It is currently Fri Nov 20, 2026 9:28 pm
 Post subject: Drawing Tablet for GIMP - Recommendations please
PostPosted: Fri Feb 13, 2026 2:55 pm  (#1)
GIMP Version: 3
Operating System: Windows
OS Version: Windows 11
GIMP Experience: Basic Level
Hoping I've posted in the right place.
I've been using GIMP for some years now, and have come to the conclusion I need a Drawing Tablet. Could anyone recommend one for me that works well with GIMP. I have done my research but there is so much to choose from, and I want to get the right one. I have a budget for around £50. I don't need professional equipment, but I don't want garbage either.
Thanks
 Post subject: Re: Drawing Tablet for GIMP - Recommendations please
PostPosted: Thu Feb 19, 2026 6:03 am  (#2)
My Huion H420 works well in GIMP. It's pretty basic and not that big, but you can pick one up second hand now for under £10! It could be a good option if you want to see if using a tablet is for you, before getting something bigger and better.
PostPosted: Sat Feb 21, 2026 10:20 pm  (#3)
I do still have a very functional Wacom Intuos Pro (PTH-860),
sitting around if needed,
but I don’t generally use my tablet much these days.
With a £50 / ~$67 budget,
You're looking at smaller tablets,
brands like the already mentioned Huion tablet,
or a XP-Pen,
or perhaps Veikk.
Models in the XP-Pen Deco range,
or the Huion Inspiroy range,
tend to sit around your budget,
and offer a few good features as well.
I’d avoid very cheap tablets or writing pads,
as some may not provide proper pressure sensitivity,
among other things,
if they work at all.
A small, non-screen tablet can work perfectly fine,
and may also begin to feel natural over time.
Hope this helps!
PostPosted: Tue Mar 03, 2026 12:49 pm  (#4)
Thank you so much for your comments both of you. much appreciated.
