It is currently Fri Nov 20, 2026 8:23 pm
 Post subject: I need a quick help with image editing zoom scroll down effect
PostPosted: Tue Nov 04, 2025 11:56 am  (#1)
GIMP Version: 2.8.14
Operating System: Windows
OS Version: Win 11
GIMP Experience: New User
Hi.
I need a quick help with canva, gimp, capcut or something free.
So i have a picture with a text made up ( half of a4 format ), what i want is to create a zoom effect to the beginning of a text and with time this zoom effect scroll down to a middle and end section of my whole text.
Somebody with experience could help me.
If can apreciate alot!
 Post subject: Re: I need a quick help with image editing zoom scroll down effect
PostPosted: Wed Nov 05, 2025 5:48 am  (#2)
In GIMP 2.8.14 you could duplicate your text layer several times,
and on each copy use Scale (for zoom)
and Move (to scroll down) a bit more than the last.
Rename each layer like Frame 1 (100ms), Frame 2 (100ms), etc.,
then preview via Filters → Animation → Playback,
and export as an animated .GIF (File → Export As → GIF → As animation).
PostPosted: Fri Nov 07, 2025 5:26 am  (#3)
Check pm.
PostPosted: Fri Nov 07, 2025 10:16 am  (#4)
Sergeys777 wrote:
[align=center]In GIMP 2.8.14 you could duplicate your text layer several times,
Check pm.
Please post any resources or references you might have and also provide more detail,
so that others within the forum might be able to assist you.
PostPosted: Fri Nov 07, 2025 10:47 am  (#5)
Check pm.
PostPosted: Sat Nov 08, 2025 2:38 am  (#6)
Not sure if there is a 3rd party plugin to create an animation like this. Possibly it could be done with Gimps Animation Package ( GAP ).
You can get it for Gimp-2.7 (should work in Gimp-2.8 and Gimp-2.10 versions as well), here...
https://www.gimp-forum.net/Thread-Insta ... -Gimp-2-10
Or straight from my (wacmaster), onkelhatti, and Photo Comics website (free gimp packagers), here
https://sourceforge.net/projects/gimp-p ... z/download
You will find a tutorial on installing GAP and creating a GIF animation here
https://www.bing.com/videos/search?q=do ... &FORM=VIRE
There could be a tutorial for a zoom animation on YouTube somewhere.
This is basically a magnification effect correct?
PostPosted: Sat Nov 08, 2025 3:33 am  (#7)
This animated text tutorial may possibly give you some ideas as well. :)
https://www.youtube.com/watch?v=KkX18lqXjYw
PostPosted: Sat Nov 08, 2025 9:07 am  (#8)
I would not expect much from gimp-animation-plugin (GAP) it is very old and not much works with Gimp 2.10
The initial proposal is a bit strange and and I am not 100% understanding.
A4 size image - way too big for an animation
The text area fills most of the width. Not much scope for zooming in.
However, not Gimp but using ImageMagick with a command like this
magick page.png -distort SRT 'mid-page,y-offset  zoom factor  angle '  +repage out.png
And with a suitable script to generate images then into Gimp for an edit and animation.
PostPosted: Mon Nov 10, 2025 4:30 pm  (#9)
Hmm i like your attachment. Can u do the text like appearing from the very bottom to up to fill the whole window to end?
PostPosted: Tue Nov 11, 2025 5:03 am  (#10)
Sergeys777 wrote:
....snip... Can u do the text like appearing from the very bottom to up to fill the whole window to end?
That is scrolling up and you cannot scroll some text that does not exist into a canvas. You need to edit your image with a blank area on top of the text. This is a A4 landscape @100 ppi double height. A bit like your diagram, a moving window using ImageMagick.
I use linux - you need a Windows user for MS format - just for info, in a script.
#!/bin/bash
count=0
until [ $count -gt 830 ]
do
    echo "$count"
    count=$(( $count  + 40 ))
done
Any document as yours makes a monster file size. Even as a tiny animated gif this still 1 MB.
The best place for imagemagick question is their forum https://github.com/ImageMagick/ImageMagick/discussions
PostPosted: Tue Nov 11, 2025 6:14 am  (#11)
Can you guide me step by step to make an animation ?
PostPosted: Wed Nov 12, 2025 3:58 am  (#12)
#!/bin/bash
count=0
do
    echo "$count"
done
PostPosted: Wed Nov 12, 2025 9:24 am  (#13)
Do I detect a bit of desperation ? Not able to use ImageMagick ?
Well, a Gimp 3 solution that is only slightly automated, uses the scrollup.scm script-fu attached.
Put that in your Gimp 3 scripts folder C:\Users\"yourname"\AppData\Roaming\GIMP\3.0\scripts
This uses the Gimp offset function.
works like this: about 5 minutes https://youtu.be/vx9WCxju6BQ
scrollup.scm [887 Bytes]
Downloaded 73 times
PostPosted: Wed Nov 12, 2025 10:08 am  (#14)
Alright thanks. Might be trying this out later. Rn i figured it out with other tool. Peace.
PostPosted: Wed Nov 12, 2025 4:34 pm  (#15)
Oh Well, guess I was wasting my time then ;)
PostPosted: Thu Nov 13, 2025 3:07 am  (#16)
Might be not. Some other people might get something from it. Also i might try something else to later.
