cibolo wrote:
"since you are using Mint Zena use one of the PPA's"
...snip...
It installed many -dev packages. maybe I can compile locally with those as dependencies? But, for now, I have responsive gimp that can be backgrounded and still work.
Maybe you had an existing libgimp dev package which got upgraded, that pulls in lots of dependencies. A clean install - with just a
sudo apt install gimp leaves all that out. From memory about 30 or 40 MB of packages.
Now you have gimp tool, then you can compile plugins, not too many at the moment, gimp_gmic_qt, resynthesizer, deskew
Running in background. I manage with a mixture of appimage Gimp 2.10 and PPA Gimp 3.0.8 and can get more than one running using the gimp -n (new instance) switch
