It is currently Fri Nov 20, 2026 7:46 pm
 Post subject: Canny Edge Detection & Depth Map plug-in filters??
PostPosted: Fri Dec 12, 2025 11:06 am  (#1)
GIMP Version: 3.0.6
Operating System: Linux
OS Version: Arch Linux
GIMP Experience: Basic Level
 Post subject: Re: Canny Edge Detection & Depth Map plug-in filters??
PostPosted: Fri Dec 12, 2025 1:17 pm  (#2)
G'MIC has presets for both. :)
PostPosted: Fri Dec 12, 2025 7:04 pm  (#3)
Using the 64 bit plugin ( V-02-Windows), i get really nice results.
Utilizing a partial mask, and grain merge layer mode on the resulting layer. with about 47% opacity.
Original created in Canva AI with Affinity.
The results with Canny edge detect. :bigthup Results are definitely sharper.
Plugin did crash though while raising threshold parameters. But i just ran it thru filters>Repeat and it worked fine.
PostPosted: Fri Dec 12, 2025 7:13 pm  (#4)
Switched out the 64 bit with the 32 bit V-02 version and no crashes. :) Thanks MareroQ!
