It is currently Thu Nov 19, 2026 3:18 am
 Post subject: Error when trying to open a jpg file
PostPosted: Thu Feb 12, 2026 4:32 am  (#1)
GIMP Version: 3.0.6 rev
Operating System: Windows
GIMP Experience: New User
I've just restored some jpg files from an external hard drive using a piece of data recovery software. When I try and open the file in Gimp I'm getting the following error message: ' Not a JPEG file, starts with 0x02, 0x00. Opening F:\050226\3.jpg failed. JPEG image plug-in could not open image'. I've looked at the file attributes in File Explorer and it does appear to be a JPG file. I tried within the attributes to find the 0x02 data but failed. I've got over 20,000 files like this so I should very much appreciate any assistance in sorting out this problem. Many thanks.
gimp error.pdf [291.94 KiB]
Downloaded 75 times
 Post subject: Re: Error when trying to open a jpg file
PostPosted: Thu Feb 12, 2026 4:46 am  (#2)
Looks like it should be an image of some sort. The file isn't corrupted is it?
PostPosted: Thu Feb 12, 2026 5:30 am  (#3)
Long shot, change the extension from .jpg to .png and try again.
PostPosted: Thu Feb 12, 2026 6:48 am  (#4)
It will be a long shot by changing the file extension. Gimp uses a file signature to identify the type of image.
A long list here: https://en.wikipedia.org/wiki/List_of_file_signatures
Get a binary editor, open the file and have a look at the contents. It should tell you right at the top the file format. Very often you find a file full of zeros and is scrap. This a png "renamed" as a jpeg and a regular jpeg.
Hmm...the only one in the list starting 02 00 is ClarisWorks
PostPosted: Thu Feb 12, 2026 9:18 pm  (#5)
have you tried another software package? an image viewer.. just to make sure it isnt an issue with gimp.
PostPosted: Fri Feb 13, 2026 4:29 am  (#6)
I'm getting the same problem when trying to open the file in Adobe Photoshop Express. I couldn't see anything obvious when the file was opened within a hex editor.
