It is currently Sun Oct 04, 2026 7:06 pm
 Post subject: Linux Mint: Upgrade from Gimp 2.10.36 to 2.10.38
PostPosted: Wed Sep 24, 2025 3:03 pm  (#1)
GIMP Version: 2.10.36
Operating System: Linux
GIMP Experience: New User
:wvy
As I mentioned in this thread: viewtopic.php?f=8&t=21594, I'm new to Linux.
I abandoned my Linuxmint cinnamon training during the hot months, and now I'm resuming my exploration.
The installed version of Gimp is 2.10.36, and I'd like to upgrade to 2.10.38, but the update search suggests version 3.0.x, which I don't want.
How should I proceed?
 Post subject: Re: Linux Mint: Upgrade from Gimp 2.10.36 to 2.10.38
PostPosted: Wed Sep 24, 2025 11:17 pm  (#2)
How did you get update suggest for 3.0.x?
I have Mint 22.2 on one laptop, and to replace 2.10.xx with 3.0.x (I guess it was 2.10.36) I used Panda Jim (ubuntuhandbook) PPA
It's an unofficial PPA I have used for years on Mint because Mint comes always behind the initial releases.
Here's "how to" but you should wait for rich's reply, he knows these things well.
https://ubuntuhandbook.org/index.php/20 ... 6-release/
BTW, this is why my main distro is MX Linux. I'm running 2.10.38 on MX. It has it's own package installer that allows you to choose from various PPAs.
PostPosted: Wed Sep 24, 2025 11:35 pm  (#3)
There should be a linux Gimp-2.10.38 in the repository.
https://download.gimp.org/gimp/v2.10/
You need only compile the 2.10.38 src files. There should be a .configure file in that src folder and running that in a cmd window should get you a make file. If you have all the needed dependencies installed first.
Other than that i do not know how you can get it installed. A linux user here would know how to get the file from git and install from there.
Good luck! I haven't messed around with Linux for years. :)
:ninja by Nidhogg :)
PostPosted: Thu Sep 25, 2025 1:55 am  (#4)
Compiling GIMP is nothing for Linux newbies. M2C.
@level_0 will probably have to stay with 2.10.36.
Or use an AppImage.
Problem with 2.10 GIMP is the outdated components in it (GTK2, Python2)
which are no longer supported by the system.
PostPosted: Thu Sep 25, 2025 2:49 am  (#5)
Nidhogg :wvy Rod :wvy quietreader :wvy
Thank you for your replies.
Reply to Nidhogg: I opened Gimp and:
What Rod is suggesting is too complicated for me; :cry:
I'll wait for rich2005. :)
PostPosted: Thu Sep 25, 2025 2:53 am  (#6)
I managed a Gimp 3.0 compile once ! Usually fail right at beginning with GEGL and dependency hell ;)
Appimage is a good alternative.
There is a Gimp 2.10.38 that should work although you might have to install libfuse2t64. It will use gimp_gmic_qt and comes with python 2.7 for those old useful python plugins.
https://github.com/TasMania17/Gimp-Appi ... s/releases
and if you want to try a Gimp 3.0.4 This comes with a gimp_gmic_qt alteady installed (needs QT5 which should already come with Mint)
https://www.gimp-forum.net/Thread-Gimp-3-0-4-AppImage
A 1' 20" video example of those in Mint 21 https://i.imgur.com/BjyAojS.mp4
PostPosted: Thu Sep 25, 2025 4:00 am  (#7)
Thank you, rich2005 :hugme
I'll study your response and certainly come back with questions. ;)
PostPosted: Thu Sep 25, 2025 5:11 am  (#8)
Yes, You will probably need some help somewhere in the process. Please give your version Of Mint - 21.3 or maybe 22 .1 That video shows Mint 21.3 The version does matter when it comes to gmic and appimages.
PostPosted: Thu Sep 25, 2025 6:48 am  (#9)
This is Linux Mint 22.2 Cinnamon
PostPosted: Thu Sep 25, 2025 9:28 am  (#10)
OK this is a Mint 22.2 zara but the MATE desktop rather than Cinnamon. Still based on ubuntu 24.04 LTS so both those appimages work. I have tried both.
For Gimp 2.10.38 and gimp_gmic_qt 3.6.1 , use the ubuntu 24.04 version from the gmic.eu site. You might already have that.
A suggestion.
Put the appimage in its own folder and make a menu item for it: You can supply your own icon.
This is Gimp 2.10.38 up and running and the menu item.
PostPosted: Sat Oct 04, 2025 8:09 am  (#11)
Here I am again :wvy
Thank you all for your contributions.
All of this seemed very complicated for a Linux beginner.
So I decided to continue with Gimp 2.10.38 on my Windows 10 computer.
And on the Linuxmint PC, I uninstalled Gimp 2.10.36, which was installed by default, and installed Gimp 3.0.4, which was offered as a Flatpack.
The question remains how to put Gmic.
PostPosted: Sat Oct 04, 2025 12:40 pm  (#12)
If you go to the gmic site it says
so in a terminal run the command
flatpak install flathub org.gimp.GIMP.Plugin.GMic
PostPosted: Sun Oct 05, 2025 11:18 am  (#13)
Thank you Rich2005 :hugme
It's done :)
