It is currently Mon Aug 10, 2026 11:55 pm
 Post subject: crash with gmic
PostPosted: Sun Jul 06, 2025 4:20 pm  (#1)
GIMP Version: 2.10.38
Operating System: Windows
GIMP Experience: New User
:wvy
For the past few days, I've been having a problem with Gmic which frequently freezes, whether it's with my Gimp 2.10.38 version (Gmic 3.5.4)
or with the portable version of samj 2.10.36 (Gmic 3.5.2).
or with samj Gimp_3.0.2_Portable_clang
And I noticed in programs and features this:
Is this normal?
 Post subject: Re: crash with gmic
PostPosted: Thu Jul 10, 2025 7:19 am  (#2)
No replies : No body has a fix, including me.
Using the appropriate gimp_gmic_qt 3.5.5 installer I find no problem with Gimp 2.10.38 / Gimp 3.0.4 both from gimp.org.
You could give a bit more information about which gmic filters you are using. If you are using some old filters maybe incorporated into a "fave" then that might be the problem. A gmic update might be breaking the old parameters.
gmic is a bit like Gimp, it keeps a folder with user files C:\Users\"yourname"\AppData\Roaming\gmic
You could disable that by renaming, run Gimp and then gmic and it will make a new default folder. See if that helps.
The samj portable versions are another matter. I would stick with the gmic that comes with each version. That has its own gmic folder, maybe have a look for that and delete any updatexxxx.gmic files.
PostPosted: Sun Jul 27, 2025 11:15 am  (#3)
:wvy
Thanks, rich2005 :bigthup
Health problems prevented me from coming back to thank you.
I did what you told me, and now I'm limiting myself to using only Gimp 2.10.38. ;)
