It is currently Sun Aug 09, 2026 9:05 am
 Post subject: Issues Installing LUCE
PostPosted: Sat Jun 21, 2025 5:19 am  (#1)
GIMP Version: 2.8.14
Operating System: Windows
GIMP Experience: New User
Been trying to install the LUCE plugin. I have an older version, GIMP 2.8.20 installed. I try to install LUCE and says there's missing .dll files and will not install.
What can be done to install it?
 Post subject: Re: Issues Installing LUCE
PostPosted: Sat Jun 21, 2025 11:51 am  (#2)
Have you placed the LUCE.exe file within your user Gimp Profile plugins folder?
As a side note.
Simply running the LUCE.exe file within Windows,
especially one that's intended to be used as a plugin,
(rather than a standalone executable),
will result in these kind of missing .dll errors.
PostPosted: Sat Jun 21, 2025 12:41 pm  (#3)
As Wallace says make sure the plugin luce.exe is in your Gimp 2.8 user plugins folder Remember it starts with a dot and is a hidden folder C:\Users\"yourname"\.gimp-2.8\plug-ins.
Really need more info:
Is your Windows installation 32 or 64 bit ? The Gimp installer contains both versions and installs accordingly.
Where did you get the luce.exe plugin ? I pulled a 32 bit version out of my archive and that does not work at all. Better luck with a 64 bit version. This Win 7 - 64 bit / Gimp 2.8.
Your error messages look suspiciously like 32 bit..and you are probably getting them by trying to run the plugin directly. ( (2) as console above) Any Gimp plugin has to start from the Gimp menu system, in this case Filters -> Light and Shadow -> luce. (1)
PostPosted: Sun Jun 22, 2025 5:08 am  (#4)
Okay. It's Windows 10 Pro 64-Bit.
I had a luce-2.0.0-32bits-64bits-Win Zip that contained both 32 and 64-bit versions. Tried both by placing the Luce.exe as advised in the .gimp 2.8/plug-ins folder and they didn't work.
Wallace shared a different Luce zip. I placed it's Luce.exe in the .gimp 2.8/plug-ins, IT WORKED.
Thank you both for assisting with this issue.
