It is currently Sun Sep 27, 2026 5:13 am
 Post subject: Blurring Upon Resizing
PostPosted: Mon Sep 29, 2025 10:38 am  (#1)
GIMP Version: 2.8.14
Operating System: Windows
OS Version: 10
I recently upgraded from a previous version of GIMP to 3.0.4.
One of the weirdest problems (among a few) I have encountered is that part of the image blurs when I scale downward.
I start with, say, a 1200x1200 px image and scale it to 600x600. The top third or so of the image goes blurry; the rest remains clear.
X resolution and Y resolution are at 300 pixels/in
Interpolation set to Cubic or None gives the same results
Any ideas? I'd post links to images, but I'm too new.
 Post subject: Re: Blurring Upon Resizing
PostPosted: Mon Sep 29, 2025 2:19 pm  (#2)
I got help on Reddit, so the initial problem is resolved. I had an effect (Gaussian blur) connected with my layer.
I still question how that got there, so that I can prevent it from happening in the future.
PostPosted: Mon Sep 29, 2025 3:27 pm  (#3)
It can only get there if you applied the gaussian blur filter. It does not happen on its own accord.
When you apply a filter that will become a non-destructive-effect (nde - that fx icon) there is a check box to merge it straight into the layer (1) If you forget or leave as a nde then clicking on the fx icon comes up with options, one is a merge (2)
