It is currently Fri Nov 20, 2026 10:59 pm
 Post subject: Add Gmic to Gimp on MacBook
PostPosted: Thu Apr 09, 2026 7:24 am  (#1)
GIMP Version: 3.2.0
Operating System: Mac OS
GIMP Experience: New User
Hello Gimp users
Can I install Gmic for Gimp om MacBook Air ?
And if I can install Gmic - How can I do it ?
Thans
Doron.
 Post subject: Re: Add Gmic to Gimp on MacBook
PostPosted: Fri Apr 10, 2026 3:06 am  (#2)
I asked your question here https://discuss.pixls.us/t/mac-book-ins ... gmic/57057 one of the best places to get an answer unless you are part of a Mac community and they can tell you.
PostPosted: Fri Apr 10, 2026 2:31 pm  (#3)
Dear sallyanne
Thank you for your help.
I will install Parallel and solve the problem with Parallel.
Doron.
PostPosted: Fri Apr 10, 2026 7:16 pm  (#4)
Hope that helped some.
Got an answer for you
At GMIC page it says that G’MIC is not officially maintained for Mac. You would need to go the MacPorts or Howebrew routes.
PostPosted: Sun Apr 12, 2026 6:25 am  (#5)
Try these links and see if they help
https://ports.macports.org/port/gmic-gimp/ &
https://formulae.brew.sh/formula/gmic#default
