It is currently Mon Aug 10, 2026 10:34 pm
 Post subject: How can remove the edge line ?
PostPosted: Tue Jul 29, 2025 3:49 am  (#1)
GIMP Version: 2.8.14
Operating System: Linux
OS Version: Debian 12 + Lxde (desktop)
GIMP Experience: New User
How can remove the edge line in the image?
 Post subject: Re: How can remove the edge line ?
PostPosted: Tue Jul 29, 2025 4:11 am  (#2)
I have a plugin named threshold alpha 2 that does it. You can download it here.
threshold_alpha_2_SourceCode.zip [4.32 KiB]
Downloaded 32 times
threshold_alpha2_linux_binaries_gegl_plugin.zip [4.82 KiB]
Downloaded 37 times
threshold_alpha_2_windows_binaries_gegl_plugin.zip [30.69 KiB]
Downloaded 31 times
Depending on your OS put the binary in
Windows
Linux
~/.local/share/gegl-0.4/plug-ins
~/.var/app/org.gimp.GIMP/data/gegl-0.4/plug-ins
Then Restart GIMP and
if on GIMP 3
/ search for threshold alpha 2
if on GIMP 2.10 to go the GEGL operation menu and look for "threshold alpha 2" GIMP 3 also has this option. Then apply the filter, the higher the slider the less soft edge excesses
PostPosted: Tue Jul 29, 2025 5:13 pm  (#3)
Using GIMP 2.8 I used Curves Adjustment.
Set channel to "Alpha" as seen in the screenshot.
File comment: Result
File comment: Screenshot 2
