It is currently Sun Aug 09, 2026 5:13 am
 Post subject: How can cut out all characters in red color without any select tools?
PostPosted: Tue Jul 29, 2025 9:03 pm  (#1)
GIMP Version: 2.8.14
Operating System: Linux
OS Version: Debian 12 + Lxde (desktop)
GIMP Experience: New User
How can cut out all characters in red color without any select tools(rectangle select,ellipse select,free select)?
 Post subject: Re: How can cut out all characters in red color without any select too
PostPosted: Tue Jul 29, 2025 9:58 pm  (#2)
This required both my plugins, AI plugin and manual selection
It was difficult
PostPosted: Tue Jul 29, 2025 10:48 pm  (#3)
Why do not upload your AI plugin and how to manual select them to cut out all characters in red color?
PostPosted: Tue Jul 29, 2025 11:12 pm  (#4)
Look for "color removal" from AI plugins that is one thing i partially used
viewtopic.php?f=9&t=21647&start=20
https://github.com/LinuxBeaver/LinuxBeaver/releases/
PostPosted: Wed Jul 30, 2025 12:41 am  (#5)
Will those GEGL plugins work in Gimp-2.8.14 Contrast?
PostPosted: Wed Jul 30, 2025 2:14 am  (#6)
cp Downloads/LinuxBinaries/*.so /home/$(whoami)/.local/share/gegl-0.4/plug-ins/
ls /home/$(whoami)/.local/share/gegl-0.4/plug-ins/
'*' gegleffects.so outlinedeluxe.so
3plusdivider.so glass_hardlight.so photo2cartoon2.so
action-lines.so glassman.so photo2cartoon.so
alignment.so glassovertext.so pixel_text.so
artbossing.so glass_tiles.so pixel-wheel.so
balls.so glossy-bevel-.so plastic_wrapping.so
basic_outline.so glowstick.so polygondistortion.so
bevel.so goldbevel2.so polygon.so
bgremoverbycolor.so goldbevel.so quickmaskfilter.so
blendassistant.so goldmetallicmeme.so rgbglitch.so
bloody_ice.so goo.so ringbevel.so
bokeh.so goosub.so ringtext.so
brushed_metal_wood.so gradient-map-port.so rock-surface.so
cbevel.so greataura.so rocktext2.so
charcoal_sketch.so gshapes.so rock-text.so
chippedvolcano.so heaven.so royal.so
chiselbevel.so hyperopacity.so saber.so
clay.so icetext.so sand.so
clouds.so inner-glow.so scratched_glass.so
colorizeluminance.so internal_color_light.so segment-kmeans-port.so
commonadjustments.so invert-alpha.so sharpbevel.so
crayontext.so layershadow.so sharpendeluxe.so
crazy_bevel_collection.so lcs.so shinytext.so
ctrail.so linerayaura.so skeletontext.so
cutout.so liquidwooddistortion.so sketch.so
designer_border.so liquidwood.so slimetime.so
diamondscircles.so loadport.so smoothedge.so
differencedeluxe.so logo.so sparkle.so
doubleglow.so longshadowpd.so sphere.so
earth.so long_shadow_policy.so spiraldistortion.so
edgebevel.so major_plugin_list.so ssg.so
edge_detect_glow.so makeatexture.so starbackground.so
edgeextract.so marblewallpaper.so starburst.so
edgesketch.so maskhack.so stardistortion.so
effects.so metal.so starfield.so
electricity.so motion_shadow.so stripes.so
engraver.so msi.so targetblur.so
extrusion.so neonborder.so thresholdalpha2.so
fixer.so nugget.so tilebg.so
focus.so ocean_surface_2.so tilezoom.so
fog.so ocean_surface.so tsccake.so
frosted_glass.so old.so video-degradation-mod.so
frozengel.so original.so zzstrokebevelimage.so
geglchrome.so orton.so zzwind.so
gegleffectspending.so osga.so
gegleffectsrework.so outerglow.so
Which menu to select and how to use it ?Please write it step by step.
PostPosted: Wed Jul 30, 2025 4:54 am  (#7)
It doesn't work on appimage GIMP
Only GIMP 3 native and GIMP 3 Flatpak. Flatpak GIMP goes in
~/.var/app/org.gimp.GIMP/data/gegl-0.4/plug-ins
Quick answer, probably not but a few might.
For AI Plugins that don't involve nodes but only math the chance is much higher
For my plugins, Only the most super simple ones without node connect have a chance of working in other words over 95% of my plugins will not work because they use node_connect instead of old GEGL's 2.8's node_connect from. Try to see if this plugin works on GIMP 2.8, it is one of the super simple ones with no composer connections
https://github.com/LinuxBeaver/GEGL-GIM ... ge_Extract
https://github.com/LinuxBeaver/GEGL-GIM ... t/releases
PostPosted: Wed Jul 30, 2025 9:18 am  (#8)
I have installed GIMP 2.10.Which one to select?
Get nothing with edge-extract.
PostPosted: Wed Jul 30, 2025 3:52 pm  (#9)
That is the wrong plugin, I will upload the one you need.
Color Removal, the AI plugin from a few months ago to assist with this workflow
color_removal_linux_binaries_gegl_plugin.zip [6.15 KiB]
Downloaded 27 times
color_removal_windows_binaries_gegl_plugin.zip [31.25 KiB]
Downloaded 25 times
source_code_color_removal.zip [7.78 KiB]
Downloaded 23 times
btw unrelated, based on the screenshot you sent me I can likely guess you are using Debian or Ubuntu 22.04 as the vast majority of my plugins are missing because you are using an old version of GIMP 2.10 before GEGL 0.4.46, To use my plugins correctly either update to GIMP 2.10.36+ or use this branch of plugins
Old branch of GEGL plugins for GIMP 2.10.34 and below
https://github.com/LinuxBeaver/LinuxBea ... naries.zip
Do not mix these with modern plugins or things will break. That means you need to remove everything but color removal from gegl-04/plug-ins and replace it with these
PostPosted: Wed Jul 30, 2025 4:01 pm  (#10)
I quickly did this in GIMP 2.8 using just the :clone Clone Tool.
