It is currently Thu Nov 19, 2026 3:17 am
 Post subject: How to automate levels with Batcher plugin?
PostPosted: Tue Jul 29, 2025 9:10 pm  (#1)
GIMP Version: 3.0
Operating System: Windows
OS Version: 10
GIMP Experience: Experienced User
URL or Image link: https://kamilburda.github.io/batcher/
List any relevant plug-ins or scripts:
Batcher
I'm trying to apply the same levels change to multiple images using Batcher. It asks for a "preset file". I know there's \AppData\Roaming\GIMP\3.0\filters\GimpLevelsConfig.settings but it contains all the existing levels presets, not just the one I'm trying to apply. Batcher's interface doesn't give me any way to choose which preset to use.
ChatGPT is telling me that I need to write my own JSON preset file. Before I dive into that, doesn't anyone know how this works? Thanks.
 Post subject: Re: How to automate levels with Batcher plugin?
PostPosted: Thu Feb 19, 2026 7:23 am  (#2)
You may have found a solution to this now but I thought I'd post my solution here, in case anyone searches for this and it's helpful for them.
Firstly, Batcher does now allow loading preset files, which is good!
To create and load a preset:
- Configure your levels , *making sure you have the 'Linear' button checked to ensure compatibility with Batcher*
- Click the button at the far right end of the presets bar (tooltip: Manage presets)
- Choose 'Export Current Settings to File'
- Save your preset file wherever you like, *with the .gtp extension* e.g my_levels_preset.gtp
- Load your preset file in Batcher and run :)
