It is currently Sat Nov 21, 2026 6:31 am
 Post subject: GIMP 2: Smoothen Jagged Edge after Background Removed?
PostPosted: Sun Oct 19, 2025 12:34 am  (#1)
GIMP Version:
Operating System: Mac OS
GIMP Experience: Experienced User
Hi,
I'm working on a Jpeg Portrait - Background Removing.
How do you Smoothen Jagged Edge of the "PERSON/MODEL" after Background Removing process?
 Post subject: Re: GIMP 2: Smoothen Jagged Edge after Background Removed?
PostPosted: Sun Oct 19, 2025 4:12 am  (#2)
Depending on the size of your image. I would give it a little of a feather, only 3 if a small image. Not too much as you will get a 'white' border around your image. The feathering helps to blend in with the background and without, the removal will look too unnatural.
Edit- Oh, and do this feather before deleteing the background.
Only other thing I can think of is after you delete the background maybe Alpha to select the image, shrink a couple of pixels then invert the selection and blur it a little so the edges become more smooth
PostPosted: Tue Oct 21, 2025 4:05 pm  (#3)
This plugin might help. Same plugin works on GIMP 2.10 and 3.
https://github.com/LinuxBeaver/GEGL-GIM ... /releases/
PostPosted: Thu Oct 23, 2025 8:12 am  (#4)
Alright, will check that out soon ☺️
PostPosted: Thu Oct 23, 2025 8:17 am  (#5)
Thanks a lot! Will give it a try then!
