It is currently Sun Aug 09, 2026 7:48 am
 Post subject: What GIMP Features Can Be Utilised?
PostPosted: Fri Jun 06, 2025 5:04 am  (#1)
GIMP Version: 2.8.14
Operating System: Windows
GIMP Experience: New User
I create resident evil based 3D renders using DAZ Studio. I'm wondering is there a GIMP feature/adjustment that create the haze or the effect that the games filtering layer seems to incorporate in pictures of in-game play from RE2 & RE3 remakes?
My render is: Jilleon-Gas-Station-Test-3. The others are the ones that have the "haze".
 Post subject: Re: What GIMP Feature Can Be Utilised?
PostPosted: Fri Jun 06, 2025 12:29 pm  (#2)
I used Differences Clouds to produce this effect.
Jilleon-Gas-Station-Test-3-Con40-High40_wallace.jpg [ 1014.51 KiB | Viewed 20495 times ]
PostPosted: Fri Jun 06, 2025 1:02 pm  (#3)
I am familiar with DAZ but back when I was doing 3 models using google's sketchup I would create fake fog that looked convincing by creating multiple copies of white or light gray transparent planes
so I asked ChatGPT:
Daz studio can you render haze by creating multiple layers of somewhat transparent white
ChatGPT said:
Yes, you can create haze in Daz Studio by layering multiple slightly transparent white surfaces or planes — this is a simple and effective trick when you're not using volumetric fog.
If you do it with GIMP it won't look convincing since GIMP is 2D unless you take the time to paint manually. With multiple somewhat transparent planes however you'll get really convincing because further objects will be behind more somewhat transparent planes than closer objects.
When you successfully create haze or fog in DAZ, please share results I'd love to see it.
TinT
PostPosted: Fri Jun 06, 2025 10:16 pm  (#4)
Yeah, sort of. Can it be a full layer that covers the entire image, not patches?
PostPosted: Sat Jun 07, 2025 4:15 pm  (#5)
Created a depth map in DAZ Studio. How is it brightened up and applied to the render using GIMP?
PostPosted: Sat Jun 07, 2025 9:50 pm  (#6)
Here's what I did with that "depth map".
File comment: Example Curves
PostPosted: Tue Jun 10, 2025 1:32 am  (#7)
The attachment Screenshot (2690).png is no longer available
I gave it a go. The "greyish" layer does not go over the characters which is what I want.
PostPosted: Tue Jun 10, 2025 4:03 am  (#8)
If you don't want patches and have the haze over the whole picture. Just add a white layer and reduce the opacity until you get it as you like. Maybe down to 5
Or you could use 'simplex noise' Scale 4. Iterations 2. Random 0. Mode addition. Opacity 10 or less. Depends if you want smoke or fog.
You could also use GMIC and use the clouds there, taking the density and smoothness to the far right. Have the output as a new layer and bring the opacity down on that and use addition mode
PostPosted: Thu Jun 19, 2025 8:42 am  (#9)
I've been playing around with various adjustments with GIMP, Depth Maps and Fog. I found a few Fog effects in the DAZ Shop. Also a one of the posters that also create environments shared a Fog effect zip. I ended up using one I found from the shop for the gas station exterior view and the one for the close up. Best I could do using these Fog effects.
What are your opinions?
PostPosted: Thu Jun 19, 2025 11:36 am  (#10)
I believe you've achieved the overall look.
Minus perhaps a few lighting tweaks,
that might add more depth to a night scene containing prominent or obvious lighting.
File comment: Lighting tweaks added.
bloody-footprints-mizoil-gas-station-1st-meet-0-by-thenic123-djyzd1n_wallace_1.png [ 8.16 MiB | Viewed 1194 times ]
Below is the lighting layer used to demonstrate these possible lighting tweaks.
File comment: Lighting layer with layer mode set to addition.
bloody-footprints-mizoil-gas-station-1st-meet-0-by-thenic123-djyzd1n_wallace_Lighting.png
bloody-footprints-mizoil-gas-station-1st-meet-0-by-thenic123-djyzd1n_wallace_Lighting.png [ 1.65 MiB | Viewed 1194 times ]
Here is the xcf file that will show the breakdown of the isolated lighting layers.
File comment: xcf file showing the isolated lighting layers
bloody-footprints-mizoil-gas-station-1st-meet-0-by-thenic123-djyzd1n_wallace.xcf [49.24 MiB]
Downloaded 24 times
PostPosted: Thu Jun 19, 2025 3:56 pm  (#11)
the fog effect look good but I really like what Wallace did with lighting of the car beams...really cool
TinT
PostPosted: Fri Jun 20, 2025 7:20 am  (#12)
@Wallace
All I can say is Wow!
I opened the file you shared and looked at each layer. I had a look in the Layer menu but couldn't find a "Lighting" option. I noticed each numbered "Visible" and 'Layer' had a different opacity but not the two without numbers?
I would like to learn. Can I kindly ask what the specific process of making each isolated layer is made and how the final image is saved, Please?
I might sound nit picky. Is there a way to make the beam of light wider from this emissive light where the yellow are spaced if possible?
I think it's called soft light which is either side of the main beam?
I not sure about the angles and blending of light. Can the beams of light from the jeeps upper four lights be joined to form more of a solid beams?
PostPosted: Fri Jun 20, 2025 8:44 am  (#13)
I used the "Luce plugin" to create the beams of light on each isolated lighting layer.
I duplicated the original layer and used Grain Extract then Color Curves to pick out the bright spots.
Then did New From Visible,
which gave me the bright points to begin isolating and running the Luce Plugin.
You can isolate the lighting elements however you like,
onto there own black filled layers.
Then run Luce on each layer to create the beams of light you desire.
Once the lighting layers are all created.
Set the layer mode to Addition and adjust their opacity.
Here is the Luce 2.0.0 plugin,
which works in GIMP 2.8 but not in 2.10
File comment: Luce 2.0.0.exe
luce_plugin.zip [73.17 KiB]
Downloaded 30 times
As an example.
Here is one lighting element that I ran the Luce plugin on.
File comment: Luce Single layer Example.
Note:
One can also create these lighting elements manually,
without the use of plugins or scripts.
However,
this method is slow and tedious,
when compared to what Luce can accomplish is a fraction of the time.
Also note,
that with added lighting comes more shadows.
Sometimes multiple shadows going in different directions.
If you look at the image carefully,
you'll notice that there are few shadows,
if any at all that are well defined.
Adding additional shadows may be something to consider.
 Post subject: Re: What GIMP Features Can Be Utilised?
PostPosted: Sun Jun 22, 2025 5:30 am  (#14)
"You can isolate the lighting elements however you like,
onto there own black filled layers."
I have to ask how this is done?
I got as far as the Color Curves step. I noticed you have a black Layer before the visible layers. Is this needed and how is it created?
PostPosted: Sun Jun 22, 2025 12:22 pm  (#15)
Within my example XCF file.
Each black layer used for this effect has a lighting element within it.
The black layer without an apparent lighting element within it,
was not used and can be ignored.
Once I created the new layer from the visible layers.
I used the free selection tool :freesel to make the appropriate selections of each element.
I copied and pasted each of the elements onto it's own black layer.
Once you have all the lighting element you want.
Run the LUCE plugin on each element to your liking.
Once LUCE was run to my satisfaction on each lighting layer.
I then use "artistic license" on each of the lighting elements,
to refine the look of each element.
This includes the use of whatever tool I feel would help refine each element to my liking.
I used the paint brush tool mostly :brush , the smudge tool :smudge and also the eraser tool :eraser
