
Operating System: Windows
GIMP Experience: New User
:wvy
I use the plugin "Change menu & icons.py" without any problem in several versions of Gimp but in the portable version of samj "Gimp_3.0.2_Portable_clang", the plugin does not appear in the Menu/Windows nor with Help/Search and Run a command.
 Post subject: Re: plugin "Change menu & icons.py"
PostPosted: Wed May 07, 2025 12:32 am  (#2)
Is the python filter written for 3.0?
PostPosted: Wed May 07, 2025 1:09 am  (#3)
Plug-ins for GIMP 2.10 don't work in GIMP 3.x.
PostPosted: Wed May 07, 2025 2:04 am  (#4)
Gimp 3.0
As previous posts, your Gimp 2.10 scripts and plugins do not work.
For this one in particular, you can get the same from Gimp 3.0 Edit -> Preferences -> Interface -> Theme
before - after screenshots
Make sure you tick that "Override icon sizes set by the theme"
PostPosted: Mon May 12, 2025 11:23 am  (#5)
Thanks rich2005 :hugme
