It is currently Sat Aug 08, 2026 12:38 pm
 Post subject: CIE Lab* colour values from scans
PostPosted: Sat Aug 30, 2025 6:56 pm  (#1)
GIMP Version: 3.0.4
Operating System: Windows
GIMP Experience: New User
Is there a 'newbie' method that will identify the CIE L*a*b* shade of scans taken with an Epson ET-2810 scanner? TIA for any advice.
 Post subject: Re: CIE Lab* colour values from scans
PostPosted: Sun Aug 31, 2025 3:02 am  (#2)
The images will be RGB - Gimp is a RGB editor, although the color profile, the something.icc can vary. When you import an image there is usually a choice to keep-existing or convert-to-GimpRGB Probably best to keep.
You can decompose Colors -> Components -> Decompose and select LAB from the Color Model Drop down menu. (1) see: https://docs.gimp.org/3.0/en/plug-in-decompose.html Greyscale layers which you can edit then Recompose.
If you install the gimp_gmic_qt plugin http://www.gmic.eu then that also has a decompose filter (2) also...
...an interactive curves filter with a LAB option (3)
What are your scans ? Are they negatives ? There will be users more experienced than me for that purpose.
PostPosted: Sun Aug 31, 2025 5:03 am  (#3)
Thanks rich2005,
They are scan in high res of very old postage stamps that have numerous shades. I'm endeavouring to catalogue against the attached research document.
File comment: It is the shade measurement in this file I am attempting to compare against. I have downloaded Paterson Photography Colour Checker to calibrate against the printers colour output. I'm not overly tech savvy but I'm prepared to work towards a solution to my dilemma.
Vol 095 No 02 Jun 2015 ~ Optical Properties of the Chalon Issues Tables ~ Klaus Moller.pdf [372.62 KiB]
Downloaded 30 times
PostPosted: Sun Aug 31, 2025 6:14 am  (#4)
Ouch ;) I can not see anything in Gimp for that. A quick look at ImageMagick - nothing obvious.
Try this scientific application: Two versions ImageJ https://imagej.net/ij/ and an enhanced version fiji https://imagej.net/software/fiji/downloads
In the fiji plugins menu to look for Color Inspector 3D That gives values under the cursor for RGB and LAB
A quick scan into Gimp, export as a png - looks like this using fiji
Edit: A closer look and if you select the histogram option and then click LUT you get a table of Lab colours
PostPosted: Sun Aug 31, 2025 7:14 pm  (#5)
rich2005 - Thank you. That's helpful and will get me to the next stage I think.
