It is currently Thu Nov 19, 2026 4:43 am
 Post subject: Gimp won't open Documents file
PostPosted: Mon Dec 29, 2025 9:40 pm  (#1)
GIMP Version: 3.0.6
Operating System: Mac OS
OS Version: Sonoma 14.7.6
List any ERROR messages you received:
Could not read contents of Documents
Operation not permitted
I have used Gimp successfully for several years. Yesterday I downloaded the latest version (3.0.6). When I tried to do a "save as" operation to my Documents file, I got a message that Gimp wanted permission to access the file. By mistake I pushed the reject button. Now Gimp won't access the Documents file. How can I undo the reject and give Gimp permission to read the file? I tried deleting Gimp and re-installing it but I still get the same lockout.
Thanks for any suggestions.
RWF
 Post subject: Re: Gimp won't open Documents file
PostPosted: Tue Dec 30, 2025 12:29 am  (#2)
Usually removing the gimprc file and restarting GIMP works most of the time.
In windows it is found here.
C:\Users\username\AppData\Roaming\GIMP\3.0\
Not sure where you can find it in Mac.
PostPosted: Tue Dec 30, 2025 10:26 am  (#3)
I found the file but deleting didn't help.
On Mac the location is
~/Library/Application Support/GIMP/3.0/~
PostPosted: Sun Feb 22, 2026 9:06 pm  (#4)
Try System Settings/Privacy and Security/Files & Folders/Gimp and see if thre's something there you can change. Screenshot of mine below:
File comment: Screenshot of where the system keeps track of app's access to other directories
